Niwalker 2018 Group Buy is ACTIVE now. Reply below if you wish to receive our deal details.
Product review: LEXEL / Maukka
MSRP: $159.95 / GB price: $LOW
Features
- Utilizes U.S. made Cree XHP35 HI emitter
- Maximum output up to 2200 ANSI lumens
- Highly efficient constant current design offers maximum output and runtime
- Smart triple Multi-function clicky side switches.
- Memory function to remember last output setting used (except hidden modes on main switch)
- Advanced thermal protection circuit prevents overheating
- Unique smooth reflector design provides great throw beam distance and beam pattern
- Aircraft grade aluminum, mil-spec hard anodized for maximum wear
- Toughened ultra-clear tempered glass lens with anti-reflective coating
- Large cooper heat sink pad for superior thermal conductivity
- LED indicator turns red(below 12V) to alert user to switch lower output mode and recharge batteries in time
User Interface
- Press hold the main switch for momentary activation (100% output). Do second -press hold within 3 seconds for 100% constant on.
- Double click the switch for instant strobe.
- Triple click the main switch for lock out.
- Press hold the main switch when light is on for changing outputs (0.2 lumen>25 lumen>300 lumen>900 lumen>1500lumen).
- Once you release the switch, the light comes on constant output with mode memory.
- When the light is on-double click to access hidden modes (SOS, beacon, warning flash).
- Press hold the switch for changing hidden modes.(light flashes to let user know you are in next mode). One click gets you back to the output you were in.
- You can save one different mode or output on each switch next to main switch. (Press hold the switch that you want to save - led indicator on main switch flashes means its saved.
- All three switches are able to operate independently when modes/outputs are saved.
Product review: Maukka
MSRP: $229.95 / GB price: $LOW
Features
- Utilizes total 3 U.S. made emitters - 2xXHP70.2+1xXHP35 HI
- Maximum output up to 10,000 ANSI lumens
- Memory function to remember last output setting used (except main switch)
- LED indicator turns red (below 12V) to alert user to switch lower output mode and recharge batteries in time
User Interface
- Press hold the main switch for momentary activation (100% Output). Do second press hold within 3 seconds for 100% output constant on.
- Double click the main switch for strobe.
- Triple click for lock out (main switch, switch A and B)
- There are three settings in main switch- setting 1 (2xXHP70.5) > setting 2 (1xXHP35 HI) > setting 3 (2 x XHP70.5 x 2 + 1xXHP35 HI). You may select your desired setting first and then press hold the main switch when light is on for changing outputs
- When the light is on - double click to access hidden modes (SOS, warning flash, beacon)
- Press hold the main switch for changing hidden modes.(light fast flashes to let user know you are in next mode)
- You can save one different mode or output on switch A or B (Press hold switch A or B that you want save)
Product review:
MSRP: $259.95 / GB price: $LOW
Express Your Interest Below
My VOSTRO order is here.
FreeDailyDeals | Freeme's Group Buy / Freeme Club ★★★★★ / Giveaway
Count me in,,,,
Interested, depending on price !
yes
Yes
Max
Vostro
http://atvillustrated.com/files/logo.2013.yamaha.racing.blue_.jpg
I have included MM18III in the list. Just reply which model you guys are interested with.
Interested may be for all three, depending on price.
I am interested in all 3
BK-FA30S
MM18JR 70.2
Depending on price of course
Max
MM18JR(70.2) And MM18III
interested
Hi,
thanks,
depends on price of course,
Vostro.
hi
interested 1* #1,#2,#3
Thanks
MM18JR 70.2
longtime lurker here, interested in all 3
Interested in the FA30S if the price is right.
All three now pending price.
BK-FA30S
Greetings
I had interest in the BK-FA30S.
Lexel reviewed the light extensively, with a nice (thorough) review and tear-down! Thank you, Lexel
There are too many issues Niwalker needs to fix.
Niwalker does not want to disassemble-fix-reassemble? My guess, a group buy to get rid of them. More cost effective for them.
I want a light that's perfect right out of the box. Not a light that needs modded to make it what it was suppose to be
No thanks. Maybe after they fix and re-release.
Edit
I spoke with Lexel about the updates he plans and changed my mind.
I purchased elsewhere
>>>Searching for a specific flashlight? <<<
Ditto above, and lack of NW/WW is a deal breaker.
BK-FA30S with LED from BLF GT would be nice for me, too…
Light will be in stock form. If capable of DIY, you may want to consult Lexel for upgrade options.
im in for all three if well priced. I like Niwalker. they are well made
Interested in all three, but depending on price
"Keep On Luxing" © and "May The Lumin Be With You" © (by my very self)
Interested mostly in #2 and #3.
interest 1) BK-FA30S depending on price
Interested 3) MM18III, depending on price
BK-FA30S depending price
Thank
Group buy will start as earlier as next month at jaw-dropping price!!!
