Water Cooled MONSTER 1500 watts
113 posts / 0 new
RattleSnake
Last seen: 7 months 2 weeks ago
This build was started almost a year ago now and is still ongoing, just one of my long term projects.
This build was never intended to be practical, its more the enjoyment of creating it and getting a functional “sculpture” at the end.
20x Cree CXA1850
16178917_1614380321911968_4555519030151613048_o
1 of the 2 240×60mm radiators
15391509_1551069831576351_4137224645975412912_o
The Solenoid
16836592_1637350562948277_7443775081223790189_o
Reflectors, what is the purpose of the cone things inside the reflectors?
16252141_1604026172947383_8475672964249215558_o
Most of what is going into it.
16992419_1642177842465549_2776055645755336060_o
FmC
FmC's picture
Last seen: 7 min ago
Can’t wait to see more of this!
No idea what the centerpiece is in the reflector – is it just hollow?
MRsDNF
MRsDNF's picture
Last seen: 1 hour 48 min ago
You are one seriously crazy guy. Love what your doing. Smile
FPV
FPV's picture
Last seen: 6 days 6 hours ago
can you make an EDC version of this?
j/k this is amazing.
djozz
djozz's picture
Last seen: 5 hours 21 min ago
lostheplot
lostheplot's picture
Last seen: 2 days 10 hours ago
are you lighting up the mcg?
sorry all images down
thanks photobucket
The_Driver
The_Driver's picture
Last seen: 5 hours 10 min ago
The cones in the reflectors keep you from seeing the LEDs directly. They might either reduce the spill light around the hotspot (if they are lenses) or they might make the spill even wider (if they diffusers). The might also be cone shaped reflectors which redirect the light to the main reflector, also minimizing the spill.
Cula
Cula's picture
Last seen: 10 min 5 sec ago
Subscribed, can’t wait to see the build process. Thumbs up from me Beer .
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 days 6 hours ago
EasyB
Last seen: 19 min 50 sec ago
Wow cool! Thumbs Up
Has anyone tested one of these high power COB style LEDs to see how much they can be over-driven?
Enderman
Enderman's picture
Last seen: 3 hours 43 min ago
You could get similar power draw and higher lumen output by using three Citizen CLU550 LEDs Smile
Up to 70k lumens 500W each. https://www.digikey.ca/product-detail/en/citizen/CLU550-3626C1-65AL7G4-B...
The_Driver
Here’s my (German) thread where I calculated that.
freeme
freeme's picture
Last seen: 2 hours 10 min ago
Guinness world record is coming. LoL.
CRX
CRX's picture
Last seen: 42 min 53 sec ago
Crazy build SmileThumbs Up
Pöbel
Pöbel's picture
Last seen: 6 hours 44 min ago
you might run into pump trouble. 1500W with 2×280s will surely exceed the maximum allowed Pump temperature.
leaftye
Last seen: 1 month 1 week ago
Where is the pocket clip?
I can’t wait to see this. I’ve wanted to do a build like this for a long time, but didn’t have the resources. It’s good to see someone actually doing it.
That shouldn’t be a problem if the pump is after the radiators unless the radiators can’t provide adequate cooling.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
Hobo
Last seen: 22 hours 50 min ago
Subscribed!
8) Lube Threads Everyday 8)
Pöbel
Pöbel's picture
the water temps in such a loop don’t differ much before and after the rads because of the high flow rate. Single digit K at max.
It’s a common misconception that you get “cold” and “hot” parts in the loop.
The bigger the difference between coolant and ambient, the more heat can be removed by the rads, but this is limited by the pump he chose
contigo
Last seen: 4 days 15 hours ago
You gonna track Elons Roadster with it?
Enderman
Enderman's picture
Nah, I calculated that myself over a year ago Smile
http://budgetlightforum.com/node/50518
When you drive it at 2x the base spec you get the 500W 70k lumens.
Still really good efficiency, over 100lm/w, assuming it is cooled properly.
Temperature difference before and after a radiator is a fraction of a degree, unless you have a really weak pump and low flow rate.
sovereignknight
sovereignknight's picture
Last seen: 23 sec ago
Subbed. I gotta see what you do with thoes CXA’s! o.O
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x6 Sk68 modded 3 Nichia 319AT, 3 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, w/ Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x6 Lumintop Tool AA - x1  x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light - x1 Lumintop Zoom 1 - x2 Zebralight Sc700d
RattleSnake
Cones are hollow.
1“>IMAG0494<sup class=1“>
RattleSnake
Enderman wrote:
You could get similar power draw and higher lumen output by using three Citizen CLU550 LEDs Smile Up to 70k lumens 500W each. https://www.digikey.ca/product-detail/en/citizen/CLU550-3626C1-65AL7G4-B...
Over 100 volts could be an issue though Silly
RattleSnake
Maybe send some morse code.
RattleSnake
Its an EK pump that cost me AUD $120ish so the quality is there.
Pöbel
Pöbel's picture
I know, I’m using the same pump. Maximum coolant temperature is specified at 50°.
1500W with 2× 280 rads will exceed 50° coolant temperature. If you only use it for short(ish) bursts and do not let the coolant reach maximum temperature you might be ok.
Adding a coolant temperature sensor + display (these are available for under 20$) might be a relatively easy fix, so you can switch off or reduce power when it aproaches critical temps.
RattleSnake
Rear panel and front panel cut, front led positions marked out.
17097933_1647045348645465_5227071254323403929_o
Chassis and fan holes cut.
16991668_1648064065210260_189564402287756997_o
Front view showing the “Water Block” in position.
16836288_1648064501876883_7019712221958287012_o
Chassis “Finished”
17191801_1659683094048357_846457505308119977_o
Frame getting painted. Metal etch primer all over then Epoxy enamel for the inside and truck bed liner for the outside.
17880417_1702110359805630_2364092567129754979_o
lichan
Last seen: 6 hours 34 min ago
Subscribed.
XD9
XD9's picture
Last seen: 3 months 6 days ago
Interesting…
The_Driver
RattleSnake wrote:
Cones are hollow.
Weird!
Maybe they are only supposed to block one’s direct view of the emitter?
Turby3Pots
Turby3Pots's picture
Last seen: 1 month 2 days ago
yep i’ll subscribe to this
