How many amps do most 14500 flashlights pull?
12 posts / 0 new
nquinn
Last seen: 2 weeks 19 hours ago
Looking to buy a 14500 battery, but it seems the most recommended Sanyo one really only handles 1A and below well.
I see some of the Windyfire and AW batteries (not sure where to buy AW) can do 6A+ though.
I have a little SF14 AA/14500 light.
What do most of these little 1xAA lights pull in amps when driving LED’s at turbo up to 600 lumens or so?
southland
southland's picture
Last seen: 13 hours 29 min ago
Purple Efest 650mah 14500 do 6.5 amps.
RobertB
RobertB's picture
Last seen: 35 min 20 sec ago
2nd the purple Efest. Great 14500
EasyB
Last seen: 24 min 33 sec ago
Something like 2-3A probably for your light in turbo.
moderator007
moderator007's picture
Last seen: 2 hours 7 min ago
600 lumens with a xpl-hi V3 or V2 would be around 1.5 amps. The Sanyo would handle this just fine lasting just a little longer than the Efest 650 (purple).
But any light with a higher current draw than 1.5a the Efest will start to dominate the higher you go. Lasting longer and having a higher discharge voltage (less voltage sag). The Efest is a great high current battery in the 14500 size.
If your light is using XP-G2 R5 led 600 lumen’s should be around 2600ma according to Djozz graph.
http://budgetlightforum.com/comment/416063#comment-416063
Your light would benefit from the Efest, higher lumen’s and lasting longer.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 4 hours 1 min ago
I would say on average if its a consumer flashlight like from a major brand about 1.5-2 amps max.
Then you can buy light like the BLF X5 which will do maybe 6amps on turbo.
My recommendation will be out of the ball park here but these Trustfires are good. They perform similiar to my AW 14500 cells.
https://www.fasttech.com/p/1450301
The trade of here is that a higher drain cells will have less capacity maybe only 150mah less but that is like 20% of overall capacity
d_t_a
Last seen: 12 hours 54 min ago
moderator007 wrote:
600 lumens with a xpl-hi V3 or V2 would be around 1.5 amps. The Sanyo would handle this just fine lasting just a little longer than the Efest 650 (purple). But any light with a higher current draw than 1.5a the Efest will start to dominate the higher you go. Lasting longer and having a higher discharge voltage (less voltage sag). The Efest is a great high current battery in the 14500 size. If your light is using XP-G2 R5 led 600 lumen’s should be around 2600ma according to Djozz graph. http://budgetlightforum.com/comment/416063#comment-416063 Your light would benefit from the Efest, higher lumen’s and lasting longer.
I have a question re lumens vs amps for the different kinds of Cree LEDs.
So XP-L Hi V3 @ 1.5A ~600 lumens
Where can I find the data for others, like XM-L2 (let’s assume the usual I see in specs are XM-L2 U2) or for XP-L HD V6?
Are the approximate lumens to amps almost the same? (other than some LED emitters can be driven to higher currents)
crz6662
crz6662's picture
Last seen: 4 days 23 hours ago
Just purchased 4 @ $2.75 US each. Luv those Efest. 18650 and 18350’s on hand.
Yokiamy
Yokiamy's picture
Last seen: 18 min 53 sec ago
TexasAce has done several tests, you might want to take a look at his tests
http://budgetlightforum.com/node/52183
  BLF
nquinn
Thoughts on the efest vs. the windyfire here?
http://www.mtnelectronics.com/index.php?route=product/product&product_id...
600mAh capacity
6.5A continuous discharge
9.75A pulse discharge
$2.99
https://www.illumn.com/14500-efest-imr14500-v2-650mah-high-discharge-but...
650mAh capacity
8.75A pulse discharge
$3.99
Both look quite similar, but I’d need to compare their curves to see how they each hold up at different powers.
Dutcheee
Last seen: 1 day 1 hour ago
I just have some (protected) keeppowers in from banggood. In my unmodded tool AA they pull 1,5A.
They test to 930mAh in my Opus @500mA discharge.
cclight
Last seen: 1 week 2 days ago
nquinn: look at HKJ’s tests at http://lygte-info.dk/review/batteries2012/CommonSmallcomparator.php. They show that the windyfire is somewhat better for high currents. I’m quite satisfied with them.
