Balder SE-1 XM-L
106 posts / 0 new
how2
Last seen: 5 years 2 months ago
Balder SE-1 XM-L
I have just received It Today. This is a Pocket Rocket.
A Nice Light that weighs 51g and not 40g as advertised.
Has 3 modes H-M-L, always starts on high after the light is turned off for 10 seconds.
There are no marks or damage to the body.
LED slightly off center
Tail Cap readings
                      Ni-MH               Trustfire 14500(4.14v)
High                2.23Amps          2.45Amps
Medium          0.78Amps          0.74Amps
Low                 0.06Amps          0.02Amps
New readings using 8 batteries 14500 Flame
4.02v  2.06Amps  0.61Amps
4.05v  2.22Amps  0.68Amps
4.06v  2.18Amps  0.63Amps
4.08v  2.20Apms  0.67Amps
4.13v  2.40Amps  0.73Amps
4.14v  2.54Amps  0.75Amps
4.16v  2.53Amps  0.73Amps
4.18v  2.56Amps  0.77Amps
The first reading I got was 2.50Amps but settled on 2.45Amps. Seems to work will with both batteries. I will tell you about the light output when it gets dark.
Buy this light
Here we go Beam shot. Balder VS UF 2100 3 Mode modded to 5 Mode.
SE-21- Mouse Out  UF2100 Mouse Over
Control shot
High
Med
Low
Edited by: how2 on 11/28/2011 - 11:07
Kokopelli
Kokopelli's picture
Last seen: 10 months 2 weeks ago
Wow, what a high current on such a small light. I really wonder how long this guy's going to last. Will definitely get one if it keeps up strong.
Don
Don's picture
Last seen: 2 years 9 months ago
At those currents I'd be getting some Bestinone IMR 14500s - that is way past the 1.2-1.5A that lithium cobalt 14500s can safely produce.
Most likely it'll just age the cells really fast but there are other possibilities.
Wish my one would show up - it has now left HK, but no idea where it now is - the Royal Fail website is useless for tracking incoming items. In fact it is pretty useless full-stop just now as it has most of it not working.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
weiser
Last seen: 6 years 11 months ago
Hey, you got the brand printing on yours! My XP-E came without any markings whatsoever. I wonder if I got sample stock Tongue Out
I have another XP-E coming directly from Balder and also an XM-L that is still in transit from Tactical HID (don't buy from them if you want your item in decent time and it's shipping from HK).
GETEMER
Last seen: 7 years 2 months ago
I ordered one of these too. Can't wait to get my hands on it!
Don, are you saying that this light will quickly age my trustfire flames because of the hight amperage? Where can we get those Bestinone cells?
Kokopelli
Kokopelli's picture
Easy. From bestinone.net . Those IMR are really inexpensive and fairly good.
Don
Don's picture
They are not expensive, but you won't get them this year I'd expect.
http://www.bestinone.net/index.php?route=product/category&path=57_67
The 14500s are here ($7.99 for two)
http://www.bestinone.net/index.php?route=product/product&path=57_67&prod...
They charge just like standard lithium cells but aren't protected (As there is no real need for them to be) but watch you don't over-discharge them - don't go below 2.5V but you will know before they drop that far as the light will dim significantly. The same goes for lithium cobalt cells (The normal Li cells) and I've yet to see a low voltage cutout that works on them. There musty be some out there, but most just seem to cut out on current draw which with a regulated driver will rise as voltage drops.
GETEMER
Oh, thanks guys! So the difference is that what they are made out of (trustfire versus the IMR)???
Don
Don's picture
Different chemistry.
The lithium manganese (Usually called IMR) chemistry has a lower internal resistance so is capable of producing higher currents. The downside is they have lower capacity usually.
While they can be made to go kaboom (and have done so in one well publicised case in the Other Place - the Sony cells concerned were IMR cells) it is far less likely than with the usual lithium-cobalt cells. This (wikipedia) article goes over some of the basics. There isn't a specific article on lithium-manganese cells but there's a bunch of (wikipedia) stuff here. And it isn't all that likely with any single cell lithium cobalt cell device.
If you want completely non-kabooming lithium cells you need to go for the lithium iron phosphate (LiFePO4) cells but they have a lower nominal voltage, a lower capacity and usually a higher cost. And need different chargers and I don't think they will provide as much current anyway.
In single AA lights you are not likely to have anything nasty happen, regardless of the lithium chemistry involved but such heavy loads mean the cells won't last as long as they otherwise might. I have some unprotected 14500s that are now down to 90mAh capacity which is hardly useful. This is largely as a result of repeated high discharge rates. Or that they were never all that good in the first place. Or both.
