Test/review of DMM Aneng Mini 180
DMM Aneng Mini 180
This is a really cheap DMM with manual ranges and a minimum of functions, it is very small.
There was no box included with the DMM.
It included the DMM, a pair of probes and a instruction sheet.
The standard probes are rather tiny.
They use 4mm shrouded plugs, but they are very short (shroud about 10mm, normal is 20mm).
The battery is a small 12V type (23A).
The small probes looks large on this meter.
Display
Typical display during usage, it will only show the number.
The HV symbol is only shown in the 500V ranges.
Functions
Rotary switch:
  • Off: Meter is turned off
  • VAC: 500 & 200: AC voltage ranges.
  • hfe: NPN & PNP: Transistor tester
  • Battery test: 1.5V & 9V: They use the current input and shows current.
  • ADC: 200u, 2m, 20m, 200m: DC current range
  • : Continuity and also announced as diode, but it is not.
  • Ohm: 200, 2K, 20k, 200k, 2M
  • VDC: 200m, 2, 20, 200, 500: DC voltage range.
Input
  • COM: The common terminal for all ranges.
  • Vohm: Voltage, resistance and Continuity input.
  • mA: Current and battery test input.
Measurements
  • Volt and frequency
    • 5V AC volt readings drops 5% at about 10kHz, this do not include the 5 count error due to rectification.
    • Input impedance is 1Mohm on DC
    • Input impedance is 6Mohm on AC
    • AC range uses a single diode, i.e. DC will show a (wrong) voltage if it has the correct polarity.
    • Rated voltage 500V DC or peak AC on DC and 500V AC on AC.
  • Current
    • uA and mA range is unfused (Back of meter says there is a fuse).
  • Ohm, continuity, diode and capacity
    • Ohm needs about 1s to measure 100ohm (Manual range helps a lot).
    • Ohm voltage is 0.3V open in 20k and above ranges and 25uA shorted in 20k range down to 0.3uA in 2M range
    • Ohm voltage is 2.6V open in 2k and 200ohm ranges and 2.1mA shorted in 200ohm range and 1.2mA in 2k range
    • Continuity is slow (About 500ms).
    • Continuity beeps when resistance is below 56ohm.
    • Continuity is 2.9V open and 1.4mA shorted
    • Diode range is same as continuity and it will show ohm
    • Rated overvoltage protection is 250V AC/DC for up to 10 seconds.
  • Miscellaneous
    • 1.5V battery range uses a 37ohm resistor as load. Display shows current, not voltage, 40 is about 1.5V.
    • 9V battery range uses a 360kohm resistor as load. Display shows current, not voltage, 25 is about 9V.
    • Current consumption of meter is 0.58mA except 2k, 200ohm and Continuity where it is 3mA
    • Meter displays values down to 2.8V where it turns off, battery symbol show at 6.6V.
    • Readings will increase significantly in value below 6.2V (Shows about double voltage at 2.9V).
    • Viewing angle is good
    • Display updates around 2 times/sec
    • Will not automatic turn power off
    • Standard probes cannot be used, but banana plugs will work.
    • Distance between terminals are non-standard.
    • The meter usual need a couple of display update to reach the final value.
    • Weight is 52.5g without accessories, but with batteries.
    • Size is 100 x 51 x 23mm
  • Probes
    • Probe resistance 80mOhm for one.
    • Probe wire is fairly soft and thin, the are 60cm long.
Tear down
Two screws and the back could be removed.
3 more and the circuit board could be removed.
This side of the circuit board has the range switch, the LCD connection, the battery connections, the transistor tester socket and the input terminals.
The electronic is on this side, near the current input terminals are the 3 current resistors: 1R00 (200mA), 9R00 (10mA) and 1000 (2000uA). A bit higher up on the circuit board are the two battery test resistors 360 (1.5V) and 361 (9V), they both include the 1ohm resistor in their final resistance.
The red wire and the trimpot do not look nice, the red wire is probably a last minute bug fix and the trimpot is because the correct part was not in stock.
I suspect that the M7 diode near the common terminal is for AC rectification.
Conclusion
This is a simple and cheap DMM without any real input protection and with only a few ranges. This may be enough for some applications, but keep it away from mains voltage.
The battery test is not very useful with display of current, i.e. is 23 a good or bad battery?
Notes
This meter probably exist with many different names on it and small variations in functions.
How do I review a DMM
More DMM reviews
