Boruit Headlamp Review D10 (aka. EHL0628) - King of the Budget Headlamps?
312 posts / 0 new
NeutralFan
NeutralFan's picture
Last seen: 4 days 2 hours ago
Thanks for the review garrybunk! Looks like a good budget headlamp. Does it have low voltage protection?
I’d rather use my flashlight around the house than turn on the lights.
Wildcat
Yes, low voltage indication (blinks) and auto-off.
garrybunk
garrybunk's picture
Last seen: 6 days 5 hours ago
Whoops! I have it in my notes, just forgot to post. According to my testing (and trying to pull the cell to measure voltage quickly) it seems to trigger 3 slow flashes at 3.00v but keeps running at regular ouput (no stepdown) and I don’t believe it flashes again – just shuts down when it reaches about 2.70v. That shut-off level might be a little low for some cells.
-Garry
P.S. – I’ll add this to the O.P.
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
MascaratumB
MascaratumB's picture
Last seen: 3 hours 16 min ago
Yesterday I used this light intensively (almost 7hours, with some interruptions) and I must say I am really pleased with it! I used it with a protected 18650 and mostly on medium mode (sometimes used the “high medium” and “turbo”).
The best part for me is to know that when switching ON it will always start on the same level and that with a fast click I can raise the output to the Highest mode.
Also, the simple “click” to ON is very pleasant!
Only once I accidentally turned the Strobe ON when making a fast click. The stock headband feels good on the forehead and despite this is not the lightest flashlight, it doesn’t feel heavy.
The tint with a pebbled TIR lens is indeed more pleasant and it worked well when used against non-white objects.
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
garrybunk
garrybunk's picture
I now love lights without memory meaning I know exactly what mode a light will come on in. You see, the problem is that my memory isn’t as good as the driver’s memory – I can’t remember what the last mode I used was when I turn it on again!
-Garry
JasonWW
JasonWW's picture
Last seen: 6 hours 9 min ago
I got mine in today. Ordered on Feb 5th and go it 10 days later. Really fast!
It is quite nice. Not heavy at all. It’s surprisingly light and doesn’t really need the 3rd strap over the top.
I’m pretty sure it’s less blue tinted than the RJ02. I don’t have it handy to compare them. It’s a nice white, though.
The UI is great. No problems at all using it.
I had to install the 60° tir from MTN Electronics. The stock reflector is 18.8mm wide as mentioned before and about 10.5mm tall. The tir is about 19.7mm wide and 11.8 tall. So I filed it down some to make it fit. I filed the edges and the narrow bottom. I removed the plastic centering ring. The tir sits on top of the white emitter package, not the mcpcb. This seems okay.
I got the optional Boruit 4,000mah battery as well. It’s only 67mm long which is pretty short for a “protected” cell. Maybe it is protected, maybe it isn’t. I can’t say for sure.
Here it is next to a Evva protected Panasonic NCR18650B at 69.5mm.
I’ll be testing it’s capacity soon.
JasonWW
JasonWW's picture
I ran the Boruit battery down until the light turned off. That should be 2.70 volts, but when I measured it, it was 2.78v. Then several minutes later it showed 3.2v.
I put it in the Miboxer C4-12 charger at 3.2v and it very quickly started charging. Internal resistance showed 98 ohm. Capacity ended up being 1570mah. I was hoping for at least 2200 or so. Oh well, it was only about $2 extra.
garrybunk
garrybunk's picture
Glad to hear you like the light!
-Garry
d_t_a
Last seen: 1 hour 14 min ago
Did a capacity test for batteries that are bundled with flashlights:
Also did a capacity test of the Boruit “4000mAh” (discharge current 0.50A, cut-off 2.50v) – ordered with Boruit RJ-02 “kit” (it weights lighter than many standard 18650s — coming in at only 40 grams) ~1639mAh capacity
Above pic also shows the Sofirn “3000mAh” 18650 included with SP32A flashlight+battery kit under the same conditions – discharge 0.50A, cut-off 2.50v) ~ 2641mAh.