CheapThrills
CheapThrills's picture
Last seen: 15 hours 36 min ago
So, is this about the cheapest, yet decent quality XM-L pocket-rocket yet?
Xeno is cheap and bright but I never liked the looks or form that much...
This, only 4$ more than regular Balder Smile
edit: I also recommend those BIO IMR´s. Got good results with them.
how2
I must say those who like a really low low have got the perfect light.
Low on both Ni-MH and 14500 batteries is very low.
how2
Lighthound has the same light in XML($24.99) and XPG($20.99).
weiser
I see Lighthound chose to go the route of branding it as their own as opposed to selling the Balder brand. I actually don't like this because I think Balder is creating a unique product on their own. However, Balder is the one offering this option so whatever.
how2
Maybe out next BLF light could be a Balder?
fran82
Anyone can give a lumens estimation on NiMh in the highest mode please?
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Don
Don's picture
As soon as it arrives, I'll do this. It left HK three days ago but hasn't made it here yet.
fran82
Thanks Don!.
Seems to be a good light, at least if you see the desing and light output... but I dont beleive that this light is fully regulated  (I mean, current increases as battery voltage decreases)
mizjif
mizjif's picture
Last seen: 3 days 12 hours ago
I also vote BLF edition of this light Wink with special BLF price hehehe.
how2
See New beam shots.
fran82
Thanks for the beamshots. That beamshots are with 14500 or nimh?
how2
14500
borstar_micke
Last seen: 2 years 4 months ago
Got my xp-e in Sweden the 25:th, shipped from CQG the 21:th, thats crazy fast!
Ordered it as a gift for my dad and liked the design much better than my Xeno 03 T6 NW so I ordered a T6 CW for myself yesterday! Smile
Vectrex
Vectrex's picture
Last seen: 11 months 1 week ago
If I had known that there would be an XM-L NW version, I would have waited for that.
weiser
I probably would have, too, but now I'm kind of glad I can compare the two. My problem was buying the XM-L from Tactical HID instead of CNQG because that was the only vendor carrying it at the time. He took the order but the drop shipment wasn't nearly ready and it took two weeks just to process. I had no idea Ric would be carrying it so fast, since it was ME who informed him it was actually available just a few days earlier. haha
2100
Last seen: 1 year 3 months ago
http://www.bestinone.net/index.php?route=product/product&path=57_67&product_id=53
I actually discharged one till i believe 2.1V open circuit and another time 1.7V open circuit.....so that's VERY low. But i recharged them immediately when i saw that the light was so dim.  Still able to dump nearly 2.3A into the Xeno E03 when fresh, and nearly slightly over 3A in the Ultrafire XM-L drop-in so there's no damage i guess.   These cells are good.
UPz
UPz's picture
I have this torch. It's a winner. Mine draws 2 amps from a 4.1V 14500 trustfire. Pure flood power on a extremely nice built flashlight.
To all you talking about the IMR: Be advised this flashlight has a "reverse polarity protection", a nylon ring protecting the positive contact on the driver. That means flat top cells (such those BIO IMR's) won't make contact with the driver. It also has gived me some trouble with some of my trustfire flame 14500, but It can be solved using a magnet spacer. Anyway there's enough room for the protected 14500 + the 1mm spacer. ( I didn't have this small size magnets so I broke one and used the pieces)
I still don't know how to dissasembly the pill for removing this annoying "protection".
EDIT: you can check my wn review for forolinternas.com here: http://www.forolinternas.com/viewtopic.php?f=5&t=2756
ChibiM
ChibiM's picture
Last seen: 3 hours 1 min ago
Its a nice torch, but I would like a more even design better. The head and tail "fatter" than the middle. Hopefully Balder makes one soon! they are really good priced!
how2
More Tail cap readings
Orignal
Tail Cap readings
                      Ni-MH               Trustfire Flame 14500(4.14v)
2100
UPz, i always DIY a nipple with solder for my flat top IMRs, Panasonic, Sanyos.
Don
Don's picture
My flat-top IMRs work(ed) just fine. Picked my one up from the PO this morning. I really am not fond of forward clickies in multimode lights.
Time to do some playing testing
Nice finish. Could do with some more threads at the head end.
Worked in the office - now at home refuses to emit light. Ah well, it isn't going to get used for dog spotting in the park tonight.
how2
Don see if your readings are high as mineSmile
