The Sceptre - PScal's quest for a superthrower
57 posts / 0 new
pscal
Last seen: 3 weeks 2 days ago
In 2014, I picked up a chrome Elephant host and turbo head. I built it up with an xp-g2 s4 2b, taskLED H6cc at 5 amps, 3 series battery holder, 78mm DX aspheric, and a wavien collar. I nicknamed this light The Sceptre due to its royal appearance.
For larger photos go here
BLF GT for reference
This light was good for about 1m lux. I never got what I would consider to be an accurate lux reading. It went back and forth beating and losing to the GT, but it appeared brighter to the naked eye.
Around the same time, I read that a worthy LED upgrade has finally come along. Time for an overhaul.
Parts purchased for upgrade:
  1. Synios LED (Best of 10)
  2. 75mm Optolife lens (A298)
  3. Mag D Heatsink slug
  4. Noctigon 32mm XP mcpcb
  5. Convoy Biscotti driver (8× 7135 but I removed 2 to make it 6× 7135)
Design constraints:
  1. MCPCB must be electrically isolated from the host
  2. Wavien collar must be re-aimed for the Synios LED
  3. The LED module shall be capable of being inserted and removed from the Mag intact. (In my previous build, the collar was glued on after the slug was secured with a set screw.)
The Build:
MCPCB mods and LED mounting:
The MCPCB was drilled to allow access to the set screw hole in the heatsink slug. I also jumped the thermal pad to a nearby solder pad to solder the cathode connection.
Arctic Alumina epoxy was used to electrically isolate the MCPCB from the heatsink slug. Since both the MCPCB and the heatsink had holes drilled into them by me, careful deburring was required.
Old pill vs new pill
Wavien collar aiming:
I scratched my head about this one for quite some time. Once the parts arrived, I used a stack of post it notes to roughly aim the collar. Then, I found a piece of 1.5mm thick prototype board. I sanded it down to the perfect height, cut it into a circle, drilled a hole in it, cut relief for the solder pads and set screw hole, and sharpied it black. I made the circle slightly larger radius than the wavien collar but still small enough to fit inside the mag so that I could hot glue the collar to this piece directly. This piece is the one I spent the most time and thought on.
Heatsink prep:
I drilled a small hole for the wires, then I drilled and tapped a set screw hole aimed such that it would be accessible with the wavien collar on the light.
The driver is simply epoxied to the back with arctic alumina.
Speaking of the driver, it needs to be powered by 4v instead of 12v. I happen to have the 3p battery holder for this host also, so it was taken out of the parts bin and put into use.
I used 22ga teflon insulated wire due to its small diameter. I did not want the wires to touch the collar – only the custom spacer. I used 18ga silicone wire between the mag switch and the Biscotti driver, and made the wire run extra long for ease of installation.
Lens upgrade – or not:
The Optolife lens fits beautifully in the FM3X head. Unfortunately its focal length is a bit short and it does not quite focus the die as well as the DX 78mm lens. I plan to do testing on both lenses with a lux meter fairly soon. For now, visually, the DX 78mm seemed better so I am using it.
The light went together great. I am thrilled with how it came out. I like how the Synios LED uses 1/3 the power of the XP-G2 and does not require a buck driver.
Measurements:
Soon.
Beamshots:
Here are 2 shots from its previous life with xp-g2 s4 2b. I know they are crap. I’ll get better ones with the new light and my BLF GT.
Thanks for reading!
Edited by: pscal on 02/23/2018 - 09:36
pscal
Got some quick shots on my patio this evening.
ISO400, f/8, 1 second exposure.
The Sceptre with Synios LED
BLF GT
Both
Foggy with Synios LED (2sec exposure)
Beamshots with Flat Black (had to adjust exposure to 2s due to atmospheric conditions, but they still turned out darker than they looked on the camera)
BLF GT
The Sceptre
Both
Shooting the Moon
pscal
First lux measurements:
The Sceptre (with depleted batteries)
Initial lux reading at 80 feet was 1,460 lux with a 10” spot. The aperture of this light is 3”.
BLF GT:
Lux reading at 80 feet was 1,640 lux with a 30” spot (hard for me to measure). The aperature of this light is 4.75”.
