Manta Ray on Aliexpress
23 posts / 0 new
beam0
beam0's picture
Last seen: 11 months 3 weeks ago
Some interesting flashlights and parts. I’m not affiliated with them, just posting to share because I thought they had some interesting and relevant products, also to get feedback from anyone who bought from them.
It appears they have 2 storefronts on AliExpress:
Wankedun Chain First Store:
https://mantaraylights.aliexpress.com/store/113294?spm=2114.12010612.100...
Wankedun Chain Second Store:
https://wandedun.aliexpress.com/store/707941?spm=2114.12010615.0.0.77da3...
Anyone have any experience buying from this seller?
Items I found interesting: (Non-aff links)
Mini C8:
Standard C8
  • Rectangular threads at tail cap
  • Modes: 1-mode / 3-mode / 5-mode
  • Tints: CW 6500K(1A) / NW 4300K(3A) / WW 3000K(7A)
  • Power: 8*7135 2800mA / 10*7135 3500mA / 12*7135 4200mA
XHP50 Flashlights:
  • (6500k) SMO or OP reflector
SST-40 Flashlight
  • Luminus SST-40 LED (7000k)
  • (1*26650) https://www.aliexpress.com/item/High-Bright-C8-2-Luminus-SST-40-LED-Flashlight-Camping-Light-Linternas-LED-Torch-Lanterna-Bicycle/32837735505.html?spm=2114.10010108.1000013.2.406962beeO5D2d&traffic_analysisId=recommend_2088_1_90158_iswistore&scm=1007.13339.90158.0&pvid=343dc163-1f88-4e90-ad39-d2b41ea4d480&tpp=1
UltraFire C12
  • Copper mcpcb / Brass pill
Manta Ray / UniqueFire HS 802
  • Tint choices (XP-L HI and XM-L2 versions only):
  • CW 6500K(1A) / NW 4300K(3A) / WW 3000K(7A)
26650 Flashlight Host (SMO or OP reflector)
https://www.aliexpress.com/store/product/Manta-ray-C8-2-black-flashlight...
C12 Flashlight Host (SMO or OP reflector)
https://www.aliexpress.com/store/product/Manta-Ray-C12-NEW-Version-Aluminum-Alloy-DIY-LED-Flashlight-Shell-Host-with-SMO-Reflector-Glass/113294_32855237960.html?spm=2114.12010615.0.0.29df3b83CnhVgi
XHP50/70 drivers (6V output):
https://www.aliexpress.com/store/product/22mm-3A-3000mA-1-cell-5Mode-Boo...
https://www.aliexpress.com/store/product/Cree-XLamp-XHP70-XHP70-2-6V-LED-Driver-22MM-DC6V-12-6V-2Groups-8modes-Board-For/113294_32849962062.html?spm=2114.12010615.0.0.7eff1514alw530
https://www.aliexpress.com/store/product/1mode-5mode-Cree-XLamp-XHP70-6V-LED-Driver-Board-26MM-Input-DC6V-15V-Output-6V-5000mA/113294_32839442906.html?spm=2114.12010615.0.0.7eff1514ZzSXO0
XHP35 driver (12V output):
https://www.aliexpress.com/store/product/22mm-5Mode-3-7V-4-2V-Input-1A-1...
One thing I’d like to see from them is to offer NW & WW tints for their XHP50 lights.
Some photos:
Manta Ray C8.2 (26650):
(Product link above)
Manta Ray C8.2 (2*26650):
Manta Ray C8.2 Host version: 26650 (SMO or OP reflector)
Manta Ray C12 Host version: 18650 (SMO or OP reflector)
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
Edited by: beam0 on 05/01/2018 - 23:58
Dioda
Last seen: 5 hours 52 min ago
Hi, seems we are interested in similar products Big Smile I still cant decide between the K5S, OP, NW or the Manta Ray C8.2., as both have pro and cons.
