[The Lite Review]: FiTorch P30Z Review (Zoomie)
27 posts / 0 new
mcorp
Last seen: 1 year 3 months ago
Preface
The original review can be found on TLR's website: Click Here
For quite a few of us, one of the first few flashlight ever purchased is probably a zoomie-style light or even a Maglite focus-able light.
This zoomie light brings back much nostalgia and let's see how it fare as we put it through the TLR's review process!
Packaging & First Impressions
This is what the light will come with as shown below.
  • Packaging looks rather similar to Fenix's style of packaging.
  • The threads and o-rings were overly lubricated (it is our first production light that ever had this).  Threads were smooth and clean (no gritty feeling).
  • The zoomable head was well-lubricated and it is easy to switch from flood to spot and vice versa.
  • The tail switch can be easily accessed to activate the light and require little force to activate.
  • The clip has sufficient tension to ensure that the light will stay clipped to any material to prevent the light from falling out.
  • Attachment of the light to a baseball cap for hands-free usage is not possible as the clip is not reversible.
  • Anodizing of the light is uniform without any missing specs.
  • The provided lanyard is able to support the full weight of the light and should hold up to the test of time.
  • Holster provided is of decent quality and should withstand day-to-day abuse without issue.
  • Battery compartment holds a KeepPower 18650 3400mAh battery with sufficient room for a slightly thicker battery width. 18650 3500mAh batteries should be able to fit without issue as well.
Front:
Back:
Sides:
Top:
Box Contents:
Quick Overview (Manufacturer Specifications)
  • Body Material: Black HAIII Aluminium
  • LED: XP-L
  • Battery Format:  1 x 18650 or 2 x CR123A ONLY
  • Output & Runtime (with SANYO 18650 3500mAh battery):
    • Low (30 lumens / 120h)
    • Mid (300 lumens / 3h 48min)
    • High (700 lumens / 2h 9min)
  • Max Beam Distance: 190m
  • Beam intensity: 11,300cd
  • Waterproofness: IPX-8 Standard (2m)
  • Impact Resistance: 2m
  • Dimension: 129mm (length) x 34.6mm (head diameter)
  • Weight: 124.6g (excluding batteries)
  • Accessories Included:
    • 1*Spare O-rings
    • 1*Spare Rubber Switch Boot
    • 1*Lanyard
    • 1*Holster
  • MSRP: ~$51
UI (User Interface)
UI for this light is perfect for Every Day Carry (EDC) as it is simple and straightforward to use.
Switching ON and OFF is done by the tail forward clicky (mechanical) switch on the light, so momentary activation is possible.
From OFF:
  • 1/2 Press - Mode change per every press (light cycles through HIGH, MID, LOW -> HIGH, MID, LOW).
  • 2 x 1/2 Press - Direct access to STROBE; 2 Click again for SOS or 1 Click to switch OFF.
  • 1 Click  - Switch ON to last brightness level used (last mode memory).
  • 2 Click - Direct access to STROBE; 2 Click again for SOS or 1 Click to switch OFF.
From ON:
  • 1 Click - Light will switch OFF.
  • 2 Click - Mode change per every press (light cycles through HIGH, MID, LOW -> HIGH, MID, LOW).
Mode memory will remember almost instantaneously whichever non-blinky mode (Strobe and SOS are not memorized) the light is in.
If the above 1/2 presses mode switching from OFF are done too quickly, the light would jump straight into STROBE instead of the next mode level.
Zoomable Function:
  • Rotate Head Clockwise: Spot (Pics below)
  • Rotate Head Anti-clockwise: Flood (Pics below)
Form Factor
For flashlights that are intended to use on a daily basis (EDC) and for possibly a long period of time, form factor is extremely important.
This light feels well balanced in a medium sized hand (not head/tail-heavy). Switching between overhand and underhand holding method is easy with its form factor. The knurling on the light enables the light to be sufficiently "grippy", even with wet hands/gloves.
It fitting in the holster snugly as well as being able to tail-stand perfectly (even with the lanyard attached) without the slightest wobble is very much desired.
