"Optisolis"tm, Nichia starts with ultra-high CRI leds (mid-power currently)
77 posts / 0 new
djozz
djozz's picture
Last seen: 1 hour 5 min ago
To prevent the cyan dip, the leds feature an especially developed 420nm blue led, so shorter wavelength than normal white leds (450nm) and longer than Yuji uses for their VTC series (400nm). For most flashlight use, these midpower leds are too weak, but perhaps they come out with a high power version some day Smile
Here's what they write about it:
Ultra-High CRI White LED (Optisolis™)
Optisolis™ achieves Ultra-High CRI with a spectrum that demonstrates the closest match to that of the standard illuminant. Optisolis™ is optimized for the general lighting market and is accomplished by using Nichia’s own blue chip and phosphor technology.
Manufacturers can utilize Optisolis™ and trust in a spectrum where all colors are reproduced to the color seen under a standard light. (Figure 1) Also, color rendering index has been significantly improved compared with the current products for general lighting. (Figure 2) Most importantly, since UV emission is essentially non-existent in the spectrum, the degradation of irradiated materials can be reduced dramatically compared to that of other light sources containing UV emission, including other market available LEDs.
Target applications include Museum and Art Gallery Lighting, where the highest CRI is preferred, but UV radiation and light sources can be detrimental. Additional applications could include Color Evaluation(e.g. painting, printing), Commercial Lighting (e.g. retail, etc.) or anywhere Ultra-High CRI is desired.
Figure 1.
Example of spectrum (TS 25°C) *1
Figure 2.
Example of Color Rendering Index (n=1) *1
*1 The above values are from measured samples and are for reference purposes only, these values are not guaranteed.
Product Type
Size
LxWxH
(mm)
Chromaticity Coordinate
Typ(x,y)
Luminous Intensity
Typ(cd)
Luminous Flux
Typ(lm)
Ra
Min
R9
Min
Forward Voltage
VF(V)
Directivity
2θ ½
(degree)
IF
(mA)
x
y
Typ
Max
Optisolis
NF2W757G-F1 (Rfa00,Rfc00) N
3×3×0.65 White 0.3447 0.3553   23 95 85 2.9 3.3 120 65
Optisolis
NF2L757G-F1 (Rfe00,Rff00,Rfg00,Rfh00) N
3×3×0.65 Warm White 0.4338 0.4030   24.1 95 80 2.76 3.3 120 65
2 items totally
N=New Product   U=Under Development
*The photos might not exactly be the same as the original.
*Please refer to CIE 1931 chromaticity diagram.
*The 'Typ.' in the products page indicates typical value so that is not under guarantee.
Edited by: djozz on 02/01/2018 - 07:38
Phlogiston
Last seen: 13 hours 25 min ago
Cool. I’d be interested to see something like this in a 5mm through-hole package, like the ones Yuji used to sell.
clemence
clemence's picture
Last seen: 1 hour 6 min ago
I kept this since last month because Nichia told me not to leak it until they’re announced. Finally it’s official!
The only problem is they’re still low powered at 25 – 30 lumens/pc
I exchanged the 219D sample offerings with this new LED Big Smile
- Clemence
gchart
gchart's picture
Last seen: 4 hours 44 min ago
Interesting…
And, umm… Clemence? 219D? Care to elaborate?
Edit: sorry to thread jack. Just excited with all these new LEDs. Noticed the 219D listing though I haven’t digested it yet.
clemence
clemence's picture
gchart wrote:
Interesting…
Yes 219D newer version of 219C, I have no interest on it. The max CRI is currently only Ra8000
If you’re going for performance upgrade from 219C it’s better to use 319A R8000. Unless tighter beam is what you’re after.
- Clemence
gchart
gchart's picture
Thumbs Up roger that
Barkuti
Barkuti's picture
Last seen: 7 hours 26 min ago
Subscribed for now!
Surface mount leds with about half the lumens of run-of-the-mill 5730s. I recently had the pleasure of reflowing a 100-pack of them on an electric induction stove. Time consuming task…
Question with regards to these is footprint and boards' availability.