Could you link me needed parts if I wanted to make a Manta Ray host (the OP version) with XHP50.2 NW on board, and for example the LC15 driver that comes with the assembled version by default?
beam0
beam0's picture
Sure, gotta take of for work now but I’ll do that tonight with the parts I plan to use. I probably will try the Manta Ray driver.
Dioda
Cheers! At the moment im still slightly leaning to the K5S, as it has SS ring, AR coated glass already and also tint options are there, so less hassle. Now the only thing preventing me from pulling the trigger is the supposed lo-mode flash mentioned earlier, would like to know how bad that is.
Feel free to share your planned setup, I would preferably go for the OP version with NW XHP50.2 Gotta maintain those soldering skills Thumbs Up
TBone
Last seen: 9 hours 45 min ago
The first driver looks like a slightly modded 22 mm version of the 20 mm H1-A.
3A vs. 2.8A.
beam0
beam0's picture
3A vs. 2.8A.
Both are 3A “Max”
H1-A: “2900mA – 3000mA max.”
Manta 22mm: “Ouput Current: 3A(Max)”
eas
eas's picture
TBone wrote:
The first driver looks like a slightly modded 22 mm version of the 20 mm H1-A. 3A vs. 2.8A.
I don’t know what the 3x SOT-3 devices are on the battery side of the MantaRay driver, but I don’t see anything comparable on the H1-A.
beam0
beam0's picture
I see what you mean, something different going on between those two with those transistors. I’m not too knowledgeable on driver components or building drivers though, just noticed they were the same amperage rating.
I posted this in 2 other threads with discussion comparing the KD K5S to the Manta Ray C8.2:
Here are the two drivers with links to compare:
KD H1-A 3A (20mm):
Very Lo(5%) > Lo(35%) > Med(65%) > Hi(100%) Hidden Strobe: Double Click
Memory function : ( > 3 secs)
MantaRay LC-15 3A (22mm):
Very Low(20mA) > Low (300mA) > Medium (1000mA) > High(3000mA) Hidden Strobe: Double Click
Memory function : ( > 2 secs)
http://budgetlightforum.com/comment/1278401#comment-1278401
http://budgetlightforum.com/comment/1276918#comment-1276918
TBone
Jensen567 has done a lot of work on the H1-A and the H2-C. He measured 2.82 A.
beam0
beam0's picture
TBone wrote:
Jensen567 has done a lot of work on the H1-A and the H2-C. He measured 2.82 A assume that’s why the 3A is just “Max” spec.? The Manta Ray probably doesn’t quite do exactly 3A either in real use.
TBone
Don’t know. If they use a slightly different sense resistor, why not? The driver chip can do up to 3.5 A.
beam0
beam0's picture
Manta Ray Host
Manta Ray 1-cell 22mm Boost Driver
XHP50.2 LED on 20mm Copper DTP (5000K or 4000K)
NW 5000K: http://www.kaidomain.com/p/S026576.Cree-XHP50_2-Neutral-White-5000K-LED-Emitter-with-KDLIGHT-5050-20-20mm-x-1_5mm-DTP-Copper-
NW 4000K: http://www.kaidomain.com/p/S026577.Cree-XHP50_2-Neutral-White-4000K-LED-Emitter-with-KDLIGHT-5050-20-20mm-x-1_5mm-DTP-Copper-MCPCB-6V
Centering ring/gasket
I’m not sure if the host kit includes a centering ring/gasket that goes between reflector and LED, but I don’t see any in the photos. I messaged them to find out. If not I’ll try to find out what the diameter of the opening in the base of the reflector is to get an idea of exactly which one is needed.
Here’s the ones they sell for XML that may work:
(Package “B”) https://www.aliexpress.com/store/product/8-2mm-D-White-Plastic-Insulation-Gaskets-for-Cree-XP-L
And here’s some from KD:
http: //www.kaidomain.com/p/S025067.15-8mm-L-x-6mm-W-x-0-8mm-T-White-Plastic-Ins...
