1100 lumen 16340 klarus Mi1C Resistor Mod
34 posts / 0 new
moderator007
moderator007's picture
Last seen: 4 hours 28 min ago
Most people already probably know how to do resistor mods. Since this is a fairly new light I thought I might show others how easy it is to mod this new light. I have both the cooper version and the titanium, this mod works on both and maybe the aluminum version if its the same driver.
This light is tiny compared to all my other 16340 flashlights especially since it has a side e-switch. Amazing they got all parts necessary to fit in such a tiny light. Its smaller than my ITP A1 EOS which is the smallest 16340 light I own, and its a twisty.
So on with the mod. First you will remove battery and battery tube. On the driver battery side it has a black plastic retainer with 2 small holes in it. Take your time here and use needle nose pliers or whatever you use but keep the tips very shallow in the holes. The driver components are right below this retainer. If you go to deep or force the retainer out you will twist off components on the board and brick your driver. Now unscrew the bezel once the retainer is out, I used a pair of short needle nose pliers stuck down in 2 of the 4 notches on the bezel spreading the pliers apart fitting the notches. Be careful here and keep pressure outward and twist counter clock wise. Mine was not glued and came apart easily. Now unsolder the little ground wire and both led connections, unscrew the screw holding down the ground wire terminal and don’t loose the terminal. The led mcpcb should come right out and has very little thermal paste on it or mine did. Now take a small screwdriver and push on the wires a little and maybe the board, but don’t force it, it should come out fairly easy.
Once its out flip the driver over on the spring side. You are looking for the resistor marked R050.
In the pic above you will need to solder on another R050 resistor on top of the original one. The light draws 1.5 amps factory. Half the resistance doubles the current. Mine draws 3 amps with the piggy backed resistor. Best I can tell the formula would be 75 divide by your target current in milliamps. 75/3000ma = .o25 ohms. Now time to put everything back together. Be careful and take your time. The driver will only go in one way with the switch lined up with the button. Good luck modding.
At 3 amps it gets hot within 3o seconds and seems like some batteries can’t keep up because it will step down from turbo to high within a few seconds with some batteries I have tried. Might be better to be conservative and use a resistor that gets you closer to 2.5 amps or so. This light is suppose to have thermal regulation but with a good battery it gets so hot I don’t wanna hold it any longer so I have to turn it off.
Klarus sales ad:
“Newest Intelligent Temperature protection System(ITS) monitors internal temperature and adjusts output to regulate heat dissipation; protects LED and internal components for perfect balance of output and safety.” Facepalm
Edited by: moderator007 on 02/04/2018 - 12:54
Jiffy
Last seen: 6 months 1 week ago
This sounds a great mod. Any chance of getting the pics working?
ssschen
ssschen's picture
Last seen: 1 month 2 days ago
Second this. Would love to see some photos of the mod.
MascaratumB
MascaratumB's picture
Last seen: 52 min 8 sec ago
+1 here! I haven’t been able to see moderator007 pictures on the last threads, presenting some mods Sad
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
moderator007
Sorry guys I had no idea the pics were not working. I linked them thru google photos. They show up on my end, so it looks fine to me. Facepalm
I’ll see if I can fix it, might need some help letting me know if the new pics work.
moderator007
Can you see both pics now?
sp5it
sp5it's picture
Last seen: 9 min 24 sec ago
Second one only.
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
moderator007
I just created a imgur account for hosting photos. I’m really upset about photobucket holding my older pics for ransom. Google photos seems to have problems sharing on forums from what I googled.
Does both pics show up now?
ssschen
ssschen's picture
moderator007 wrote:
I just created a imgur account for hosting photos. I’m really upset about photobucket holding my older pics for ransom. Google photos seems to have problems sharing on forums from what I googled. Does both pics show up now?
Yes, I can see both photos now. Thanks Big Smile
moderator007
Thanks for letting me know ssschen. Thumbs Up
Bruno28
Last seen: 1 month 1 week ago
do you have a comparison photo between the stock and the modded? Would be interesting to see.
moderator007
I guess your referring to a beam shot pic. I dont have any at the moment but I have some Efest IMR 16340’s on the way that are rated for 5 to 7 amps continuous (depends on the seller). So I’ll wait until I have those to use. I have several of the top rated 16340 batteries from HKJ’s comparator but none work good at a 3 amp load, to much battery sag. Seems they haven’t really designed a high current 16340 yet that I could find. The driver I’m pretty sure has a low voltage step down, so when the battery sags below say 3v the driver steps down to high, thinking the battery is depleted but its not (to much voltage sag).
The best I found by description was the Efest IMR 700mah (red) or the Imren IMR 700mah (blue). They haven’t been tested by HKJ yet or anywhere else I could find, so I’m not sure what their going to do, but I do plan on testing the Efest 700’s when I receive them. I noticed they were popular with the vape sites, so that’s a good sign since that’s a high current device. I may buy some Imren’s to try also. Probably just the same battery given their both 700mah Imr’s.
moderator007
I tested the Efest IMR16340 700mah(red) and there no better than the klarus LIR16340 or the fenix ARB L16-700. They all dive pretty quick in voltage at a 3amp load. I get around 300mah at about 6 minutes out of any of the 3 at a 3v cut-off. Trustfire seems to be about the best 16340 at the moment from HKJ’s testing, I got four on the slow boat to try next.
