Review: Nitecore HC65 (Multi-Beam Headlamp, Red, HICRI, XM-L2, 1x18650 Rechargeable)
8 posts / 0 new
Budda
Budda's picture
Last seen: 1 week 2 days ago
I received the Nitecore HC65 from Nitecore for the review
The HC65 is a versatile headlamp, featuring a flood HICRI beam, a flood Red beam and a throwy beam. The headlamp is powered by a single 18650 and is rechargeable via micro USB. The HC65 comes in this box In the box: the Light, micro USB cable, a 18650 3400mAh battery, spare o-rings, manual, headband The HC65 shares some designs element of the HC60 The headband is made of plastic with some rubber elements molded in that keep the light in place On one side of the headlamp you have a regular tailcap, with anodized threads, that encloses the slot for a 18650 battery. On the other side there is a double stage switch with rubber cover, underneath it the micro USB port for charging the battery The HC65 next to the provided battery As before mentioned, the light has different LED emitters: a red one, a flood HICRI one, and a XM-L2 in a smooth reflector (in reality there is a small blue LED that acts as a battery indicator and is positioned nearby the RED and HICRI one). With the headband Beamshots Wallshots Outdoor shots Output and runtime Tested with the provided battery .. .. My thoughts The light is well built and finished. I like the UI with direct access to last used mode, highest, lowest mode. I am usually not a great fan of red beams, but on the HC65 the red beam is quite bright and with a perfectly flood beam (IE no artifacts or shadow cast); and the same beam quality is found on the HICRI mode. They both have a small output of few lumens, enough to see around you in complete darkness, or to do closeup work in the darkness without being blinded and preserving low light vision. For seeing at further distance and for high outputs, you still have the XM-L2 emitter in the smooth reflector. Although even this beam is quite usable for walking around, since the spill arrives at your feet as you can see in the beamshots. I don’t like so much the fact that the headband mount is “proprietary”, and the fact that if you are a unorganized person (as myself), you could lose the tailcap during the charging process. Regarding this, I would like that tailcap to be secured to the body via a small string of glued cord. The battery indicator / locator are easy to understand and useful. I wish the red and the HICRI modes had more brightness and more outputs, and the XM-L2 came in a NW tint. Thanks to: AntoLed for the camera help and the luxmeter.
All my reviews, in italian and english, here: Lumenreviews.com
Edited by: Budda on 02/13/2018 - 17:36
MascaratumB
MascaratumB's picture
Last seen: 3 hours 26 min ago
Thanks for your review Budda!!
According to what you said, are there “shortcuts” to turbo and ML modes?
This seems a very nice light! Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
SKV89
Last seen: 12 min 37 sec ago
Looks like an interesting light. Too bad no WW/NW version.
Budda
Budda's picture
Single complete press: last level
Double complete press: turbo
long half press: Hicri
long complete press: red
MascaratumB
Budda wrote:
MascaratumB wrote:
Thanks for your review Budda!! According to what you said, are there “shortcuts” to turbo and ML modes? This seems a very nice light! Thumbs Up
Single complete press: last level Double complete press: turbo long half press: Hicri long complete press: red
Thank you for the information Budda!! Thumbs Up
OL Contest 2019
GIVEAWAY: 1 / 2
M78
Last seen: 1 hour 27 min ago
They should have had a small magnet in the tail cap which would have taken care of storing the cap while charging. Could just take it off and attach it to the side of the light. 10 cent magnet would do the trick.
Budda
Budda's picture
I correct a mistake in my review: the shortcut to turbo is not a “momentary on”, but a regular turbo mode.
Beachlogger
Nice review, I like nitecore headlamps. Looks like it comes apart fairly easily