Cheers Smile
Sofirn C8T and C8F reviews of mine
PMme for a tip Wink thanks
AEDe
AEDe's picture
Last seen: 4 min 13 sec ago
clemence, why 25-30 lm? Datasheet say that 24lm it is for 65 mA, but maximum curent is 150-200mA without overdrive.
clemence
clemence's picture
Officially 25-30lumens, since this is BLF, well…150lumens should be doable
- Clemence
Agro
Last seen: 4 min 58 sec ago
If it can do 150 lm, it’s interesting.
For a quad-led headlamp you don’t need more than 100 lm/LED really.
clemence
clemence's picture
Sample delivery scheduled in 2018 February 14. Will be available via the store in 3000K and 5000K only. Have no idea about the binning and quantity.
- Clemence
djozz
djozz's picture
I feel another virence order coming..
Barkuti
Barkuti's picture
Maybe enough violet for violet stuff to shine, we'll see. I wonder how actually good are modern leds in this regard (remember this sort of violet we see on our displays really isn't violet).
Cheers
ma tumba
Last seen: 1 hour 33 sec ago
Will these fit the quad boards? I understand they are bigger than e21 but they are low power ones so gapless setup prrhaps?
clemence
clemence's picture
I think so too. But can’t give any suggestions until I tested them. Being a low power LED (away from BLF habit) any non DTP boards should serve it well. It’s
overall footprint is symmetrical unlike Yuji but the the anode-cathode pads aren’t.
- Clemence
clemence
clemence's picture
UPDATE 180214:
3000K and 5000K “full spectrum” Optisolis depart from JPN to ID. Happy valentine everybody!
- Clemence
djozz
djozz's picture
ma tumba
The optisolis spectrum begs for a UV bandpass filter. the rest of the spectrum is just BB without that dip at 480nm
leaftye
Last seen: 1 week 4 days ago
If heat output is low enough, you could design your own pcb and make a cob lantern out of it. It’d take an ungodly number of these led’s to get decent output and efficiency though. I’d want a thousand emitters, maybe a lot more, and there’s no way I’m reflowing that many emitters.
It seems unsuitable for light bulbs. Maybe it’d be okay for panel lights, and excellent for lighting film sets. Computer monitor backlighting may be a good application.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
The_Driver
The_Driver's picture
Last seen: 1 hour 59 min ago
- Clemence
This Graph doesn’t make sense to me. This new LED should have a lower color temperature. There is more red spectral content in relation to the blue peak compared to the other LEDs.
JaredM
JaredM's picture
Last seen: 15 hours 46 min ago
Any update on these Clemence?
clemence
clemence's picture
If nothing gets in the way, they should be available in May
- Clemence
djozz
djozz's picture
output test is in the make
clemence
clemence's picture
Packet to Maukka in the make too Wink
clemence
clemence's picture
Some more informations:
- Clemence
djozz
djozz's picture
clemence
clemence's picture
djozz wrote:
Output test is up: http://budgetlightforum.com/node/59478
Saw it already. Looks like you could increase the current a bit further
- Clemence
koef3
koef3's picture
Last seen: 1 day 4 hours ago
I'm curious how the Optisolis performs in my setup. Overall the performance and efficiency looks very nice, even better than expected.
Maybe they can beat the 260 lumens at more than 1.0 - 1.4 Amps... - could be a great replacement for my JAXMAN M8 Triple...
My LED tests: Cree SC5 based LEDs (WIP!)  ---  Nichia 319AT 83 CRI - Optisolis (3000/5000 K) - Lumileds Luxeon LXML-PWD9 - Luxeon MZ 5700 K (90 CRI, 3 V) - Luxeon V (CSP) 4000 K 70CRI - Luminus SST-40-W (+ dedomed) - Cree XP-L2 (+ High CRI variant) - XHP35 HI - XHP70.2 - CXA1304 COB - OSRAM OSLON Black Flat HWQP - SYNIOS DMLQ31.SGLE UW Q8WP - unknown 5050 LED ---- finished: JAXMAN M8 (Mini C8) HighCRI Triple
Schoki
Schoki's picture
Last seen: 21 hours 53 min ago
Looks like a good choice for small key chain lights.
And good test!
doubleone44
doubleone44's picture
So do these fit the quadtrix board? Else I might have to cut up a 5050 board like djozz did, but ofcourse that will give some insulation issues with DTP.
clemence
clemence's picture
No quadtrix board doesn’t fit. Another quad board for 757 series is still work in progress.
- Clemence