Charging Process (Optional Accessory)
The light was sent with a FiTorch 2600mAh Micro-USB chargeable 18650 without the Micro-USB cable.
Using an Olight branded Micro-USB cable, the battery was charging at ~0.71A.
The RED indicator depicts charging in progress and GREEN indicator depicts charging has completed.
Beam Style/Beamshots
For this light, the spill, corona and hotspot is somewhat familiar to zoomies owing to the TIR(Total Internal Reflection) optical lens used. Hence, the beam produced can be floody for very close-up usage (flood mode) and still be sufficiently “throwy” (spot mode) for recognising items in the near to mid-range distance.
The above beam profiles are rough interpretations of what is seen when white wall hunting.
In the flood mode, the beam has is simple a large circular wall of light with no discernment between hotspot and corona. However, in spot mode, the beam has a distinct circular hotspot with a slight corona and a fairly wide (perfectly round) spill.  There are some slight rings in the beam (in flood & spot mode) when whitewall hunting but not visible in real world usage.
All of the beamshots taken below are done so with the following camera settings.
For Flood: (LOW: 1.3, F3.5, ISO100, Daylight WB and MID & HIGH: 1/2, F3.5, ISO100, Daylight WB).
For Spot: (LOW, MID & HIGH: 1/3, F3.5, ISO100, Daylight WB).
Some pictures have been adjusted slightly to depict as close as to what is seen in real life. The distance of the light from the door is 4.6m.
FLOOD Mode
Control shot:
LOW (30 lumens):
MID (300 lumens):
HIGH (750 lumens):
SPOT Mode
Control shot:
LOW (30 lumens):
MID (300 lumens):
HIGH (750 lumens):
Mode (Output) Spacing
Mode spacing appears to be somewhat progressively brighter to the eye but the MID and HIGH modes are visually too similar to each other to be able to know which mode one is currently in. With that in mind, TLR tend to view mode spacing as battery life indicators (amount of runtime left) rather than the specific output (lumens).
It would be nice if FiTorch would incorporate a lower MID level in the region of 150 lumens and this would give a more significant bump in runtime on the MID level as well. In addition, a MOONLIGHT mode (sub-lumen or 1 lumen) for those bedtime runs or during which having 30 lumens for LOW is way too bright for the night-adjusted eyes.
However, in the flood mode, the 30 lumen "low"  is more acceptable as an actual LOW mode since this light is diffused out into a wall of light as mentioned earlier.
Tint & CRI
FiTorch did not disclose the tint (color temperature) and/or the CRI (Color Rendering Index) for the LEDs used in their light. For this light, a guesstimate would be in the 6500K and 60CRI ballpark.
There are tint shifts throughout the beam profile.
In flood mode, the beam from the centre to near the spill edge is cool white with a slight blueish-purple tint whilst the spill edge possesses is white with slight yellowish tint.
In spot mode, the hotspot is almost pure white with the corona being white with slight yellow-ish green tint and the spill having a slight blueish-purple tint.
This is however, not as noticeable in real life.
Waterproofness
The light was subjected to warm water submersion, followed by cold water submersion and left under room temperature running water tap whilst running on Turbo (in spot & flood mode).
No signs of water intrusion in the head, switch or body was seen.
Lockout Capability
No electronic lockout but mechanical lockout is possible when needed, like during transportation in a bag.
A quarter turn (anti-clockwise) of the head or tail portion of the light will enable mechanical lockout.
 Summary
To sum up, we believe that the most important part of any review is if given the chance to purchase the same light for our own EDC or to gift to our loved ones out from one's pocket (wallet), would we still do it?
For this light, it is a possible YES if the mode spacing & tint shift is not an issue for your usage.
The zoomable setup used by FiTorch is rather ingenious, enabling both flood and spot whilst still retaining waterproofness; and it seems somewhat similar to the type used in Fenix's FD series. The TIR optical lens's Achilles heel is that the spot beam produced will not be focused to a point whereby the LED's die image can be seen like with true aspheric lights - to increase the intensity candela.
