Mecarmy New Releasing: Irregular USB Rechargeable Flashlight (FL02)
15 posts / 0 new
mecarmyflashlight
mecarmyflashlight's picture
Last seen: 3 weeks 5 days ago
Mecarmy’s first Irregular flashlight, whole body is made by Titanium, same to most of Mecarmy flashlights, it is micro USB rechargeable as well. Compact design but it is a multi-modes and bright light, max 360 lumens, respective modes are Turbo, High, Med, Low, Stobe. Considering it also can be your good choice as a keychain decoration. We make it many optional patterns, let’s know more…
Primary features:
-Patented irregular keychain flashlight,
-Made of TC4 titanium, lightweight, portable, corrosion resistant with high hardness
-Utilizes CREE XP-G2 S4 LED, max output 360 lumens
-Max runtime of 8 hours
-Max beam distance of 64 meters
-Standard Micro USB charging port with charging indicator
-Four lighting modes and Strobe function
-Unique titanium switch prevents accidental activation
-Triple clicks to access Turbo mode, click again for Strobe
-Powered by 120mAh lithium polymer rechargeable battery
-Overheat protection
-Anti-scratch double coated lens
-Smooth reflector
-Titanium protector for light head and core components
-CNC precision machining
-Multi colors available using different surface treatment
-IPX5 waterproof
Dimension:
-Length: 67.15mm / 2.644’’
-Width: 20.4mm / 0.803’’
-Thickness: 12mm / 0.472’’
http://mecarmy.com/product/details/251/298
www.mecarmy.com
Main products are Mini USB rechargeable flashlights,Tactical light, EDC knives, Tactical gear
Edited by: mecarmyflashlight on 02/26/2018 - 03:13
chinooker
chinooker's picture
Last seen: 2 min 46 sec ago
That could have been so much more. Sad
I hope it evolves.
saypat
saypat's picture
Last seen: 3 hours 50 min ago
120 mAh battery???
lumenzilla
lumenzilla's picture
Last seen: 1 week 1 day ago
They look great Love
www.lumenzilla.com
raccoon city
raccoon city's picture
Last seen: 57 min 6 sec ago
Looks like a knife handles...  :-)
chezz
chezz's picture
great design, nice to see something a bit non-traditional with some unique outside the box thinking. will you possibly be making a high CRI version, or a maybe Neutral White version ?
AlexGT
AlexGT's picture
Last seen: 1 hour 37 min ago
When I first read “Irregular” I was thinking second grade quality or with defects in the finish… Maybe a more appropriate name would be “Asymmetric”
djozz
djozz's picture
Last seen: 5 hours 8 min ago
Not my taste, I’m particularly fond of symmetry, but nice different from the crowd! Smile
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
zelee
zelee's picture
Last seen: 4 hours 44 min ago
it need blade add on
Don’t mistake my kindness for weakness.
I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me.
Gebe
Last seen: 1 day 16 hours ago
Yeah, put a knife blade on the opposite side of the action button. Would be cool and make it more symmetrical not to mention handy! Smile
leaftye
Last seen: 1 hour 22 min ago
It looks expensive. I see six operations if it’s done on a 3 axis mill, although four of those operations could be combined on a 4-axis machine, and that’s just for the main body. The inside corners are surprisingly sharp, which makes me think they’re starting with castings, especially since the area in front of the switch doesn’t appear to be blended symmetrically. I still see the same number of operations though, so those corners just make it more expensive. This light doesn’t do it for me, but I like seeing something different being attempted. If they keep playing with this concept, maybe they’ll come up with something I can’t resist.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
CRX
CRX's picture
Last seen: 1 hour 2 min ago
I almost like this design, but not 100% on it.
bansuri
Last seen: 22 min 3 sec ago
I bought an SGN3, loved everything about it but the PWM made it unusable.
For the record: I don’t mind PWM when it’s fast enough that I can’t see it, but the SGN3 was rough on the low levels.
This looks like an interesting keychain light, doesn’t need a giant battery if you’ll just use it occasionally.
Please consider using higher PWM frequency on this attractive light and an emitter that is worthy of the effort that will go into making this.
Mayor Glenn Welsch: There's a saying in Missouri, if you don't like the weather just wait five minutes. In Blaine, with hard work, I think we can get that down to three or four minutes.
Tjohn
Tjohn's picture
Last seen: 5 hours 24 min ago
Location: the grid fringe ~ 5.134-35.572..Backwater Brazil
Do we have any idea what pair of emitters the upcoming PS14 will use, can they be easily swapped, and is this concept going to expand to other models.
Will it use PWM?
Will PVD be used to color the titanium models?
What kind of output from AA cells?
Edit: info sent today by email with a pre-order discount coupon.
The PS14 is an AA-sized EDC flashlight, it comes with a USB rechargeable 14500 Li-ion battery. You can choose the preferred color temperature from cool white and neutral white, or both of them working together with a max output of 1200 lumens. We got it crafted from two materials Aluminum and Titanium
Better yet, why not a PT16 with a toggle between/adding Nichia E21a 9080 on Clemence’s MCPCBoards, ready for the RBG emitters from the family coming up.
PS14
MascaratumB
MascaratumB's picture
Last seen: 3 hours 31 min ago
Will it use PWM?
“PS14”:http://www.mecarmy.com/product/index/261
These threads are about that light, but no further information was given about those questions! Maybe you can post your answer there please? Wink Therefore pandapanda may be answering that Beer
http://budgetlightforum.com/node/57791
http://budgetlightforum.com/node/59704
DB Custom said: "Hide your billfold, cut up your credit cards... you're a perfect candidate for full blown flashaholism and will soon need dedicated flashlight cabinets. [...] Have fun! Modding is next... :P"
REVIEWS : Amutorch S3 - XPG3-S3 /  AM S3 vs Neal 219c  /  Amutorch AM30 - XHP70.2 / Nitefox UT20 / Sofirn SF14 & SP10A / Sofirn SP32A / Sofirn SP10B / Odepro KL52 / Acebeam H20 / SS AAA / Wuben TO10R / BlitzWolf BW-ET1 / Odepro B018 / DQG Slim Ti
Mods and tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7                         Convoy S2+ TIR Lenses on: XML2 / XPL-HI                             Others: Convoy S2+ Mini (Biscotti 3 & 1*7135)
Sofirn K6 Discussion: 1 / 2 / 3                                Triple TIR Lenses & XP-G2                                     MY GIVEAWAY = ACTIVE
