Any OZ Sydney guys that can change the BLF GT LED to 5700k?
22 posts / 0 new
Far Thrower
Last seen: 2 weeks 2 days ago
I love the BLF GT but the LED is too warm for my taste as it is for many guys that bought one.
Are there any talented modders in Sydney OZ that can change the LED to 5700k or 6000k for me?
I will pay a reasonable amount to have it done.
Edited by: Far Thrower on 02/24/2018 - 16:33
Nicolicous
Nicolicous's picture
Last seen: 44 min 24 sec ago
i will have a go with mine this weekend.
i suspect the head is glue and need to use rubber tube wrench to undo the head.
Far Thrower
The head should not be glued on.
The rubber gasket holds the front bezel on without glue as it is usually pretty dry.
I hope you succeed in your quest.
Nicolicous
once i get the head open the rest is easy.
I have new LEDs E2 3C (ordered from Cutter.com.au) which is far more superior than stock LED BLF GT
Nicolicous
Few people open the head using rubber wrench method.
http://budgetlightforum.com/node/57676?page=3
I just ordered the wrench on ebay and hoping it gets here by friday (https://www.ebay.com.au/itm/2Pc-Multipurpose-Wrench-Adjustable-Rubber-St...)
where about in Sydney are u locate?
Far Thrower
Southside of the Airport.
Where are you?
Far Thrower
What temp is that LED that you have got?
Nicolicous
Yagoona… about 40 minutes away from u.
let me do mine first and see how it go. The hard bit is opening the head and im waiting for the wrench.
I believe it’s 5000K (XHP 35 E2 3C )
Far Thrower
I went to school at Bankstown and lived there for 40 years.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 17 min 26 sec ago
I can do it but I don’t have the led? Do you already have the new led? Do you want to keep the original led board?
Far Thrower
I do not have the LED yet.
The driver board is probably going to stay.
Why change it?
LSX
LSX's picture
Last seen: 22 hours 5 min ago
The head is easy to get open, I have had the head and bezel apart now.
I used a bench vice with rubber jaws and a strap wrench to get the head open, and two strap wrenches to get the bezel off.
Why change it?
I mean the board the LED sits on? Will you buy an LED already on a board or use the original MCPCB? Mean i would have to reflow the LED onto the old board.
I stopped reading the GT thread along time ago so i am not sure what sizes they are using for the LED and driver.
The stock driver will be fine if you are replacing the LED with the same LED XHP35.
Nicolicous
im having extreme difficulty trying to open the bezel with the rubber wrench.
Will give it ago again later
Heat it up? Don’t go to crazy with the heat just enough for the loctite to loosen up.
Nicolicous
dont want to use heat as im worry about the heat pressure can crack the glass.
will try warm water (about 50 degrees) tomorrow.
I think the wrench is just bad with griping….i will look for another type.
FmC
FmC's picture
Last seen: 2 hours 52 min ago
There is no Loctite used on the GT threads.
Then it should be easy enough to get apart lol.
Do you want help?
FmC
FmC's picture
Then it should be easy enough to get apart lol. Do you want help?
Me? Already done mine, thanks.
I wouldn’t say it was easy, though. It took a ~40cm extension bar on a strap, with the torch held in a vice, before it budged.
I guess it all depends on how much Wheaties the Lumintop employee had that morning when they tightened it up….
Nicolicous
I’ll give it ago again tonight and wanting to handle with care.
Hate scratches or dent to my torches Big Smile
Asking nick if he needs help.
Yea some people took there of easy.
Strap wrench doesn’t have the most grip it will slip with out much force. I guess that may also depend on the quality of the tool.
Nick what about trying a clamp? Like an F clamp?
Far Thrower
Why change it?
I want to use the same XHP35 but in the 5700k tint.
I could send the head if you already have a GT there to test it on.
What area of Sydney do you live in?
I live just south of Sydney Airport.
I might be able to bring it over to you.
Mark
