The There Are No Stupid Questions Thread
1140 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 49 min 2 sec ago
CNCman wrote:
It is working now, MT07 Buffalo that fried a led a few weeks ago. I will get you a full update if I get time tonight, busy now. Thanks for helping again. Wink
Cool. That light has one of those wierd regulated driver designs I’m not familiar with so I’d be no help. Silly
MoreLumens
MoreLumens's picture
Last seen: 6 min 10 sec ago
Where to get 3535 gaskets for reflector with 6mm or 8mm hole?
MoreLumens
More questions!
So I been thinking of getting some SST-40 5000k’s, but which ones to get when choices are N5 DA or N5 DD?
https://download.luminus.com/datasheets/Luminus_SST-40-W_Datasheet.pdf
Which would you prefer and why? How much there is color difference between those two bins?
CNCman
CNCman's picture
Last seen: 1 day 17 hours ago
It is fixed, http://budgetlightforum.com/node/43980?page=314#comment-1691640 .
I removed the burnt led and it was re-flowed OK. I had wanted to check the driver voltage before risking another led. So that not an option, we hooked it up and turned it on. It fired up with no problems, so the burnt led is still a mystery. Thanks again for your help Jason !!
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
richbuff
Last seen: 5 min ago
 "EDIT: No it does not have to be about flashlights at all"
Ok, here goes:  Why is it that human beings are designed to feel comfortable in such a tiny temperature range? A 50 degree Fahrenheit temperature range ( 27.8 Centigrade degree range ) is so tiny in the physical world, yet 40 degrees F room air temperature feels so cold and 90 degrees F room air temperature feels so hot. Why can't I feel ok/fine with a much wider ambient room air temperature, even if the temperature is within 38 to 93 degrees F?  Normal people complain if room air temperature is below 66 or above 78. I feel comfortable with room air temperature anywhere from 72 to 74. Why wasn't my mind and body designed to feel ok/fine with real world temperature range?
Normal people walk around with big dogs. They look normal. I walk around with big flashlights. My flashlights have bitten less people then Teds' dog.
JasonWW
JasonWW's picture
richbuff wrote:
 ”EDIT: No it does not have to be about flashlights at all”
Ok, here goes:  Why is it that human beings are designed to feel comfortable in such a tiny temperature range? A 50 degree Fahrenheit temperature range ( 27.8 Centigrade degree range ) is so tiny in the physical world, yet 40 degrees F room air temperature feels so cold and 90 degrees F room air temperature feels so hot. Why can’t I feel ok/fine with a much wider ambient room air temperature, even if the temperature is within 38 to 93 degrees F?  Normal people complain if room air temperature is below 66 or above 78. I feel comfortable with room air temperature anywhere from 72 to 74. Why wasn’t my mind and body designed to feel ok/fine with real world temperature range?
I would say your mind and body IS designed to feel ok/fine with real world temperature range. It seems to match pretty well with the temperatures of the planet. At least we are warm blooded and can survive extreme temp swings.
Robin Dobbie
Last seen: 54 min 24 sec ago
I think we’re spoiled by AC and heat. Some people train for marathons and ultra marathons by running with a blanket on. Incredibly dangerous and uncomfortable, but it forces the body to adapt its temperature regulation. We haven’t been training our built-in temperature regulation for decades.
My ideal temp is directly proportional to my physical activity and outside temp. Like, if it’s 50 outside, and got down to 35 at night, outside, I might want it 5 degrees higher than normal even if it never got cold in the house and I never went outside.
But generally,
75-80 sittin’ ‘round doin’ nothin’
60-65 up and doing stuff – walking miles
50-90 running while it’s raining
30-45 running while dry
The colder and wetter, the more strong wind would adjust the comfort zone up.
Unheard
Unheard's picture
Last seen: 4 hours 58 min ago
My theory: We feel uncomfortable/pain/anxiety to react on a given situation. Clearly, above a certain temperature our DNA denaturates, so that is a valid concern. Below a certain temperature we’re going into energy saving mode, unable to defend ourselfs against potential enemies. Takes too much time to warm up, or, in constant alert mode, consumes too much energy. So we seek company or a warm place when it’s cold. But our body needs to notify us about the necessities.
When we were formed, we had to make sure to survive and being able to hunt. And all we have is that tiny DNA fibre that has formed in the oceans and limit our abilities to adapt.
Smile, you cannot kill them all.
Artiet59
Last seen: 1 hour 54 min ago
Here goes my “there are no stupid questions”, question:
If I wanted to use the convoy 4×18a for a host for the sbt90.2, is there anything that needs to be done to the driver? Does anyone know what type of driver is in the 4×18a? Ideallly, does a dd turbo work best for sbt90, to get mot out of led on turbo?
JasonWW
JasonWW's picture
Quick look at the 4×18a shows that uses the xhp 70.2. This is a 6 / 12 volt LED. The sbt 90.2 is a 3 volt LED. So in order to run it you need to install a 3 volt driver plus the work involved in mounting and centering the LED.
The stock driver must be a Boost design. It’s not a common driver layout due to the large battery contact ring. You’d need a driver similar to the Q8 (which happens to be a DD FET driver and should work well with that led). Most likely you’d loose the built in charging.
pennzy
pennzy's picture
Last seen: 55 min 57 sec ago
As a rule
man’s a fool.
When it’s hot
he wants it cool.
When it’s cool
he wants it hot.
Always wants it
what it’s not.
