Test/review of Sony US18650VT3 1500mAh (Green)
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 1 sec ago
DSC_3102
Official specifications (This is for VTC3):
  • Nominal capacity: 1600mAh
  • Rated capacity: 1500mAh
  • Capacity at 1.5A discharge: 1425mAh
  • Nominal voltage: 3.7V
  • Charge current: 1.5A
  • Discharge cut-off: 2.5V
Sony%20US18650VT3%201500mAh%20(Green)-info
A older 18650 battery for tools.
DSC_3101
DSC_3103DSC_3104
DSC_3105
DSC_3106
Sony%20US18650VT3%201500mAh%20(Green)-Capacity
There are two curves for all discharge currents, this must be a perfect match between the two batteries. The batteries has nearly constant discharge capacity up to 20A.
Sony%20US18650VT3%201500mAh%20(Green)-Temp-20.0
Sony%20US18650VT3%201500mAh%20(Green)-Temp-30.0
Sony%20US18650VT3%201500mAh%20(Green)-CapacityTimeHours
Sony%20US18650VT3%201500mAh%20(Green)-Energy
Sony%20US18650VT3%201500mAh%20(Green)-PowerLoadTime
Sony%20US18650VT3%201500mAh%20(Green)-TripCurrent
Sony%20US18650VT3%201500mAh%20(Green)-Charge
Conclusion
The battery has fairly low capacity by todays standard, but it can deliver a lot of current.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
Nooner
Last seen: 14 hours 25 min ago
Thank you for this review.
I have a bunch of these cells from Makita 18V battery packs I’ve dismantled.
They are used and low on mAh. But I’m happy to see that they are capable of high current draw. I don’t have the capacity to test that.
Thanks again for the above information!