The Sofirn “900mAh” 14500 (included with SP10B flashlight+battery kit) was tested with discharge 0.25A, cut-off 2.75v ~ 804mAh.
(the Boruit seems to self-discharge quite fast since I hadn’t removed it from the charger after it completed the test)
JasonWW
JasonWW's picture
-Garry
Yeah, it will probably be the new go-to headlamp, replacing the bigger RJ02.
contigo
is the rj02 noticeably bigger than this? I am torn between those 2 lights
JasonWW
JasonWW's picture
Yes. Heavier, too.
It’s a no brainer. Here are the advantages of the new one:
Lighter
Smaller
Has low voltage protection
No visable PWM
Whiter light, less blue
Better sealed against water
Pops out of headband holder with no fuss
Easy to swap a new emitter in, nichia, sst40, etc…
The only advantages the RJ02 has is:
Infinite brightness adjustment, but the new one seems fine with its 5 levels.
The motion activated switch, it’s only between full power and off and I never found it useful.
deathless
Last seen: 2 weeks 2 days ago
Awesome, thanks for the heads up!
garrybunk
garrybunk's picture
I finally have approximate lumen measurements from my DIY foam sphere (light still in stock form):
Level   @Start   @30secs
1             17           17
2             58           58
3            149         148
4            293         290
5            573         547
Pretty stable outputs in the first 4 mode levels (at least for 30 seconds). I'll add these to the O.P. too. If I do an emitter swap (219C) I'll post those results too, but that will be awhile. -Garry
garrybunk
garrybunk's picture
Looks like I’m gonna swap in an XP-G3 5C on a 16mm star. I looked all through my parts envelopes and don’t see where I ever ordered XP pcb’s to reflow a 219C onto. Of course I could reflow the 219C on to the board containing the XP-G3, but I’m going to try the XP-G3 out first.
-Garry
EDIT – I never proceeded with this. I waited on new XP pcbs.
wstrachan
Last seen: 9 hours 30 min ago
Inhave bought several now and find them excellent. The switch is positive and machining is good. It’s plenty bright…by my estimate around 900 lumens. The charging works well. This thing is a great bargain for $11.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
JasonWW
JasonWW's picture
I think 900 lumen is too high. It’s only drawing 1.9A and not even a genuine Cree led. I was thinking 500 to 600 lumen.
garrybunk
garrybunk's picture
Well after over a month of waiting I finally received my order from KD containing DTP XP boards! I reflowed a Nichia 219C onto a 20mm board and swapped it in. I accidentally broke the ends of those short emitter wires off when I was breaking the old pcb loose, so I soldered and heatshrink wrapped some extensions on them (would have needed to do anyway). I did have to file down the side of the KD pcb to fit it by the wires. It all worked out well (finally a mod that went fairly well). For now I only have the stock reflector in it, but expect to try a TIR optic at a later time. I will run it through my sphere again very soon and post those numbers. I did however re-check tailcap currents (though these were measured with a good high-drain cell vs. the old Trustfire I did the first measurements with):
Original #‘s:
5 Step Quasi-Ramping:
Level 5: 1.87A
Level 4: 0.84A
Level 3: 0.40A
Level 2: 0.13A
Level 1: 0.05A
Newly measured#‘s:
Level 5: 2.11A
Level 4: 0.99A
Level 3: 0.47A
Level 2: 0.17A
Level 1: 0.05A
So not very different and could be the different battery.
Some photos:
My extension wires soldered on:
Heat shrink wrapped:
KD DTP board fit, filed edge at wires:
Soldered up;
Put back together:
Beamshot (cell phone camera):
Beamshot comparison with cool white Zanflare F1 on the right (cell phone camera):
-Garry
MascaratumB
Nice mod Cool
A better tint and beam as well!
I’m still using mine with the original LED, but with a pebbled TIR ! Maybe someday I get inspiration from you and swap a NW or WW tint LED !