Round 2 measurements with Oslon Flat Black
at 25 meters (using the “peak hold” function
The Sceptre
2260 lux
BLF GT
1950 lux
At 20 meters (observing the lux meter in real time)
BLF GT 2930 lux (back calculated to 1,172,000)
The Sceptre 5800 lux (back calculated to 2,320,000) (is that even possible?)
djozz
djozz's picture
Last seen: 11 min 52 sec ago
That is looking great, and I’m looking forward to the result! I have a few of these leds and plan some modding with them as well.
-X3-
-X3-'s picture
Last seen: 1 day 9 hours ago
Wavien collar were the groundbreaking tech to double intensity quite easily and it stopped… such a shame.
Anyway, really nice aspheric light you got there !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
The_Driver
The_Driver's picture
Last seen: 7 hours 57 min ago
Nice! Thanks for the write up.
Enderman
Enderman's picture
Last seen: 21 hours 58 min ago
Excellent aspheric build, I will have to add it to the list of most power flashlights over 1Mcd Smile
XD9
XD9's picture
Last seen: 1 month 1 week ago
Very nice build!
MRsDNF
MRsDNF's picture
Last seen: 11 hours 29 min ago
Nice work on the upgrade. Thumbs Up
EasyB
Last seen: 4 hours 37 min ago
Very impressive light! So, are you happy with the new emitter? Higher beam intensity but a smaller beam size.
I’m not very confident in these readings. The lux meter I have has never measured this light very well and it measures the BLF GT super high. Measurements were taken in my house during the day. I will try to get some longer distance outdoor readings soon.
The Sceptre:
Divergence: 0.208889937283 Degrees
Divergence Distance to Measurement: 114.285714286 Feet
Divergence Distance Behind Aperture: 34.2857142857 Feet
Candlepower: 1.7716040934 Million
BLF GT:
Divergence: 0.753455749006 Degrees
Divergence Distance to Measurement: 95.0495049505 Feet
Divergence Distance Behind Aperture: 15.0495049505 Feet
Candlepower: 1.37649136683 Million
I think your measurement is high (relative to other peoples’ measurements) not because of your lux meter but because of the method you used to calculate the candela. While the method does make some sense, I’m not sure it is correct. See this thread for discussion: http://budgetlightforum.com/node/51344
pscal
Thanks for the info about measuring lux. I’ll read up on that. I do like the new emitter. This light is all about lux, so the smaller but more intense beam is perfect. I also like the lower power consumption / heat output and longer battery life that this LED offers.
Enderman
Enderman's picture
Yeah I agree, see this post specifically: http://budgetlightforum.com/comment/1053206#comment-1053206
I made that thread to explain the concept that I read about on CPF, but after some further research it seems to be incorrect.
The light coming out of a lens is not a single cone of light that diverges from one point, it is an infinite amount of light cones coming from the surface of the lens.
See image 5: http://budgetlightforum.com/node/55428
Based on this, the total lux of the flashlight is simply the sum of all these cones of light.
Since each cone behaves according to 1/d^2, then the sum of all cones also behaves proportional to 1/d^2
So in fact the light converges at the lens, not behind it.
The_Driver
Very nice! I like that you can actually see the shape of the LEDs package in the beam. 1.77Mcd is great!
You could probably still optimize it a bit though. With 75mm lens diameter with no ar-coating and this LED it should be possible to get up to 2.8Mcd with a 315cd/mm^2 LED and perfect placement of the collar. The collar can increase the luminance of an XP-G2 LED by up to 120%. This effect might actually be greater with an even smaller LED.
I would think about modifiying the light so you can use the more high-quality lens. It should make a difference with such a tiny LED because of its more accurate shape.
Pulsar
Pulsar's picture
Last seen: 1 month 4 weeks ago
I wish those wavien collars were more readily available. Pretty sweet build you got there
pscal
The initial lux readings are probably inaccurate. I will work on getting better long distance readings.
Due to the easy access I designed into the light, it is definitely possible to spend time optimizing focus of the collar. I will spend more time on that and rig a lux meter to give me real time info while focusing.
The optolife lens was a disappointment. I will take photos to show the difference. That should explain everything. At this point I plan to stick with the dx lens. Lenses get so expensive so fast. Also, part of what I enjoy about this light is the beauty of the elephant host. I don’t want to change the looks to fit a different lens.
Also, keep in mind that I am not driving the LED at 2.5 amps. With 6× 7135 chips, the LED sees 2.28 2.1 amps. I may upgrade the driver at a later time, but I am very close to the top of the curve and diminishing returns are in effect.