CRX
CRX's picture
Last seen: 3 days 11 hours ago
Nice Mod Thumbs Up
The Yellow AWT 16340 cells are great, I’ve been using them for a while now whereas the red TF cells were good at first some failed quite fast at high draw. YMMV.
Agro
Agro's picture
Last seen: 2 hours 9 min ago
What is the resistor size?
EDIT:
Far smaller than 2512 that I have here :/
1206?
moderator007
EDIT:
1206?
1206
moderator007
CRX wrote:
Nice Mod Thumbs Up The Yellow AWT 16340 cells are great, I've been using them for a while now whereas the red TF cells were good at first some failed quite fast at high draw. YMMV.
This one CRX?
CRX
CRX's picture
That’s them.
moderator007
Ordered 3 to try out. Thumbs Up
Barkuti
Barkuti's picture
Last seen: 1 hour 11 min ago
CRX wrote:
… whereas the red TF cells were good at first some failed quite fast at high draw. YMMV.
Interesting insight. Me and a friend recently hairdryer rewrapped a couple TrustFire IMR14500s and seems like the heat killed 'em. Quite disturbing.
Cheers Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
Agro
Agro's picture
moderator007 wrote:
EDIT:
1206?
1206
Thanks.
I was careful unscrewing the plastic, but nevertheless I slipped and ripped some resistor and some other element.
It’s funny to see strobe running with moonlight level ^^.
OK, will have to repair. But first another question:
Without split ring pliers, what’s the best way to unscrew the bezel?
I tried tweezzers, couldn’t do it. I tried friction, didn’t work either.
I can glue it to something and then polish the glue off but that’s quite a lot of work…
moderator007
You just need a cheap blunt nose set of needle nose pliers usually a dollar at most hardware stores.
The nose is rounded except where the pliers contact, it’s ground in a D shape. They fit in the round slots on the bezel.
A cheap pair of these should work fine with a blunt nose.
Barkuti
Barkuti's picture
https://www.ebay.com/itm/Precision-Beading-Pliers-Tool-Kit-Set-Jewelery-Design-Bent-Nose-Cutting-Needle/162575785598
Bought model 359A a few months ago, tip diameter is less than 1mm. Handy and sturdy enough.
Cheers
Agro
Agro's picture
Managed to unscrew the bezel with a grinding stone. Pressed the bezel hard against the stone and the friction was enough.
Unsoldered leads, no problem. Couldn’t unsolder the ground though. Too little power? I use a large screwdriver type bit, 410 °C, 50W iron. Is the iron too weak?
I weakened the connection, moved the wire a bit to the side with the iron and then cut with a knife.
I re-soldered one of the elements that I ripped off. Now I think it was not a resistor but a capacitor. That thing is TINY.
I moved the other into place – it seems I bent the legs, but haven’t broke them (not sure).
What is the simplest way to test if it works now?
Agro
Agro's picture
According to my plastic calipers the lens is 13.1 mm.
I wonder if we can find AR coated replacement…
moderator007
I don’t know if you will find one in that size but this one could be sanded down to fit.
https://www.fasttech.com/products/0/10001022/5422711-14mm-ar-coated-glas...
I just sanded down a lens the other day to fit my triple xpl DQG 4th because I couldn’t find the size I needed.
moderator007
CRX wrote:
Nice Mod Thumbs Up
Best 16340 batteries I have tried so far. I ran a 3 amp test on them and I got 400mah to 3v. Would have been more if I had lowered the cut off voltage to 2.7v. Thanks for the recommendation CRX. Thumbs Up
I still have some trustfires on the way to test when they get off the slow boat.
Agro
Agro's picture
Thanks, but this light has only a plano-convex lens.
I failed to find any AR-coated one that could fit. Though I may try harder at some point….
moderator007
I’m guessing you have the aluminum version. The Ti and Cu version has a reflector with a AR coated glass lens.
CRX
CRX's picture
moderator007 wrote:
CRX wrote:
Nice Mod Thumbs Up The Yellow AWT 16340 cells are great, I’ve been using them for a while now whereas the red TF cells were good at first some failed quite fast at high draw. YMMV.
Best 16340 batteries I have tried so far. I ran a 3 amp test on them and I got 400mah to 3v. Would have been more if I had lowered the cut off voltage to 2.7v. Thanks for the recommendation CRX. Thumbs Up . I still have some trustfires on the way to test when they get off the slow boat.
Cool, would be nice to see how the TF performs too Thumbs Up
Agro
Agro's picture
Yeah, I have Al. It’s uncoated plastic. I’ll see, if I get deeper into this light I may get a Cu/Ti one or ask Klarus if the are willing to sell me a coated one.
Thanks for the good news.
