Test/review of PKCell ICR10440 350mAh (Blue)
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 16 min ago
DSC_5368
Official specifications:
  • Brand: PKCELL
  • Model Number:10440 3.7V Lithium Li-ion Rechargeable Battery
  • Type: Li-Ion
  • Nominal Voltage: 3.7V
  • Size: 10440
  • Nominal Capacity: 350mah
  • Model: icr10440 350
  • Dimension: 10.2mm*44.02mm
  • Nominal capacity: 350mAh(NOT HIGH DRAIN)
  • Nominal voltage: 3.7V
  • Shape: cylinder
  • Color: blue
  • Top: Flat top
  • Usage: e-cigarette
  • Weight: 15g
PKCell%20ICR10440%20350mAh%20(Blue)-info
AAA sized LiIon cells, how good is this brand?
DSC_5344
DSC_5369DSC_5370
DSC_5371
DSC_5372
PKCell%20ICR10440%20350mAh%20(Blue)-Capacity
Up to 0.5A the cell works fine, at 1A it has lost some capacity (Sorry, only curve for one cell) and it cannot do anything at 2A
PKCell%20ICR10440%20350mAh%20(Blue)-Temp-1.0
PKCell%20ICR10440%20350mAh%20(Blue)-Temp-2.0
PKCell%20ICR10440%20350mAh%20(Blue)-CapacityTimeHours
PKCell%20ICR10440%20350mAh%20(Blue)-Energy
PKCell%20ICR10440%20350mAh%20(Blue)-PowerLoadTime
PKCell%20ICR10440%20350mAh%20(Blue)-TripCurrent
PKCell%20ICR10440%20350mAh%20(Blue)-Charge
Conclusion
The performance of this cell is not very impressive, but that is the same for most 10440 cell. The capacity is always around 300mAh and some can deliver more current than other, this one here is not a high current cell!
Notes and links
Comparison to other LiIon batteries
Agro
Last seen: 1 min 31 sec ago
I see several cells that clearly outperform it in your comparator. I’m disappointed.
Thank you for the test HKJ!
