[♛ FreemeGB] ASTROLUX MF04S (XHP70.2) & MF04 (XHP35 HI) - Official Group Buy Thread - 【 $150 】
1118 posts / 0 new
Tombird83
Last seen: 1 week 3 days ago
Two of my interventions have been marked as rude. I want to know what the reason is.Truth is rude? Thank you
djozz
djozz's picture
Last seen: 28 min 7 sec ago
Hi Tom, do not think too much of getting a few rude marks, ignore them and in a few days you are back to zero . Every time someone writes posts that disagrees with someone else, all of a sudden rude marks appear, I had that happen too. Although in the forum rules it is explained very well what he button is for and explicitly what it is not for, some people misuse the button if they just do not like an opinion. Our administrator in the end decides what to do with posts and people who are marked rude and he will sort out what is really going on. Still the button has proven to be very useful for the administrator in signalling bad behaviour on the forum so he can act upon it, so overal the system works well.
KawiBoy1428
KawiBoy1428's picture
Last seen: 11 min 40 sec ago
The E4 bin XHP35 that’s been de-domed hasn’t been tested for Lumen output that I can find. But my GT with the de-domed E4 at 2.5 amps and 3amps shows more throw than the other stock GT that I had (before changing it into a Lumen Monster XHP70.2)) with what ever binned LED was in the Stock GT and more throw than the E2-3A HI I had in it at 2.5amps. Nobody else has one like it, so it’s worth it to me, and that’s all that matters Wink I bet it will smoke your stock GT! Cool
KB1428 “Live Life WOT”
JasonWW
JasonWW's picture
Last seen: 32 min 43 sec ago
Agro wrote:
JasonWW wrote:
Agro wrote:
How will a slightly deeper reflector work?
Astrolux is also likely to push the current up.
We already know there is no benefit to making the reflector deeper.
That’s strictly incorrect. What was determined is that it’s a good size to performance tradeoff, not that deepening it doesn’t help.
1. Deeper reflectors have smaller centre opening and therefore more area, so they throw better. Not much though.
2. They collect more light into the beam making it wider while narrowing the spill. We’ve seen complaints that the spill is blinding, so that may bring some improvement.
I think your technically correct.”
The best kind of correct.
Silly
Hardusvd70
Hardusvd70's picture
Last seen: 2 weeks 3 days ago
Silly
This is an example of depth/diameter ratio vs lux and spill angle
Hardusvd70
Agro
Last seen: 3 hours 49 min ago
Silly
Nice!
And where’s GT?
Nicolaas
Last seen: 1 day 8 hours ago
As I’ve read in this forum that the XHP35 HI E2 can easily (provided excellent heat dissipation/transfer) to 3A, I wouldn’t mind a driver that pushes my BLF GT to that level.
At 2,5A this led might do around 140cd/mm2 and at 3A it will do around 170cd/mm2.
That’s quite a difference.
Easy calculation: @ 2,5A – 1.142.000Cd / 140 = 8157*170 = 1.386.714Cd.
244.000Cd improvement? Yes please.
Apart from the heat transfer, the driver would need to be top notch and have an accurate heat sensor, dimming the light at a set temperature.
Suggestion: turbo at 3A, high at 2,25A.
Cheers
Nico
djozz
djozz's picture
Agro wrote:
Nice! And where's GT?
Close enough to a depth/diameter ration of 1, so going deeper will not help throw, it will make the hotspot wider Thumbs Up , the spill narrower Thumbs Up and the flashlight longer
Agro
So well into the diminishing results on intensity, with still small possible improvements to beam width. It would be interesting to also chart light collection into the main beam. I’m sure there are charts somewhere…
JasonWW
JasonWW's picture
Cheers
Nico
The BLF GT driver can do 6A easily (maybe a bit more) with just a resistor swap. So if you want to change it to 3A, you can.
Nicolaas
djozz wrote:
Agro wrote:
Nice! And where’s GT?
Yep.
A longer reflector will give a tighter hotspot, narrower spill and a larger corona.
Example deep reflector: Thrunite Catapult V2/V6.
Example shallower reflector: Olight M2X.
Cheers
Nico
Nicolaas
Cheers
Nico
Tnx, I didn’t know that!
Now all I have to do is get someone with the right skillset to do it for me. “A man’s got to know his limitations”. WinkWink
Grtz
Nico
Hardusvd70
Nicolaas wrote:
Yep.
Cheers
Nico
That is so correct. You cannot describe it better.
Hardusvd70
KawiBoy1428
Nicolaas wrote:
Yep.
Cheers
Nico
Yes that’s correct… the M25C2 Turbo is another perfect example of your description. Kind of usless with a de-domed XP-G2 in it, weak narrow maybe 800lm girly man beam, but put a de-domed SST-40 in it at 8amps….you better like a massive Blue spill. Facepalm
On the lowest level the hot spot is washed out by the camera, this pic shows the corona and spill, the blue is not this intense, a bit exaggerated by the camera, but it still really blue. At this distance the hot spot is about 2.5”
Nicolaas
Quote “you better like a massive Blue spill. Facepalm: Unquote
Did you dedome a 6500K or 7500K SST40?
