Test/review of LG 18650 M36 3600mAh (Cyan)
15 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 10 min ago
DSC_5168
Official specifications:
  • None
LG%2018650%20M36%203600mAh%20(Cyan)-info
This must be a fairly new high capacity cell from LG.
DSC_5167
DSC_5169DSC_5170
DSC_5171
DSC_5172
LG%2018650%20M36%203600mAh%20(Cyan)-Capacity
The battery can deliver up to about 10A. The capacity do not match the rating, but then I do not discharge to 2.5V.
I am a bit surprised that the cells do not match perfectly, usual they do from the big brands.
LG%2018650%20M36%203600mAh%20(Cyan)-Temp-7.0
LG%2018650%20M36%203600mAh%20(Cyan)-Temp-10.0
LG%2018650%20M36%203600mAh%20(Cyan)-Temp-15.0
At 15A the battery gets too hot.
LG%2018650%20M36%203600mAh%20(Cyan)-CapacityTimeHours
LG%2018650%20M36%203600mAh%20(Cyan)-Energy
LG%2018650%20M36%203600mAh%20(Cyan)-PowerLoadTime
LG%2018650%20M36%203600mAh%20(Cyan)-TripCurrent
LG%2018650%20M36%203600mAh%20(Cyan)-Charge
Conclusion
The battery just about matches other 3500/3600mAh cells in capacity and performance
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
ChrisGarrett
ChrisGarrett's picture
Last seen: 6 hours 56 min ago
Thanks HKJ.
Seems to try hard to be the NCR-GA, but maybe isn’t quite on par.
I guess we need to see the street prices, to choose?
Chris
stephenk
stephenk's picture
Last seen: 1 week 6 days ago
Thanks for the review. Thing I’ll be sticking with GAs!
will34
will34's picture
Last seen: 1 hour 48 min ago
Thanks for the review!
Is this the new LG F1?
Barkuti
Barkuti's picture
Last seen: 48 min 46 sec ago
Barely any better than the LG 18650 MJ1 “3500”, yet they keep inflating the magic number. Is the “3600mAh” figure an actual datasheet capacity claim? No way this cell delivers that down to 2.5V even at 0.2C rate. And neither the NCR18650GA nor the Samsung INR18650-35E are much better.
This is a 3200mAh minimum capacity class cell for up to 3C rate.
Cheers Party
Sofirn C8T and C8F reviews of mine
PMme for a tip Wink thanks
ChrisGarrett
Cheers Party
I expect it from the Chinese brands, but not LG.
Oh well, for 99% of the lights out there, this will ‘probably’ be a sufficient cell, especially if they’re closer to $5 than they are to $8.
Chris
Speed4goal
Anyone know LG date codes? Seems like the cells are from 2 separate batches. I would expect them to match a little better though. These didn’t overheat either at 10amps like the mj1 and last a good bit longer at 15 amps as well before overheating. There are slight improvements. I would go with whatever cell is cheaper.
I use both mj1 and ga. I like GA for lights that need button tops they usually make contact. Or I remove the little plastic spacers. But in my use I’ve noticed the mj1s hold there capacity for more cycles then the GA cells do. But I use a lot of cells. At least 12 to 20 cells daily occasionally 40 cells charged a day
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Niko
Have you tested blue LG 3600?
HydrAxx
HydrAxx's picture
Last seen: 6 hours 38 min ago
Because for you, the LG M36 tested in this subject are what color? Lol, Cyan is a kind of blue.
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
Niko
New 3600 is dark blue colour
Barkuti
Barkuti's picture
According to this datasheet from NKON, the standard discharge specification (point 2.7) for this cell is 0.2C at 670mA down to 2.5V. This is ≈3350mAh typical down to 2.5V in a 5 hour long discharge. ⚆ _ ⚆
Cheers Party
HydrAxx
HydrAxx's picture
Do you have at least one picture to prove what you’re doing?
Because, I have never seen or heard of that. For my part I ordered 5 units of LG M36 from Vapcell and another 4 units from NKON.NL a little over a month ago and they are all Cyan. And anyway, if the M36 have changed color wrap I doubt that their performance has changed greatly whether it is at capacity, discharges or temperatures.
Niko
Enderman
Enderman's picture
Last seen: 7 min 1 sec ago
Niko wrote:
Seems different colour:
https://eu.nkon.nl/rechargeable/18650-size/lg-inr18650m36-3600mah-10a.ht...
Different cameras and lighting can change what colours look like.
HydrAxx
HydrAxx's picture
Exactly, it’s a question of lighting and model cameras used, more in my LG M36 reviews, the ones I ordered from NKON.NL moreover have exactly the same batch number (Q250I073A7) that on your photo example (taken on the site of NKON.NL at the same time it is rather logical) and I can confirm to you that they are cyan as HKJ had previously described in his test, so there is no new versions or revisions, in addition if they wanted to change colors due to changes in versions or revisions, they would not have taken a blue because it is too close to the cyan, for example the LG M26 has been Revised and changed color by changing revisions, they went from purple to gray, which makes more sense to highlight any change on a cell model.
