I have a Skilhunt H02 headlight torch which has been my most used torch, sometimes 8 hours a day for weeks on end.
However as of yesterday I was using it and it started to flicker then died, I opened it up and all connections are ok ,it’s just dead, I took it apart tried a battery straight to the LED and it lights up ok, I tried shorting power button in case it was that, it wasn’t so that only leaves the driver. After measuring it it is an odd sized 22mm with e-switch, wheres a good place to get these in the UK Banggood and Gearbest don’t list anything this size and Mountain Electronics is quite expensive to ship to UK.
It had 4 well spaced modes so I would like something similar if possible and not too expensive.
I have ordered the Nitecore HC33 from fins thread as a replacement but would like to get this going again if possible as I really like the NW LED in it.
