Sony VTC5A 6-pack sale from Turmera Powerflagship store
4 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 6 hours 47 min ago
Link: https://www.aliexpress.com/item/18650-mod-battery-35a-vtc5a-3-7V-2600mAh-VTC5A-rechargeable-Li-ion-battery-for-rx300-vape/32831951961.html
Store link with store number: https://www.aliexpress.com/store/3110015
Bought them this Dec 22th 2017 and arrived home on Jan 15th 2018. I've recently hooked one of 'em to my (yet to publish review) Sofirn C8F discharge rig, and my initial testing has been underwhelming. A known good Samsung 30Q cell goes above 9.6 cold start amps in turbo, such VTC5A under same conditions only did ≈8.6A. Alarm bells ringed…
Picture:
They seem good to me but according to Batterybro 18650 Date Code Lookup Tool their (YJ09) production date is  Oct 9th 2016.
Hope to receive a Lii-500 analyzing charger soon, I'll be able to test their capacity. In the meantime, ¿do you think these are degraded old stock?
I just paid $24.80 (20.96€) for them but this is no excuse. Once the capacity figures come out I'll take a decision with regards to going the dispute way, but I'd like to hear from you as they seem to work well. As Duke Nukem said, damn!
Cheers Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Edited by: Barkuti on 02/09/2018 - 20:50
WTF
Last seen: 6 hours 27 min ago
There is something fishy about the date code. I found this spec sheet on the LIION Wholesale website.
https://cdn.shopify.com/s/files/1/0697/3395/files/US18650VTC5A_spec.pdf?...
Scroll down to 6.5 to decipher the date code. After the 9 there should be an electrode code.
I just got some old stock VTC6 from Tumera as well. February 2016 date code. Two of my six batteries have a day code in the 50’s. That number should not be higher than 28 unless it was one hell of a leap year.
I have a Lii-500, did two capacity tests with three of the VTC6’s and a fairly new button top 30q. The VTC6’s have a tiny bit less capacity than the 30q. Testing one of the Sony’s against the Samsung showed similar performance at low current. Direct driving three xp-l hi’s was about 15 amps for both batteries. Six xpl-hi’s and the 30q pulled about 20 amps and climbed as the led’s got hot. The VTC6’s did about 19 and slowly dropped as the led’s heated.
The VTC6’s should be the better cell but are not. I’m not happy about getting old stock or possibly high quality fake batteries but they work, don’t know if Tumera is dishonest or if they have a bad supplier. Not going to open a dispute but didn’t leave the nicest feed back. This was my first Ali Express purchase and I want to see how they react before spending any more money there.
Barkuti
Barkuti's picture
My testing was a tad hasty, I'll do some more tests like capacity on a Lii-500 in a near future.
Yes date codes seem odd, no electrode code. If these are fakes they may probably use some decent chinese OEM high discharge cell under the wrap, or also probably VTC5 cells.
Still not a bad deal it seems, but fishy stuff as you say. Can't dispute anyway, only 15 days of time frame since confirming delivery.
I'll pay more attention to this from now on.
Cheers Party
Jaded
Jaded's picture
Last seen: 1 year 3 months ago
WTF wrote:
xxx…I have a Lii-500, did two capacity tests with three of the VTC6’s and a fairly new button top 30q. The VTC6’s have a tiny bit less capacity than the 30q. Testing one of the Sony’s against the Samsung showed similar performance at low current. Direct driving three xp-l hi’s was about 15 amps for both batteries. Six xpl-hi’s and the 30q pulled about 20 amps and climbed as the led’s got hot. The VTC6’s did about 19 and slowly dropped as the led’s heated….xxx
Do you mind if you disclose the numbers for both batteries based on the Lii-500 test?
