Quickie review of ~$10 Rofis TR31 from an Amazon seller.
On Sunday, I noticed bikenber73 posted a deal alert for a Rofis TR31 flashlight on Amazon for $10.
I’d spent most of the weekend exploring options for 26650 hosts, and in the process I’d realized that I could probably do with an 18650 light or two to experiment with, so, I decided to jump on it, knowing nothing much about the light, beyond it being a Rofis, who seem to have a decent reputation.
The light came today and of course, I had to check it out. I even remembered to put a battery in it and turn it on before I took it apart.
I was a little thrown by the fact that I had to hold the button for the better part of a second before it turned on. From there, I flicked through the modes a few times, and then set to work inspecting it more closely.
The tube and tail are turned and milled from a single piece of metal and there looks to be enough room for a protected 18650. The head is a meaty chunk of aluminum with an integrated shelf for the MCPCB and topped with a stainless steel bezel. The anodizing looks and feels great, as good as any of my other lights (including an a v1 BLF X6-SE and a BLF A6). So far, so good!
Whoops, not so fast. The gap between the bezel and the head is a little uneven, but nothing worth fretting about. On the other hand, I noticed that emitter didn’t look well centered, definitely problematic. Rotating the light to make sure it isn’t an optical illusion confirms the fault and also suggests that there is no spacer/centering ring. Oh well, I’ll just have to open it up, void the warranty, and see what I can do.
Easier said than done. The bezel threads seem to be glued. After a few minutes with a heat gun, the mass of aluminum in the head was too hot to touch for more than an instant. I wrapped it in a washcloth and then struggled to figure out how to apply enough torque to the bezel to turn. I was considering breaking out some channel locks before hitting on the method that ended up working. I found a meaty screw driver, pressed hard against the bezel, up against the crenelations, and then applied as much torque as I could. It worked! After a quarter turn or so with the lever, I was able to twist it the rest of the way off by hand. Once free, I could see the ruby schmoo that had been applied to keep me from removing the bezel. I broke/scraped as much of it away with a bamboo skewer and then cleaned the rest out with solvent in preparation for eventual reassembly.
I was confused at first by what I found after removing the bezel, glass and reflector. The star looked like it had a bite taken out of it! There were no screws securing it, but there was a screw off in the area of the shelf where the missing part of the star would have been. Was it there to hold in some of the driver components below? I could see some thermal goop smeared from under the star. The star moved freely when I nudged it, so it was thermal grease, not adhesive.
I took out the mystery screw. It was short and had some reversible thread locking glue on it. As I unscrewed it, the pieces started falling into place. The light was $10 because finally assembly was performed by a team of morons!
The star was designed with the bite taken out of it, but it was also backed by a substantial amount of copper. It was supposed to be installed 180° from how it was, which would allow the screw to clamp down on a (single) notch in the PCB.
As I thought about my options for fixing the unfixed star, I realized that the person responsible for installing the star may not have been a complete moron (but their boss and co-workers clearly were). They may just have been doing their best to work around the fact that the leads from the driver had been threaded through the holes in the shelf backwards (positive where negative should be, and vice versa). The leads weren’t long enough to reach if the star was secured in the proper orientation. Rethreading them probably wasn’t an option for the worker, and may not be for me, either.
I thought I could just desolder the star, remove the driver and rethread the leads in the proper orientation. At least I did until I realized the driver was glued in! I’m not sure what it will take to break it loose, and I’m a bit worried I’ll find potting compound on the other side.
At this point, I think my best option is probably to find a suitable centering ring and reassemble the light and just use it as is. Beyond that, I could put in a new star/LED, one without a bite taken out of it, that I could screw down. Or, I can work on getting the driver loose and go from there.
Tl;dr? The Rofis TR31 seems like a good, solid light, but the low $10 price I paid Amazon was almost surely the result of some assembly flaws, and remedying them is made more difficult because the driver is glued in.
Did anyone else get one of these lights for ~$10, recently? How does yours look?
I got 2 coming (weather delay) from amazon.
Got 1 today, should have ordered 2+
Emitter well centered so no reason to take apart.
No problem with the gap at the bezel like the OP commented about,
Weird driver, when you turn it off it goes to next level just as it’s turning off, but remembers correct level when turned on, Strange.
Nice steel bezel,good ano, decent tint but slightly annoyed by the AR coating tint shift of the glass. Not bad enough to change the lens however, only noticeable when white wall hunting at close range.
The manual with it claims it will come down off turbo at 5 min and go to 500 lumen, Wish there were a way to just go there as a hidden mode or something.
Tried the internal charging with a Samsung 30R and it came off right at 4.21 volts so happy about that,
Anyway, First Rofis for me and I like it, well bought for under $10.
