LED test / review – Luminus SST-40-W Specialty White N4 BA (+ dedomed) – Here it is, the next gen XM-L2!
48 posts / 0 new
LichtAn
Does Luminus mark the cathode or anode with the dot on the corner?
The_Driver
The_Driver's picture
Last seen: 4 hours 46 min ago
See Datasheet…
Narmattaru
Narmattaru's picture
Last seen: 12 hours 6 min ago
thanx SO much for time spent on this
 viele, viele danke fur Seine Werk.
that gave me all info, i wanted to know
seems that one of CONs about LowCRI is not actual now
"How to choose flashlight, Main things in simple words":http://budgetlightforum.com/node/68418
The_Fat_Controller
The_Fat_Controller's picture
Last seen: 1 week 1 day ago
Sorry i know this is an old thread
Does anyone know what the full codes are for the top bins ?
it doesn’t appear in the datasheet anywhere but they state that an N5 & P2 flux bin exist
Nikon
Last seen: 1 month 1 week ago
Tell me, please, how to do dedoming this diode? I soaked it in gasoline, but it does not change. I kept it in a boiling nitro solvent, and in acetone, but the silicone dome does not change. It does not become friable and cannot be removed, as the hairs break off.
Agro
Agro's picture
Last seen: 2 hours 15 min ago
I don’t think anyone has posted a working chemical dedome procedure.
Slicing is the way to go.
Hoop
Hoop's picture
Last seen: 12 hours 43 min ago
From OP: “In dedomed state the SST-40-W is less efficient than a XP-L HI V3.”
The graphs do not appear to show this. The output of the dedomed SST-40 is marginally lower for a given current, but its Vf is much lower, around .5v lower at higher currents. At 6 amps it is using around 3 watts less power but producing almost the same output.
Agro
Agro's picture
And Luminus has updated the production process of SST-40 since the Koef3 test.
There was one known change – they use tougher bonding wires which increases current carrying capability (SST-40 seems FET-safe with 18650 now). There may have been others.
I haven’t seen a newer test of this LED and I think it would be really useful…
djozz
djozz's picture
Last seen: 23 min 40 sec ago
It is my day off so I had some time. I tested the 5000K SST-40 that I retrieved from my Wildtrail D80 V2, on its own Palight 20mm DTP board. So I did not do the reflow myself and trusted on Wildtrail’s reflow. The rest was standard procedure. I did not make a nice comparison graph, but it is easy to get the picture.
So the bond wires blew at just over 9.5A which is not much different from my test 2.5 years ago (link), and from what koef3 found in the OP of this thread.
The voltage curve is almost exact what I found for the led that I tested 2.5 years ago.
Further, I now found a maximum (2300 djozz-lm at 8A, mind that this is a 5000K led as opposed to the 6500K led of the previous SST-40 tests), while the earlier tested SST-40 leds kept increasing output until the bond wires gave in. It can be a bad reflow by Wildtrail, but my feeling is that it is real. In the picture below you can see, apart from the toasted bond wires, that the dot pattern on the phosfor is different from the original SST-40, so Luminus gave the SST-40 quite an overhaul, which may just have influenced overcurrent performance.
djozz
djozz's picture
I unsoldered the test led and although they did not use an overly large amount of solder (me I’m pretty bad at that Facepalm ), it seemed that the whole thermal pad was covered fine.
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 3 hours ago
Beautiful test! Dot pattern like on old XP/XM emitters.
We need larger emitters with super lux performance.
Agro
Agro's picture
Thanks a lot djozz!
The results are disappointing…
CRX
CRX's picture
Last seen: 37 min 12 sec ago
Thanks, I just received an SST-40 N5 DD Neutral White 5000K from KD, now I need another host to try it in.
djozz
djozz's picture
Agro wrote:
Thanks a lot djozz!
This is just one led tested, as always, I may have got a lower performing one, or there was indeed an air gap under the thermal pad.
EasyB
Last seen: 3 min 17 sec ago
I have some new die size measurements to report. Based on lumen output and throw measurements in the same light I have supposed that the SST40 die size is larger than the XPL, but I’m not sure there has been a direct comparison done. I used calipers to measure the die size of a dedomed SST40 N4 (6500K earlier gen) and of a dedomed XPL V6. The SST40 is 2.06mm across so 4.23mm^2 and the XPL is 1.93mm across so 3.73mm^2. This is about consistent with my observations: at the same lumen output the SST40 beam intensity was about 10% less.
SKV89
Last seen: 1 hour 7 min ago
Djozz, I'm wondering if Luckysun used an older version of the SST40 because I got 2,121 lumens with the Astrolux C8 Copper. OTF lumens should be 20% less than emitter lumens so actual emitter lumens should be about 2,550 lumens.
Astrolux C8 Copper Mode 7 2,121 lumens 6489K -0.0057 DUV 68.1 CRI   -11.6 R9 41.9 R12 60 Rf 99 Rg VTC5D
Astrolux C8 Copper Mode 6 1,233 lumens 6489K -0.0060 DUV 67.7 CRI           VTC5D
Astrolux C8 Copper Mode 5 609 lumens 6339K -0.0045 DUV 67.8 CRI           VTC5D
Astrolux C8 Copper Mode 4 218 lumens 5363K 0.0068 DUV 67.0 CRI           VTC5D
Astrolux C8 Copper Mode 3 71 lumens 5151K 0.0105 DUV 66.8 CRI           VTC5D
Astrolux C8 Copper Mode 2 11 lumens 5146K 0.0098 DUV 66.6 CRI           VTC5D
Astrolux C8 Copper Mode 1 <1 4890K 0.0098 DUV 72.1 CRI           VTC5D
djozz
djozz's picture
Of course: how old is old?, but at least the SST-40 from the D80V2 is a 5000K version and that is not very long on the market, and it shows the alternating dot pattern on the die unlike the oldest SST-40’s that have a square grid dot pattern.