Here’s a photo of what the centering ring looks like in the complete light.
_____________________________________________________________________________________________________________________________________
Also here’s XHP70.2 options for a NW LED mounted on 20mm mcpcb:
XHP70.2 LED on 20mm Copper DTP
NW 5000K: http://www.kaidomain.com/p/S026865.Cree-XHP70_2-Neutral-White-5000K-LED-Emitter-with-20mm-x-1_5mm-DTP-Copper-MCPCB-6V
NW 4000K: http://www.kaidomain.com/p/S027211.Cree-XHP70_2-Neutral-White-4000K-LED-Emitter-with-20mm-x-1_5mm-DTP-Copper-MCPCB-6V
Dioda
Looks like a solid build, are you going to glue the LED or screw it down? Which glue or type of screws would you use? Just one more detail, does the driver or the host assembly come with the driver retaining ring?
eas
eas's picture
I’ve concluded that with a good fit and proper centering ring/gasket, neither screws, nor adhesive are necessary. When the light is assembled, the bezel presses the reflector into position, which presses and holds the mcpcb.
Screws do help keep the mcpcb in place, and the thermal grease undisturbed, while tightening and loosening the bezel. But they shouldn’t be too tight, so the mcpcb can shift laterally, if needed, as the bezel seats and presses the reflector.
beam0
beam0's picture
Yep ^^^^^^ what he said ^^^^^^^ >>> EDIT: screws not necessary but can be beneficial Thumbs Up (see post by KawiBoy below)
No glue only thermal paste:
https://www.amazon.com/Arctic-Silver-AS5-3-5G-Thermal-Paste/dp/B078K52KJ...
If I can do screws I’ll try to use some Torx/Star head screws salvaged from old computer hard drives, I have a bunch of those.
Good catch about the retaining ring, for some reason I thought it was pictured but now I see it’s not, more questions then Manta Ray.
They do respond fairly quick, I asked about a bezel on a different flashlight and got a reply in a day or two.
Retaining ring usually doesn’t come with the drivers, but one usually comes with the host.
Here’s a photo showing the retaining ring in the C8.2 flashlight:
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 14 min ago
The screws keep the mcpcb from rotating and cutting the leads, which can cause a direct short and burn the driver out. I use the screws, but not so tight that the reflector/centering ring assembly can’t be floated in.
Sometimes you get Lucky, sometimes you don’t. I don’t like smoking drivers, the drivers I use are a bit expensive in my Big Lights, Direct Drive drivers, it’s usually the FET that gets smoked, I have a healthy supply of them on hand, to re-flow just in case. Buck, Boost or Linear drivers, I don’t chance it.
KB1428 “Live Life WOT
beam0
beam0's picture
Good points, thanks! And justification for screws, will try to use them then. Slightly loose sounds like will help with centering too if it would be screwed down slightly off-center, guess that’s what you meant by “shift laterally, if needed”.
beam0
beam0's picture
Stainless bezels added to store for C8 / C12 / Manta Ray C8.2
(Bright or Matte finish)
eng.oseas
eng.oseas's picture
Hello, could someone help me, I bought the driver LC15 for xhp50 but the same is not working, and I need to know a voltage value in the featured component in the photo, thank you....
Link>> https://uploaddeimagens.com.br/imagens/sem_titulo-jpg-64d410b2-af8f-412f...
Oséas V S Oliveira
L4M4
L4M4's picture
Last seen: 1 week 23 hours ago
2,65V
PBWilson
Last seen: 1 hour 57 min ago
Cool products.
Makes me wonder about building up an XHP70.2/26650 light. Hmmmmm.
eng.oseas
eng.oseas's picture
Thanks, it was this value that I had in mind, it helped me a lot … it is responsible for the control unit, and it simply was not on the plate when I received it ..
Oséas V S Oliveira
Funner
Last seen: 4 weeks 16 hours ago
What size diameter driver and board for the Manta Ray C12?
Also the size for their C8.2?