As nostalgic as this light is, we look forward to the day that FiTorch incorporates a lower MID mode at least to make the light much more usable. In addition, using a dedomed LED (XP-L HI) might help to improve the tint shift issues and improving candela in the process.
Since this light would most probably be the main EDC, it is recommended to carry a backup keychain light as well.
May we suggest the Prometheus Lights Beta QRv2 we recently reviewed - high CRI and excellent lower modes.
As with all gears, two is one and one is none.
Stay safe,
The Lite Review
Disclaimer: Light & battery was provided for by FiTorch (manufacturer) for this review. No other compensation was provided.
The Lite Review (click for my Review website!)
Edited by: mcorp on 01/29/2018 - 01:53
mcorp
For those who are considering this light, here is the link to my website for where & how to get a sweet discount.
Where to Buy Links
kramer5150
kramer5150's picture
Last seen: 2 weeks 1 day ago
Nice review… thanks.
How accessible is the driver?
Does zooming in and out change the total OTF Lumens? (like it does on traditional aspheric zooms)
I am thinking about this light as a mod host.
thanks
beam0
beam0's picture
thanks
I just ordered one, I’ll post here when I receive and evaluate it.
I ordered the Litesam one linked in his website at the bottom of the review, under “Where to buy Links”, it shows a Banggood link for the FiTorch P30Z and the amazon link, where it’s noted: (“Marketed under “Litesam” for their Amazon market”) identifying it as being the same light as the FiTorch P30Z in the review.
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
firedome
Thanks for the review! Big Smile
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
beam0
beam0's picture
thanks
I received the light today and was able to spend a short time with it tonight. (the Litesam/Amazon version)
So far I cannot access the driver, can’t get the head unscrewed, it must be glued tight.
Zooming in and out does change the OTF Lumens, it’s brighter when fully zoomed in to spot.
The light I received may be defective though because there’s the really BIG issue (and it’s whats causing the change in output)
There is a HORRIBLE black spot in the beam. (I guess it’s what’s referred to as a “Donut hole”) It is not present when fully zoomed in to spot, it disappears slightly before reaching full spot zoom. and it is not really “visible” when fully zoomed out to flood…but it’s there…
When you zoom out to flood the black spot expands, progressively enlarging until it pretty much becomes as large as the whole beam, at that point you can’t really see it, but it is still there and “darkening” the entire beam, causing the brightness to be less than when zoomed in to spot.
An expanding dark center may be an inherent characteristic of the aspeheric lens zoomies as well, but I’ve personally never seen one this bad. I have a supfire F5 and you cannot notice any dark spot unless you really look hard for it, so it doesn’t really detract from normal use like this FiTorch/Litesam. If the problem is not a defect and a characteristic of this light and lens system, it should have been mentioned in the review.
In the review the beam shots show full spot and full flood, but no beam shot of any in-between position, where the black spot is blatantly visible. It’s also visible (and annoying) in real use outdoors, not just on a white wall)
Here’s the missing beam shots:
The fully zoomed photos (in and out) in the review are the same as what I’m seeing, (no black hole) so I didn’t post those.
It’s a pity because otherwise the light is screaming quality… excellent knurling, excellent machining fit and finish, nothing sloppy, zoom threads smooth and tight, squared threads that came well lubed, great anodizing etc etc. Absolutely nothing else to complain about. I’ve sent a message with photos to FiTorch/Litesam asking if this is normal or a defect.
beam0
beam0's picture
mcorp…does your light have the donut hole as shown and described in my post above? (not at fully zoomed in/out but everywhere in-between)
beam0
beam0's picture
Also the light has PWM.
I can’t see it with my eyes (I’m not sensitive to it) but my cell phone camera picked it up…
Enlarged photos:
beam0
beam0's picture
Also having mode changing issues, it’s wonky, does what it wants when it wants.
Pretty much moot though if the donut hole is normal.
robo819
robo819's picture
Last seen: 1 day 15 hours ago
beam0 wrote:
Also having mode changing issues, it’s wonky, does what it wants when it wants. Pretty much moot though if the donut hole is normal.
