Astrolux "MF04" discussion thread
248 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 5 hours 55 min ago
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Nicolaas
Last seen: 4 days 8 hours ago
Good!
Now for the first tests and the test outcome Wink Wink Wink
If you get my drift Innocent
Cheers
Nico
sparkyDK
Last seen: 5 hours 33 min ago
Nice Cool
Imagine a even stronger beam coming back from up there Shocked
flybird
What is the driver and UI on this light ? Is it as good as BLF GT ?
JasonWW
JasonWW's picture
Last seen: 2 hours 5 min ago
Freeme said it was going to be a different driver than the MF02. I’m not sure how different, though. The MF02 uses a 6v carrier along with a boost driver to feed 12v to the emitter. The MF04 is appearantly a larger headed MF02 so the battery tube and carrier might interchange. It would be a smart thing to do.
They haven’t posted the specifications yet, but I imagine the UI is going to be the typical Astrolux style. It will probably have four brightness levels plus a double click for strobe, etc…
We will gave to wait until they announce the final specs.
Click this to go to signature links.
sparkyDK
There are already offerings for the MF02 in regard to other driver ASO, and it would be nice if they was interchangeable for this one too, which i think they will be.
flybird
Thanks to JasonWW and sparkyDK.
steel_1024
steel_1024's picture
Last seen: 16 hours 57 min ago
Sorry for my poor english.
mortuus
mortuus's picture
Last seen: 7 hours 31 min ago
nice photos.. how does the light feel in hand, is it balanced with that small battery tube?
...where Frugal meets with Flashlight!
JasonWW
JasonWW's picture
steel_1024 wrote:
Similar weight?
Maybe they made the MF04 a bit lighter on the big end?
It sure looks lighter around the switch area.
hunter1
hunter1's picture
Last seen: 2 months 6 days ago
Hi .. just a brush up on the GT
Weights BLF GT
with batteries 2273 g (8 × 35E)
tail-cap 91 g
one battery holder 64 g (empty)
one battery 48 g (35E)
one battery holder 259 g (with 4 × 35E)
two battery holder 518 g (with 8 × 35E)
battery tube 285 g
BLF GT head 1379 g (with screw 1381 g)
Here is what I found on:
Mateminco MT35 Plus (Astrolux MF04)
Battery 4*18650 battery
Weight 1290g (without battery)
Maverick1947
Maverick1947's picture
Last seen: 1 week 5 days ago
That’s really nice. Wonder how it does compared to the GT…
There’s no replacement for displacement.
M4D M4X
M4D M4X's picture
 beautiful pictures @steel_1024
klrman
klrman's picture
Last seen: 22 hours 46 min ago
Specs say 2000 lumens for the MF04 and my MF02 has 3000 lumens.  Is 2000 lm a misprint for the MF04?
maukka
maukka's picture
Last seen: 11 hours 55 min ago
The MF02 has a measured output of 2100 lumens and with the LED binning that’s already overdriving it.
klrman
klrman's picture
maukka wrote:
The MF02 has a measured output of 2100 lumens and with the LED binning that's already overdriving it.
Thanks.  Somewhat misleading for BG to post 3000 lumens then for the MF02.  I'm going to take off 30% off whatever
they say the MF04 output is and bank on that.
JasonWW
JasonWW's picture
klrman wrote:
Thanks.  Somewhat misleading for BG to post 3000 lumens then for the MF02.  I’m going to take off 30% off whatever
2000 is probably pretty accurate. The xhp35 can only get so bright regardless of how much power you put to it. It’s physically not capable of 3000 lumen “out the front”. Also, the throw of the MF02 is less than 1587m. It’s probably around 1400m.
klrman
klrman's picture
2000 is probably pretty accurate. The xhp35 can only get so bright regardless of how much power you put to it. It's physically not capable of 3000 lumen "out the front". Also, the throw of the MF02 is less than 1587m. It's probably around 1400m.
The MF02 is still by far my favorite light in my collection, but I don't get why BG feel they needed to stretch the specs so far away from reality.
JasonWW
JasonWW's picture
The MF02 is still by far my favorite light in my collection, but I don’t get why BG feel they needed to stretch the specs so far away from reality.
It is a mystery. They released those specs before the light even came out. And then once it came out and everybody realized it was much lower than those specs, we knew it would be lower obviously, banggood never did change the specs to a more realistic level.
Tally-ho
Tally-ho's picture
Last seen: 1 week 6 days ago
Long press to turn it OFF
JasonWW
JasonWW's picture
Is that different than the MF02?
Tally-ho
Tally-ho's picture
This rhetorical question doesn’t make the MF02, MF04’s UI any better. It’s not because the MF04 shares the same UI as the MF02 that a long click to turn it OFF isn’t “bad”.
Fortunately the long click isn’t too long.
JasonWW
JasonWW's picture
It wasn’t rhetorical. I don’t have an MF02 so I dont know if the long click for off is a new thing or not.
The way you said it made me think it was a new thing.
Tally-ho
Tally-ho's picture
OK, my bad Jason, I thought you already knew the answer and was a bit ironical.
All mateminco/astrolux flashlights are sharing the same UI (listed in the above picture) so far which isn’t bad as a princip…if only it was a good UI.
JasonWW
JasonWW's picture
Believe it or not, I don’t own a single Mateminco or Astrolux light even though I follow a lot of their threads. Like right now. I have zero intention of buying the MF04 as I alresdy have a GT, but I’m still curious about it.
I’ve considered buying some other Astrolux lights with the intention of swapping the driver to a Lexel unit and get NarsilM, but I haven’t done it yet.
That’s probably why I don’t know their UI, I never paid attention to it.
Their drivers tend to break anyway. It usually takes them a few redesigns to get it right. It seems the current MF02 drivers are finally working well so I guess the MF04 driver will work well, too.
steel_1024
Yes, The MT35s(MF04) driver works well.
Newlumen
Newlumen's picture
Last seen: 2 weeks 1 day ago
Skylumen is very impress with astrolux or mateminco lights. He said mf02 have a great factory heatsink. His favorite is mateminco Mt18 with the xpl hi.. I do believe him because he open and mod lights.
JasonWW
JasonWW's picture
Yes, their machining and finishes are quite good. Notice that Skylumen always changes the Mateminco drivers out to his DriverVN, though. They make good hosts.
Theodore41
Last seen: 13 hours 46 min ago
Look at the price tag please. Shocked
https://www.banggood.com/Astrolux-MF04-XHP35-HI-Searching-LED-Flashlight-p-1289449.html?rmmds=search&cur_warehouse=CN
Theodore41
steel_1024 wrote:
What about the head diameter,is it bigger than the GT?