Thanks for sharing!! Thumbs Up
garrybunk
garrybunk's picture
Ok, I have new lumen measurements after the emitted swap to the Nichia 219C. Numbers are down from the fake XM-L2 emitter measurements (which I guess makes sense). All taken @ 30 seconds
Level 1: 12.5
Level 2: 45
Level 3: 115
Level 4: 228
Level 5: 448
According to djozz’s Nichia 219C test (bin difference???), he measured about 675 lumens at 2.0A. That’s without any losses, so if we guess 20% loss 675 – 135 = 540 lumens. I wonder if I damaged the emitter during the reflow (took me a couple tries to get it on right).
-Garry
zelee
zelee's picture
finally got mine and i swapped it with 5200K tint + 90 degrees TIR optic lens, my most used headlamp right now Thumbs Up
Don’t mistake my kindness for weakness.
I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me.
JasonWW
JasonWW's picture
Level 1: 12.5
Level 2: 45
Level 3: 115
Level 4: 228
Level 5: 448
-Garry
What are you using to measure the lumens?
skinny_tie
skinny_tie's picture
Last seen: 3 hours 49 min ago
MascaratumB wrote:
Nice mod Cool
Did you find a TIR that fits, or did you file one down?
skinny_tie
Extensions leads are the way to go on this headlamp.
I tried soldering new leads onto the driver, but I’ve had to put the mod on hold until I get some thinner silicone insulated wire. Getting the wires into the channels in the battery compartment is a pain, and there’s no room for any slack at the driver end.
MascaratumB
skinny_tie wrote:
MascaratumB wrote:
Nice mod Cool
I had to file one to fit! I used a TIR lens like the ones used for Convoy S2+, but it didn’t fit well, so I filed it on the edges and it’s good now Wink
garrybunk
garrybunk's picture
My DIY foam ball integrating sphere, which is now calibrated against the average of 3 Fenix HL55’s. I don’t expect my numbers to be extremely accurate, but close enough and they are definitely consistent and repeatable.
Some links:
The build: http://budgetlightforum.com/comment/904610#comment-904610
The calibration issue seeing differences from 3 Fenix HL55’s: http://budgetlightforum.com/node/59371
-Garry
garrybunk
garrybunk's picture
Look closely at my 3rd pic in post#79 above. You can see the edge of the dome looks nicked. Output looks normal without any weird beam artifacts or weird tints, so I assumed it wasn’t anything serious. I do have one more Nichia 219C left and could try that one, but I kinda feel like leaving well enough alone.
-Garry
d_t_a
Just a comment on the included Boruit “4000mAh” 18650:
Recently ordered some of the other Boruit headlamps for trying out, including the above EHL0628 (single “L2” LED) and another very similar headlamp but with dual “G2” LEDs. I ordered the package which include 18650s.
The Boruit “4000mAh” 18650s from the recent batch I ordered arrived last week and I did capacity test — these new batch Boruit 18650s now register only around 1200mAh capacity (0.50A discharge rate using MC3000, from 4.20v to 2.50v cut-off)
(I checked my previous Boruit 18650 with around 1600mAh capacity, which weighed around 39.3grams; whereas the new batch Boruit 18650s weighed around 37.0grams and around 1200mAh capacity)
JasonWW
JasonWW's picture
Maybe their batteries are like Ultrafire?
bansuri
Last seen: 5 days 1 hour ago
Dang, I totally missed this headlamp because I thought it was about the other Boruit! The other model has worked great for me at work but is about the size of a RedBull can compared to this one.
Thanks for all the info and modding tips!!! Now I just need to find the best deal and patiently wait for round-the-world shipping.
I work in a production shop that is too broke to replace failing lighting and even with proper lighting it’s difficult to see inside machines for repair. I’ve turned my fellow employees on to headlamps and they now reach for them rather than trying to work on things one-handed with a standard flashlight. This type of safe, rechargeable, effective headlamp is a blessing.
BLF FTW!!
edit: JasonWW, WTH is that battery you posted?!!! unfreakingbelievable
