I don’t know it’s model number, but I have this light:
I would like for it to always be set to maximum output, rather than having to click through other modes.
Is there a way to do this?
Thanks
Thanks
Here’s the firmware for the BLF A6. You can easily enable mode memory, so it will always turn on in the last-used mode. As long as you always keep it in turbo, it will always be in turbo.
You can also set it to a 4-mode group, so there’s less taps to get to any brightness level.
Thanks!
But Turbo always steps down to the next brightness level after around 40-45 seconds…
So, if you turn it off when it steps down to “High 2”, won’t the next turn on start at the “High 2” mode?