Thanks to everyone for the encouraging words and tips on furthering the performance of this light.
I would think about modifiying the light so you can use the more high-quality lens. It should make a difference with such a tiny LED because of its more accruate shape.
pscal
I spent some time with the lux meter and the wavien collar. I observed something unexpected due to the asymmetrical shape of the LED. I get the highest lux reading when the rectangle is perfectly centered over the rectangle. However, the die is not in perfect orientation over itself. My thoughts are that I should focus on the die itself and not the entire package / highest lux reading. I’d like to hear others’ thoughts, too. As an experiment, I can glue the collar in place both ways and take measurements, but my free time is a bit limited and I think some discussion could be interesting.
I also realized that my batteries were almost dead, so I charged them up. That should help a bit with lux. Facepalm I’m going to officially scratch the initial lux readings until things are worked out.
pscal
Here are photos to illustrate the difference between the Optolife and the DX lens. The optolife lens scatters light. These photos are taken with the same camera settings, stepped down so as not to overexpose. In person, the scattering is much more pronounced.
DX:
Optolife:
Enderman
Enderman's picture
Wow that is bad.
My optolife lenses had almost none.
What is the product code of the one you bought?
Are you sure it was plano-aspherical?
pscal
Enderman
Enderman's picture
Ok well that’s unfortunate.
Must be a defective one, or it’s bad because of how low the F number is.
My A380 an A037 are higher F.
I would recommend this one for people who are looking for a precision 75mm lens, it’s pretty cheap:
https://www.edmundoptics.com/optics/optical-lenses/aspheric-lenses/75mm-...
southland
southland's picture
Last seen: 2 days 44 min ago
Excellent build.
pscal
The Sceptre is not performing as I hoped it would. Even with fresh batteries, the lux meter gives me lower readings than my GT and from the previous iteration of the light. I suspect the LED may have been damaged or not like being overdriven. I am considering swapping back the “king” xp-g2 or installing a flat black LED. The quest for throw continues!
The_Driver
My guess it that the lens isn’t precise enough. You can check this by looking at the light from far away. The entire lens should be yellow (or lit up when turned on).
pscal
I may have to get my wallet out again. I should amend my last post to say: The quest to “throw” money at the problem continues! Cash
That Edmund lens has an even shorter focal length than the Optolife.
The_Driver
You should calculate if this lens actually makes sense with the emission angle of the Wavien collar. If the focal length is too short th lens wont be used completely which leads to less throw.
I think this is the lens used in the Mjölnir from Vinz.
pscal
Absolutely. The dx lens is right at the sweet spot for focal length and the collar.
Enderman
Enderman's picture
You’re right, the F number is too low for us with a collar.
The DX lens looks good enough.
pscal
I did a quick experiment without the collar
BLF GT 1610 lux at 80ft
The Sceptre with Synios (no collar) 1170 lux at 80 ft
The Sceptre with XP-G2 S4 2B (old style) (no collar) 1200 lux at 80 ft
So, right now the xp-g2 is winning over the synios. I’ll build up a module with a Flat Black and give it a shot, too.
Enderman
Enderman's picture
Hey @the_driver, could it be possible that the high cd/mm^2 from synios LEDs is because of the white “cup” area around the LED?
Then when we divide the luxmeter reading by the die area we get a higher number despite the die having lower intensity and the reflected light from the sides helping increase the number?
Sad
You can see from the beamshots that there is clearly a lot of light coming from the area around the LED:
This doesn’t happen with the black flat because the surface is 100% flat around the LED.
Maybe message koef3 and ask him to redo his intensity measurements after blacking out the area around the die!
That would be really unfortunate if this is the case, and our 300cd/mm^2 LEDs are false readings.
EasyB
I just had the same thought, Enderman. This method of measuring the cd and dividing by the die area does not work for many LEDs for this reason.
Enderman
Enderman's picture
This is really unfortunate.
If pscal is getting lower than the old XP-G2 then the black flat is still highest intensity, and CFT90 is second!
That basically means I wasted like $100+ on LEDs and drivers Sad
Hopefully koef3 can retest then and we can find out the true numbers.
At least now we know that for any future tests of LEDs, the area around them definitely needs to be blacked out, especially if they are not flat.
I think it may still be possible that the flat white area around the black flat could be artifically increasing the lux a little, but not anywhere near the amount for the synios.