Lightbringer
Lightbringer's picture
Last seen: 19 min 22 sec ago
I would accept that as an axiom.
Artiet59
Quick look at the 4×18a shows that uses the xhp 70.2. This is a 6 / 12 volt LED. The spt 90.2 is a 3 volt LED. So in order to run it you need to install a 3 volt driver plus the work involved in mounting and centering the LED.
Jasonww- thank you so much for this info. I appreciate the guidance towards an appropriate driver as well. Are you saying that the 4×18a must be a boost design, and that’s not common? Or are you saying that a boost design is needed for the sbt90? I’m assuming you said that the 4×18a is a boost design considering the 6/12 volt led .. thanks !
richbuff
It’s dendroaxonic when it’s hot, and axodendritic when it’s cold.
Lightbringer
I miss aXXo.
JasonWW
JasonWW's picture
I can see the battery configuration in the 4×18a is 3v. The LED that it’s using requires either 6 or 12 volts. The only way to get to higher voltages to use a boost driver. Boost drivers tend to be more complicated so they cost more and they’re not as common. They’ve only really started to hit the scene in the last year or two. Also note that Max output for the 4×18a is 5 amp. That’s also very realistic for a boost driver to do.
The SBT90.2 is a 3 volt led. A decent FET driver should push it to over 20 amps.
You would probably need to talk to someone like Lexel about having a driver made to fit the 4×18a. He may have an existing design that can be modified to fit or else he may need to design a new one from scratch. He’s not going to do that unless you can sell enough to make it worth his while, though. Not completely from scratch, he already has the electronics worked out, its just a matter of getting a pcb with the correct size and shape.
A potential complication could be if the switch is soldered onto the driver. If the switch is separate and it’s connected to the driver with wires then it shouldn’t be any problem. Do you have a 4×18A or have seen the driver?
Artiet59
Thank you for taking the time explain these things,
I do not have the 4×18a, I’m just searching for something that’d be a good fit (both thermally and size-wise – personal preference) to house the sbt90. I was also considering the convoy L21a host, but after receiving my ft03s and seeing how fast it heats up, I’m thinking a larger multi cell light would be a better fit, for my needs.
I have not seen the driver in the 4×18a either..
The info about the switch makes me Leary on trying the mod, unless I can find more info about how it is connected first. Although to be honest I was hoping for a mod that was a little less involved since it is my first one (meaning something that is a little more “setup” for a sbt90, like maybe has a 3 volt fet driver in it already and I can just swap led, ream reflector/insulate, and maybe bass the sprinngs).
I have gotten some advise from some others about using L21a host for sbt90 and doesn’t sound too bad, actually sounds a little easier then say using the 4×18a light and having to switch drivers and switches. Maybe I can find a larger host out there that’ll work.
Boaz
Boaz's picture
Last seen: 8 hours 47 min ago
If the mind is the devils playground .Does that explain the swing set and monkey bars ?
Jack Kellar
Jack Kellar's picture
Last seen: 3 hours 46 min ago
What exactly is “evening”?
Let me expand on it: here in Brazil we have no concept of evening as native English speakers do. We only have terms for afternoon (tarde) and night (noite), and even during the sunset we still consider the time of day to be afternoon. On English study we are taught to say “good evening” when greeting people in the early hours of the night, such as between 7 and 11 PM when the sun has already set and there are no traces of its light in the sky (“good night” is taught strictly a farewell, not a greeting). Depending on the time of year and whether DST is in effect, some of us more or less jokingly say for example “sete da tarde” (seven in the afternoon) when the sun is still up in the sky during the summer, at a time that (at least for us) is pretty late and in any other time of year it’d be nighttime.
I’m guessing this has to do with latitude differences, as sunrise and sunset are universally shorter for us than for Europeans or US and Canada folks. The time between the sun touching the horizon and ambient light being too dim to do anything with ranges from 3 to 30 minutes; for the majority of our population it lasts between 15 and 20 minutes.
(On the other hand we have a time of day that has no easy English equivalent – madrugada, the set of hours between midnight and dawn. I’ve heard of this period in English being referred to as “late hours” or “witching hours”, but it’s most often purely considered night.)
Lightbringer
Here we call that zero-dark-thirty.
Jack Kellar
Yep, that one too, or its twin “o’dark-thirty”.
Sadly that doesn’t answer the main question.
Lightbringer
Wellp, “eve” (“evening”) was always considered “the night before”, presumably when people were still up and about.
“Christmas Eve”, “New Year’s Eve”, “All Hallow’s Eve” (Hallowe’en), etc., are well-known examples.
Midnight was when the day would change (ie, no longer Christmas Eve but Christmas Day), so that limits the “eve” part to before midnight, but when still dark.
Why only the nighttime before, and not include the afternoon or the whole day before? ‘Cause it’d be called “Day Before Christmas”, then.
pennzy
pennzy's picture
Just tell me when it is beer-thirty.
Lightbringer
Funny you mention it, as I just knocked off some Warsteiner. My treat for today…
pennzy
pennzy's picture
I’m about to grab a brew myself. Cheers.
Lightbringer
Beer
Starkm32
Starkm32's picture
Last seen: 32 min 29 sec ago
Would someone suggest a 12V car charger that is pro-rated for a 10A draw? Thumbs Up
TIA
Bwana
Last seen: 39 min 23 sec ago
I have not heard the expression All Hallows’ Eve in many moons . I was beginning to think it faded into obscurity .
Lightbringer
Oh, no. I’m keeping it alive, even if I have to do it all by myself.
