ENDED
101 posts / 0 new
freeme
freeme's picture
Last seen: 1 day 19 hours ago
ENDED
ENDED
©freemex1thedeals.com
Edited by: freeme on 05/09/2019 - 22:35
The Burgh
The Burgh's picture
Last seen: 20 hours 32 min ago
Where? How?
There will always be more darkness than I have lights.
Newlumen
Newlumen's picture
Last seen: 2 weeks 1 day ago
Same,, where is the link for the lazy people like me?
weklund
weklund's picture
Last seen: 4 weeks 1 day ago
Yes … purchase info please.
... Happy Landings ...
atbglenn
atbglenn's picture
Last seen: 6 months 4 weeks ago
I hope the 6000mAh rating is close to true. If so, I’m very interested.
Boycott Nike
RobertB
RobertB's picture
Last seen: 2 hours 31 min ago
I’d be really surprised if those were 20A continuous discharge like it says on the label.
patmurris
patmurris's picture
Last seen: 2 days 21 hours ago
hIKARInoob
hIKARInoob's picture
Last seen: 5 min 50 sec ago
Barkuti
Barkuti's picture
Last seen: 6 hours 59 min ago
Honestly, there's no standard yardstick for label/wrap specifications, and it is anyway wise not to blindly believe in them.
Bench test results I'll wait for.
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Agro
Agro's picture
Last seen: 31 min 56 sec ago
When can we get some independent tests? I really wonder if it’s the same cell as Shockli which was measured >5900 mAh at low currents…
silicoon
silicoon's picture
https://www.aliexpress.com/item/2-pcs-Original-KEEPPOWER-IMR26650-6000mah-E-CIG-Li-ion-rechargeable-battery-30A-discharge-high-drain/32850787447.html?spm=a2g0s.8937460.0.0.ssos2j
https://www.aliexpress.com/item/2-Pcs-Original-KeepPower-6000mAh-26650-P...
mortuus
mortuus's picture
Last seen: 35 min 8 sec ago
...where Frugal meets with Flashlight!
patmurris
patmurris's picture
mortuus wrote:
https://eu.nkon.nl/rechargeable/26650/kp-imr26650-6000.html
https://eu.nkon.nl/rechargeable/26650/kp-26650-6000.html
Amazing price at NKON – almost half of other vendors! Thumbs Up
I’ll probably get a couple, just because. Facepalm
Phlogiston
Phlogiston's picture
Last seen: 11 hours 29 min ago
Thanks all for flagging these up and providing links.
I’ve just ordered four of the protected version from NKON Smile I’ve also added them to HKJ’s review request thread – it might save him a little money if he was planning to test them anyway:
http://budgetlightforum.com/comment/1274094#comment-1274094
firedome
Last seen: 2 months 1 day ago
Any BLF review of cells?
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
ZoomieFan
ZoomieFan's picture
Last seen: 8 min 1 sec ago
Can’t find any test of the new one, but there are several of the older ones. They score good on capacity but less on drain (10A).
http://lygte-info.dk/review/batteries2012/Common26650comparator.php
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88, LiitoKala: 3x100 4/5, 2x202 4/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5.
Waiting for: (DQG Tiny) 21700 EDCs. Xtar powerbank that (also) takes 20700, 21700, 26650
mortuus
mortuus's picture
they should work in convoy l6 right? Hard to tell if they are flat tops or not.
patmurris
patmurris's picture
They look to be ‘raised top’ and may make contact in serial, but if they don’t a small magnet between them should do.
I ordered two unprotected.
Agro
Agro's picture
IF this is PLB 55A cell then you can get the unprotected variant for less from Shockli.
ZoomieFan
ZoomieFan's picture
Franz
Last seen: 1 week 1 day ago
A liitokala successor?
patmurris
patmurris's picture
That’s with the default test setting of 500mA. Considering the Opus is known to over estimate capacity it would put those cells at about 5700/5800mAh i’d guess.
I can confirm they work in serial.
Agro
Agro's picture
HKJ got 5841 mAh down to 2.8V from Shockli 5500 mAh. You see more down to 2.9V (that’s what I see here ). So it may actually be a different cell.
patmurris
patmurris's picture
I just did a quick ceiling bounce test against a few other 26650 cells i have around, using a direct drive light, and i cant measure much gain compared to a Liitokala 50A. I was hoping for a little bump… Sad
Phlogiston
I bought four of the protected version from NKON; all four arrived in good condition at 3.86V. Haven’t tested them yet, but there’s a Convoy BD01 due in soon Smile
The protected version is flat top, and it’s practically dead flat, so I doubt they’d make a reliable connection in series. All of my stuff is single cell, though, so I can’t try it and report with certainty.
mortuus
mortuus's picture
are they raised a bit or flat tops the protected?
Phlogiston
This is the version I bought. The photo shows the flat top:
mortuus
mortuus's picture
well that photo doesnt show that great in that angle.. thats why i asked :/ its weird because the 5200mahs are raised so these arent then? as i would use them in convoy l6 they cant be flat…
Phlogiston
Just made a rather irritating discovery with the protected 6000mAh cells: they are very wide. None of my four will go into my Convoy BD06, yet the protected 5200mAh version fits and has enough space to rattle.
Specs:
Keeppower 5200mAh protected 26650:
26.4mm × 69.5mm
Keeppower 6000mAh protected 26650:
26.8mm × 69.0mm
I was aware of the sizes before I ordered, but I’m having trouble figuring out how 0.4mm is going to make that much of a difference. However, it’s going to be a few days before I can get my hands on my digital caliper and check the measurements for myself.
Fortunately, the 6000mAh cells fit my Convoy X3, so I don’t have to send them back. I’ll just order a couple more 5200mAh cells for the BD06. I hope the BD01 I have coming in has enough clearance for the 6000mAh cells, though.
Edit: the 6000mAh cells don’t fit my BD01, either, but the 5200mAh ones are fine. I’m definitely going to need some more 5200mAh cells!
Barkuti
Barkuti's picture
This is an expensive niche product, whereas Lii-50/INR26650-50A are for sale nearly everywhere online with a price the Lord likes. So, no way.
Also, its capacity statement is probably a sort of lie. Lots of battery rewrappers and even battery manufacturers lie about this with figures you may not see even following their particular datasheet testing methods. Seems a lot of people blindly love in lies, just not me.
Cheers Party
Originally posted on Tue, 02/13/2018 - 19:37. Edited for correctness. Smile
djozz
djozz's picture
Last seen: 46 min 13 sec ago
This one came from nkon.nl
