Test/review of Vapcell INR18650 2600mAh (Yellow)
1 post / 0 new
HKJ
HKJ's picture
Last seen: 2 min 54 sec ago
DSC_5539
Official specifications:
  • Model: INR18650
  • Size: 18.3*65.2mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 2600mAh (0.2C discharge)
  • Min capacity: 2500mAh (0.2C discharge)
  • Weight: Max:48g
  • Internal resistance: Max:14mOhm
  • Standard Charge: 1500mA,CCCV 100mA cut-off
  • Charging Time: 2.5hours(standard charge)
  • Quick Charge Current: 3000mA
  • Max Continuous Discharge Current: 20000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
  • Storage: Temperature -5°C~35°C, Humidity
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
Vapcell%20INR18650%202600mAh%20(Yellow)-info
This is fairly high current batteries with acceptable capacity.
DSC_5534DSC_5535
DSC_5540DSC_5541
DSC_5542
DSC_5543
DSC_5544
Vapcell%20INR18650%202600mAh%20(Yellow)-Capacity
There is a small capacity difference between the two batteries, they do not like very high current discharge (30A)
Vapcell%20INR18650%202600mAh%20(Yellow)-Temp-10.0
Vapcell%20INR18650%202600mAh%20(Yellow)-Temp-15.0
Something went wrong with the A cell for this test, it was fully charged, but the discharge was skipped.
Vapcell%20INR18650%202600mAh%20(Yellow)-Temp-20.0
I wonder about the temperature difference, maybe I forgot to place the sensor on the B cell, but it must have been close.
Vapcell%20INR18650%202600mAh%20(Yellow)-CapacityTimeHours
Vapcell%20INR18650%202600mAh%20(Yellow)-Energy
Vapcell%20INR18650%202600mAh%20(Yellow)-PowerLoadTime
Vapcell%20INR18650%202600mAh%20(Yellow)-TripCurrent
Vapcell%20INR18650%202600mAh%20(Yellow)-Charge
Conclusion
The batteries handles 15A fine, but 20A is at the limit. Performance is as expected from a high current battery.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