From what I have seen with the TIR optic in the zoomies , the dark spot is almost always there in the mid focus range , although much more noticeable in some than others. Usually when fully focused or fully zoomed out (flood) you will have a crisp clear beam and edge though with the TIR.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
beam0
beam0's picture
Thanks for the info.
Also when zoomed out to flood the outer edge of the beam is not crisp, it’s not a well defined edge as it is on my other (Aspheric lens) zoomies. Not really a problem but I wanted to report this, since it’s not really as you described for TIR.
Do you know of any video reviews on a TIR optic zoomie where I can see dark spot? I think this one is way worse that what it should be.
EDIT, (see next post)
beam0
beam0's picture
OK so I found a review on YT for this (Fitorch P30Z version) the video is made by the manufacture:
https://www.youtube.com/watch?v=vVN9E2W31_I
In the Fitorch video I really don’t see the dark spot much, but he is zooming from flood to throw extremely fast, and never stops anywhere in between, (probably to hide the dark spot in the video)
I also found a Litesam P11Z review. I found this before but for some reason it was showing “User account deleted” Maybe I was looking at something else, but it’s working now.
It’s by Charles BridgTec not by the manufacture, however he said the manufacture provided their entire line of their lights to him for review: https://www.youtube.com/watch?v=Hosr13vRoSY
In the Litesam video the dark spot is visible, although it could be slightly less than in my sample it’s pretty close to what I’m seeing, but in the indoor “table top” portion of the video, again the reviewer does not stop the zoom anywhere in between full flood and full throw.
In the outdoor portion of the video, after showing full throw and full flood, he says he will now show it partially zoomed and when he does that you can see the dark spot for a second or two before he quickly zooms back to full.
He appears to have been surprised by the dark spot because he doesn’t show it much and seems to quickly avoid the subject, with only a quick mention of it before he quickly zooms it back to full. So he ends up avoiding much footage of any partial zoom.
Probably because if he beamed it around half zoomed with the dark spot showing it would look like crap.
Now I’d really like to know if the dark spot is this bad in the Fitorch version.
beam0
beam0's picture
About the mode changing issue:
This light has a forward switch with momentary, the user manual does not show mode changes from OFF by momentary half presses, and that is not shown in the Fitorch video either.
In this review mcorp wrote: “From OFF: 1/2 Press – Mode change per every press (light cycles through HIGH, MID, LOW -> HIGH, MID, LOW)”
Also in the Litesam video by Charles Bridge Tec, after going over the modes he quickly mentions being able to do mode changes from OFF with momentary half presses, but as he’s doing that it doesn’t appear to be working that way from what I could see.
With my light I’ve found now the mode changes are consistent going through the modes with double-full-clicks from ON, however I cannot get it to do mode changes from OFF with the momentary function (half-pressses) it just stays in the same mode every half press no matter what speed I try half-presses, (although with a rapid double-half-press it does enter strobe).
Now I’m wondering if it’s really suppose to change modes with half-presses from OFF?
Probably good it doesn’t, because if it did that would defeat the use of momentary for signalling purposes like sending flash-code.
robo819
robo819's picture
The only one I had handy at the moment is a little Coast HX5 with the TIR optic in it.
It has the dark spot all through the middle of adjustment also , but does get a well defined beam at or near the full flood or full focus.
Never really realized there is not a white wall in my house as everything is paneling or wall papered with color.
I took 3 shots shining on the refrigerator door at about 2 1/2 to 3 feet with the light though to show what it looks like.
Flood
Mid-Focus
Focused
beam0
beam0's picture
Thanks for the pics Robo, that coast doesn’t look as bad as this FiTorch does, but the coast is a small light, AA size I think.
I’d like to try one of those, been wanting the HP1 that I think the HX5 replaced, it comes up at half price every so often on Amazon but I keep missing it when it does.