Cheers
Nico
KawiBoy1428
Cheers
Nico
The 6500k, one of 2 out of about 40 SST-40’s that I successfully de-domed. There was alot of experimentation going on too, tried different methods, fluid’s techniques, but still they kicked my ass. I hear even the Master Modder Vinh gave up de-doming the SST-40, just shaves them, I don’t blame him!
It’s actually the only emitter you would want to shift warmer when you de-dome them, but they don’t, not by my eyes. They are still too Blue for me and I’m a CW fanboy! Facepalm
I have 12 of the 7500’s from Kaidomain that I was going to swap out the XML’s in my TR-J20 just to make a BLASTER out of, but I’m so disgusted with the SST-40, the 7500’s just sit. The best I can do with them is just shave them close and polish them. Ive given UP! Big Smile
Still shaved and polished they work very well, home made HI if you will. Same with the XHP35HD E4 bin, if you don’t want to take the chance a fudging up or the time to totally de-dome them, why settle for an E2 make your own E4-HI.
a_idoux
Last seen: 3 weeks 3 days ago
Interested depending on the price.
Nicolaas
Cheers
Nico
Tnx for the tip, that will save me a lot of frustatrion. Thumbs Up
I guess its shaving and polishing then.
My skills are not up to it but luckily I now someone from the German forum that is an expert and is willing to help me out Thumbs UpThumbs UpThumbs Up
And I promise I won’t go any further with this off-topic issue…… Wink
Cheers
Nico
freeme
freeme's picture
Last seen: 3 hours 59 min ago
Prototype is almost ready!
franktv
Last seen: 8 months 1 day ago
Interested
JasonWW
JasonWW's picture
From another thread.
lusan_senna wrote:
It is come.. Cool
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.67002e8d1d1C9a&id=56716...
They are using the same exaggerated specs as the MT35/MF02 (2,700 lumen) so you know the candela (1.46mcd) is exaggerated as well.
It looks like it’s using the same 2S2P carrier as the earlier lights which means it’s probably is using a boost driver. Maybe the same as the smaller light? I would think so.
td1042k
Last seen: 3 months 4 days ago
I figure this is going to be identical to the mf02 aside from a gigantic reflector. I’m totally cool with that. I love my mf02.
Ultrafire C12 XHP70 2S 18650 Mtn Elec 6V Zener mod driver (super donut beam!)
Ultrafire C12 XPL-HI BLF-A6 FET driver
Convoy L6 Mtn Elec D4 UI driver, XHP70.2
Utorch UT02 NW
BLF Q8
BLF A6 NW
BLF GT XHP35
BLF GT (GT70 CONVERSION CW(SOON))
Skilhunt H03 NW
Astrolux MF02 NW
Astrolux MF01 XP-G3
Sofirn SF14
Sofirn SP32A
Emisar D4 XP-L HI CW
SK68 knockoff
Mini Mag Lite 2X AAA
Convoy M1 build (4X XPL 3V MCPCB, Mnt Elec FET driver)
Xenovora
Last seen: 5 days 9 hours ago
Interested depending on price!
gabby85
Interested too upon price release
freeme
freeme's picture
Looks better than i thought.
Nicolicous
Nicolicous's picture
Last seen: 1 hour 35 min ago
lusan_senna wrote:
It is come.. Cool
I suspect they are using the same driver like MF02
If price is close to BGF GT then I won’t buy it.
Not worth to mod Oops
Nico -.-
Nicolaas
lusan_senna wrote:
It is come.. Cool
Well……the reflector is slightly bigger, 124.1mm versus 118 as in the BLF GT.
The bigger the reflector, the more impact those few extra millimeters have on the throw capacity.
If the XHP35 HI (latest binning) is driven hard it would do around 150cd/mm2.
With a 124mm reflector the light could reach above 1.4Mcd.
Guess we’ll have to wait and see….
Grtz
Nico
KawiBoy1428
Nicolaas wrote:
lusan_senna wrote:
It is come.. Cool
Grtz
Nico
Nico is this a fact that the inside diameter of the reflector is 124mm?
Nicolaas
I’m as much depending on information available as the next guy but if you follow this link
And scroll down (pic nbr 3) you’ll see a schematic of the reflector indicting it is 124,1 mm on the inside.
It would also mean that it is a different reflector then the one in the BLF GT, and it looks like it when you look at the other picture (pc nbr 4) of the reflector.
Again: I’m assuming this from the pics and info available, it’s all still quite unclear.
Grtz
Nico
KawiBoy1428
Grtz
Nico
Thank you…
