Lexels driver compilation
281 posts / 0 new
Agro
Agro's picture
Last seen: 2 min 48 sec ago
Since I got a D4SV2 I’m a big fan of Andruil with 1634 and RGB LEDs.
Lexel, do you have any plans to migrate some of your drivers to that architecture eventually?
Lexel
Lexel's picture
Last seen: 3 days 6 hours ago
Coming soon
15mm 2S
Sponsored by MascaratumB
Lexel
Lexel's picture
was not here listed for some reason
Acebeam K30 (with mirrored tail board)
MascaratumB
MascaratumB's picture
Last seen: 15 min 22 sec ago
Lexel wrote:
Coming soon
15mm 2S
Thanks for your work Lexel! Just to let people know, this will be used in the LT Tool 25 and in some other 2xAA (soon to be 2×14500) flashlights !!
Thanks again and I’m sure other people will grab these too Wink
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Lexel
Lexel's picture
I think this will be the final version
about 3.5 hours went into the design
KevinZA1988
KevinZA1988's picture
Last seen: 3 days 2 hours ago
Lexel wrote:
Coming soon
15mm 2S
Can this driver be used to drive a UV LED in a Tool 25 with 2× 14500? Will it regulate the current until the batteries are depleted to 6V?
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
ver_ivanz007
Last seen: 1 month 1 week ago
!{width:70%}http://www.metronixlaser.de/bilder/flashlight/K30_v2.1.png!
Hi Lexel,
Will this work with Acebeam K30 GT with SBT90.2 LED?
  • My current lights: Astrolux MF01 - Astrolux S43 - Astrolux FT03 - Convoy L6 - Nitecore MH20 - Nitecore TIP - Nitecore TUP - Convoy M3 - Convoy C8+ - Astrolux C8 - Astrolux MF01 Mini - Full Copper - Acebeam K30GT SBT90.2 - Massdrop tool AAA Copper and Brass - Nitecore Tip2
Lexel
Lexel's picture
KevinZA1988 wrote:
Lexel wrote:
Coming soon
15mm 2S
The FET has no current limitation, the small current resistors have current limiting function but no regulation and are only useable with 6V LEDs
Hi Lexel,
No regular 6V XHP
Lexel
Lexel's picture
OP updated
15mm 2S drivers are now ready for production
Brisco007700
I need one for my S42. Can you send me info on where I can buy one? I also have an issue with the charger in it. Can you replace this also?
Lexel
Lexel's picture
I cant replace the charging board, only option to use it without
Brisco007700
Ok. Where to buy the board with the new ui?
Brisco007700
I must be overlooking it but where do I buy the new driver from for the S 42?
JasonWW
JasonWW's picture
Last seen: 1 hour 50 min ago
Send Lexel a Personal Message with your driver request info. It’s the blue button under his name that says “Send PM”.
id30209
id30209's picture
Last seen: 7 min 25 sec ago
Lexel wrote:
OP updated 15mm 2S drivers are now ready for production !{width:70%}http://www.metronixlaser.de/bilder/flashlight/15mm_LX_2S_v1.0.png![/quote]
Oooooooo PM coming
WTB Titanium 4sevens 2xAA tube
oweban
oweban's picture
Last seen: 57 min 32 sec ago
Okay, so I’ve pulled apart my MF01 driver (the buck one, v2.1) that I got from you; everything’s working fine, just re-wiring it. Just testing with the DMM and I seem to be getting 140-150 ohms between LED+ and LED-. Unsure if that’s expected behaviour; seems to be happening on both sets of emitter wires. Open to thoughts! I’m reflowing it now on a heating platform in case I’ve done something stupid somehow.
OR
Is it possible to get this image redone without the components on it, so I can trace and isolate?
Lexel
Lexel's picture
Measuring this is no defect its just that the Shottky diode gets conductive by your DMM
they respond very fast and can deliver high currents but also have a quite considerable leak current
diode test shows me one side about 0.1V the other side 2.8V
a proper test would be a current-limited source of like 1A and then measure the current in both ways
oweban
oweban's picture
Awesome, thanks mate. Was just re-doing my wiring on it, and got a short (thankfully tested before putting power to it), and have been chasing it down and then noticed that.
phew
Lexel
Lexel's picture
phew
The buck chip has no problem with shorted output, it will just leave you in the dark till its removed
Lexel
Lexel's picture
28-30mm up to 23+1 AMC driver Bistro or Anduril
Boost drivers:
UV-C and UV-C+UV-A drivers
standard is 500mA 7.8-8V for Klaran 275nm LED, 17mm 2 AMCs for 365nm LED, 20 and up to 4 AMCs for UVA
17mm UVC, UVC+A
20, 21, 22mm UVC+A
Lexel
Lexel's picture
MF01S PCB in black
vestureofblood
vestureofblood's picture
Last seen: 18 hours 27 min ago
Boost drivers:
17mm UVC, UVC+A
20, 21, 22mm UVC+A
!{width:30%}http://www.metronixlaser.de/bilder/flashlight/22mm_UVC+UVA.png!
Lexel what is the minimum input voltage that could be used for one of these larger boost drivers? Would it be possible to power an XPL with this using only 2 NIMH cells? If so what would be the maximum possible drive current for the LED?
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
Lexel
Lexel's picture
vestureofblood wrote:
Lexel wrote:
Boost drivers:
Those drivers are specific for UVC LEDs its working fine with 8V and 500mA, the chips input switching limit is 1.2A so 8V 500mA is pretty much at its limit
its >3V input voltage so only lithium battery
vestureofblood
Okay. Thanks.
Lexel
Lexel's picture
21mm buck I have made some PCBs last order and are ready to be build
Coilcraft XAL7070 Inductors in stock, for lower currents I could order XAL7030
Klx01
Klx01's picture
Last seen: 15 hours 45 min ago
Hi.i want to make anther order if posible soo i want a driver for :trunite tn42 xhp 35 led. If u can help me,please tell me the price and i will send u via paypal
MascaratumB
Lexel has been “absent” for almost 2 weeks now.
Maybe it is better for you to send him a Personal Message to let him know about your request, so that he can see it when he returns!
Lexel
Lexel's picture
Yes I got myself 3 weeks relatively internet free holidays
thefreeman
Last seen: 8 min 45 sec ago
Hello,
Would the MF01 driver with dual buck be able to support tint ramping ?
Lexel
Lexel's picture
thefreeman wrote:
Hello, Would the MF01 driver with dual buck be able to support tint ramping ?
I see no problem modding one Buck side to be on another channel for tint ramping
for moonlight and low levels there would be a shared PWM pin putting the Bucks synchronous into a lower output
the more challenge is to look into Andurils Tint ramp code to add the Buck PWM channel to the existing 2 channel tint mixing