I think I’m going to try the Wowtac A3S next, if it ever becomes available again (they said it will but hasn’t yet)
robo819
robo819's picture
beam0 wrote:
Thanks for the pics Robo, that coast doesn’t look as bad as this FiTorch does, but the coast is a small light, AA size I think. I’d like to try one of those, been wanting the HP1 that I think the HX5 replaced, it comes up at half price every so often on Amazon but I keep missing it when it does.
I don’t know how much they are on Amazon but , I picked up my little HX5 at Walmart for like $16.78 or something like that.
The HX5 will run on Alkaline , NiMH or 14500 with the stock driver. I think it makes about 310 Lumens with the 14500 in stock form. Of course as with 90% of my lights , I modded the little coast with a FET driver and a dedomed XM-L2 U4 OD emitter and it makes 770 lumens in Turbo now.
Nana from Wowtac said they will try to get the A3S back on the Amazon site after the spring festival holidays , which should be ending just any day now.
beam0
beam0's picture
$15.39 on amazon, interesting I don’t recall seeing those at WM, I’ll have to keep an eye out for them. Sounds like a nice mod, and it doesn’t look like a very bad donuts hole on it, thanks for sharing and the mod idea!
beam0
beam0's picture
I received an answer from the manufacture today about the dark spot:
Message from 3rd party seller:
Hello, After cheking these attached photos, I would like to let you know that it’s normal…
Litesam
Not really what I wanted to hear Sad
Muto
Last seen: 4 hours 57 min ago
Well it kind of reminds me of the Solar Eclipse, so maybe they should market it that way Smile
But seriously it looks like crap and the fact that someone in engineering said, “OH well that’s good enough” is troubling.
Thanks for the heads up, pity because it does really look well built.
Will try one of their other models as soon as the reviews are in for them.
Thanks!
Keith
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Big Sky Country
No matter where you go, there you are.
beam0
beam0's picture
So after hearing back from Litesam/FiTorch that the dark spot is normal, I’ve given this some deep thought today.
I thought….Why/how could they design/produce/sell a flashlight with such an awful flaw?
I’ve never had a zoom light with this much of a dark center spot, I can’t say I even ever really noticed a dark spot in a zoomie, at least not to the point where I’d complain about it. Even my cheapo ones don’t have it like this, but my other zoomies are aspheric this is my first one with a TIR lens type.
I also thought…Why did none of the reviewers mention or complain about the dark spot?
This review, 5 reviews on amazon, 5 for the FiTorch on Banggood, and one on youtube, and not one complaint about the dark spot that I thought was either a defect or a flawed design. After all it was the very first thing I noticed soon as I adjusted the zoom, so why no one even mentioned it? Maybe none of them have ever used a regular (aspheric) zoomie before?
Then the obvious dawned on me. Apparently the zooming adjustment on this light (and maybe all zoomies?) is only intended to be used in two positions, either fully zoomed in, or fully zoomed out.
It’s the only thing that makes sense. And I had to ask myself: do I really use any of the in-between positions? Well yes maybe sometimes but most of the time probably not. Can I live with the 2-positions only? Well probably yes. You have flood and you have throw, so you have the two modes you will use the most, probably 95% of the time.
So I’m no longer as upset about the light as I was at first, now that I know it’s limitations and feel I can live with them, at least I’ll try it a while and see. I think I was just somewhat “shocked” when I saw that dark hole, because I’d never noticed anything like that in a zooming light before. One thing I have yet to understand though, if the aspheric type zoomies don’t have this donut hole problem then why even bother with this TIR lens set-up? What is the advantage to it? I don’t see what that is yet.
mcorp
First of all, thank you for supporting our website through the Amazon purchase!
In most cases focusing/zoom-able aspherics tend to lack a better water resistance as compared to the TIR lens setup. This might be the reason why FiTorch/Litesam decided with the TIR lens setup. Side note: another manufacturer that used this first is the Fenix FD series. Whilst gaining better water resistance, the drawback is the loss of throw (in SPOT mode) when compared to a properly focused zoomie aspheric.
The in-between photos of “FLOOD” and “SPOT” modes are as what you had captured. Those beamshots were not captured as those did not provide useful beam profiles for real life usage; as compared to a zoomie aspheric whereby it beam profile is usable throughout the zooming process (focused & flood).