They sold out quick after being posted here on the mighty BLF
Later,
Keith
Reflow that emitter so that the anode & cathode are in the non-corresponding spots to that board. Normally this will of course be bad because the polarities will be reversed but in your case it will allow you to reinstall the board in the correct orientation w/o repositioning the wires :smiley:
I purchased two as well. Nice light for the buck. I like the no tail switch and side long press switch. Built in battery charger works well. Great bargain light.
Bought 3 of these before Christmas they all work great.
Comes with 2 o rings, a lanyard, a nice holster, and a charge cable.
Emitters look centered, and bezel gaps are even.
Good light for the money.
I guess I got the dud in the batch then. I tried freeing the driver from the glue holding it in, but didn’t have any luck. I think I’m just going to get a suitable centering ring and reassemble the light. With the reflector in place and the bezel screwed on, the star isn’t going anywhere.
I do kind of wish I’d bought another one or two, but the truth is, I already have more lights than I “need” and if I’m going to get more, I’d rather add some variety and novelty.
I am partially to blame for the quick sell out, I have 5 coming to gift to family. Glad to see a positive review of it, I couldn’t find anything on the new version before I bought them
Heh. I actually did use channel locks on mine. I used a thick rubber bungee cord to protect the bezel and was able to remove it without any scratches. No regrets about purchase, but I question whether or not it’s really a Rofis. I’m pretty sure the TR31 has a tail switch in addition to the side switch and is capable of momentary function. The Amazon reviews from last year seem to support this.
Not bad for $10, though. As mentioned, charging seems to work quite well.
The thing that bothers me about the light is the lanyard loop on the tail. How much harder would it have been to tap a second hole to the side to keep from looping over the edge? That would have let it stand on its tail.
Interesting light, wish I would have seen the deal alert, I would have bought one for a host if nothing else. I like SS bezels and love aggressive knurling, and from the photos it looks pretty aggressive?
Yes I’m wondering now exactly what this light really is?
The (real) original Rofis TR31 (discontinued) looks completely different and does have a tail switch, but no stainless bezel:
https://www.gearbest.com/led-flashlights/pp_68011.html
Looks like you can still get one here for $20.99: http://www.sbflashlights.com/Rofis/Rofis-TR31-p260.html
And apparently there was another (real) version, possibly a later upgraded version that did have a SS bezel:
A couple of Chinese vendors on ebay are selling the (Fake??) side switch only amazon version for $24-$25 with an NCR18650B cell included:
https://www.ebay.com/itm/Rofis-TR31-CREE-XP-L2-LED-985-Lumens-Rechargeable-Flashlight-w-3400mAh-Battery/253301444036?hash=item3af9f14dc4:g:UVcAAOSwH3haKpN8
https://www.ebay.com/itm/Rofis-TR31-CREE-XP-L2-LED-985-Lumens-Rechargeable-Flashlight-w-3400mAh-Battery-/112729658475?rmvSB=true
Nice find. Thanks for the review!
There seems to be, at least from this seller on Amazon, a Rofis TR31C.
https://www.amazon.com/gp/product/B018U2VP9O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
and a TR31
https://www.amazon.com/gp/product/B072171SV9/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I purchased 2 of the TR31C from the seller back in November for $10 each. It has two switches a battery and a clip. I was going to put that deal up but they sold out before I could. I kept searching Amazon every other day for more when I found the TR31. I bought one of them and it’s not bad , not as good as the TR31C. Mine has mode memory. It has the weird thing when it switches to the next mode before turning off but I always starts on the mode I started turning it off in.
I am glad others are happy with the deal!
I received mine, they look to be great quality and finish. The only complaint I can have with it is that the bezel is not perfectly concentric with the head, so that there is a very slight ledge on the transition between the two parts. I’ve tried the charging a couple times and it also works well, light is red when charging and turns green when finished, I plan to test all 5 before I give them away. I don’t think these are fakes, on several accounts:
-The finish is too nice for a typical knock off, usually it would be the thin shiny coating that’s uneven comes with defects in the grooves
-Knurling is too deep and consistent, cheap lights usually have imperfections at the edges of the diamonds, but this one doesn’t
-It has an AR lens, which would be the first corner a fake one would cut I would think
-The same seller has a limited stock of a certain version, when thy sell out they’re gone
All of mine arrived in an unlabeled box (with a nice foam cutout for the light) instead of a ‘Rofis’ box, so I think it is more likely some overstock or discontinued stash. Anyway, for all I get for $10, I wish it were a fake rofis and the manufacturer make lots and lots more.
Ya probably just an older V1 overstock