Half presses to switch modes from OFF must be done slightly slower than the usual 2 half presses which would activate STROBE instead. The mode switching is somewhat similar to a McGizmo 3S light engine.
mcorp
Thank you all for the kind words!
If I have missed your comments or questions, please let me know here, via PM or on our TLR website.
beam0
beam0's picture
Thanks mcorp for the reply, info and further explanation, now it’s clearer to me:
  • TIR zoomie: Spot and Flood only
  • Aspheric zoomie: Usable throughout the zooming process
As I said I’m quite happy with this flashlight now that I understand it’s limitations. It’s a very well built flashlight. I also understand now why there was no need to include the middle beamshots. It would have been better if the limitations of a TIR zoomie were mentioned in the review, but I can’t expect the reviewer to educate on the principles of different types of flashlight design, so no worries. Smile
Also thanks for the info on mode changing from OFF with momentary presses, I was actually able to get that working correctly last night after playing around with it a while. Thumbs Up There is a learning curve for that as you have to press/release the half-presses just right. It’s great that you can still use easily the momentary feature for signalling purposes without changing modes.
kramer5150
Awesome thanks gents!!
Bummers about the severe doughnut hole and lost emitter lumens not making it OTF. As a mod host I had high hopes. Seeing those pics brings me way back to the days of Mag incan ROP (rise of the pelican) mods and hot rodding PR lamps. Its 2018 we really shouldn’t have doughnut hole optics by todays standards. But it goes to show just how difficult it is to make a compact optic design that floods/zooms without obstructing emitter lumens somewhere along the way. The Lenser / fraen partnership optics IIRC achieve this.
beam0
beam0's picture
I also want to add here that Litesam (FiTorch?) is not really confirming (or more likely not admitting) that the Litesam E11Z version is the same internally as the FiTorch P30Z. I asked that question, and this was their response:
“The function is similar to Fitorch P30Z”.
Litesam
But it’s a Chinese company and I assume the response came from someone in China so it may be wording lost in the translation and by “similar” they meant “same”. A simple “Yes” would have eliminated any uncertainty.
The reviewer (mcorp) has said it’s the same, plus it’s size, shape and all other specs are the same, the only thing that appears different is the knurling and the name. So I see no reason for anything to be different inside as far as the host/optics are concerned. And mcorp already confirmed the same donut hole is also present in the FiTorch.
beam0
beam0's picture
I’m still learning the pros and cons between TIR vs Aspheric. mcorp has provided some explanation of the difference: “Better water resistance……. at the cost of loss of throw (in SPOT mode)”
I believe another charistic is a round spot beam when fully zoomed in (instead of a square one showing the die image) but I think that can be achieved in an aspheric by stopping the travel slightly short of full (Wowtac A3S for example) He also mentioned another brand that used this setup was Fenix FD series, I’m wondering is this the same as what Led Lenser employs?
In another thread, in a discussion of Led Lenser clones someone posted this description of the beam for (genuine) Led Lenser optics :
“A nice round spot with no spill and almost perfectly uniform wide-angle spill that the real TIR does.”
http://budgetlightforum.com/comment/1284348#comment-1284348
However I’m not sure if Led Lenser is using something slightly different than these FiTorch and Fenix TIR.
For the FiTorch I have to wonder if their use of this TIR was worth it compared to using Aspheric.
What flashlights have the Lenser / fraen partnership optic? Is that what the Led Lenser uses? I’ve been looking at some Led Lensers, the MT10 and MT14.;
Those and the and MT18 appear to be the only models they make that run on popular size Li-ions (18650 / 26650)
beam0
beam0's picture
Yes I’m not sure it’s possible.
An alternative design that essentially gives the same usability and the FiTorch with it’s donut hole (either flood or throw only) is the setup in the upcoming Astrolux MF03
They need to improve upon that design by employing it in smaller size lights, I have a budget light with a similar concept that uses a COB LED ring surrounding a reflectored LED, it’s quite handy.
