Test/review of Charger Japcell BC-800S (8xNiMH)
1 post / 0 new
HKJ
HKJ's picture
Last seen: 6 hours 57 min ago
DSC_3774
DSC_3775DSC_3776
This charger can charge and discharge up to 8 AA/AAA cells with individual charge control for each cell.
DSC_3743
DSC_3744DSC_3745
The charger comes in a retail box. There is some specification on the box.
DSC_3771
The pack contained the charger, a car adapter, a power supply and a instruction sheet.
DSC_3778
The power input is the usual DC adapter.
DSC_3777
The display has 8 battery symbols with animation showing charge or discharge (It must be the same for all batteries).
The display shows “CHG” or “DISCHG” depending on selected function.
Pressing the button for about 2 seconds will start a discharge (or stop it).
DSC_3780DSC_3781DSC_3782
The battery slot are the typical two level construction.
supportedBatteryTypes
supportedBatterySizesDSC_4040DSC_4041
Measurements
  • Power consumption when idle is 0.35 watt
  • Discharges with 0.2mA when not powered.
Japcell%20BC-800S%20(eneloop)%20%231
The charger is charging with about 500mA, but do not stop when the battery is full, first some hours later.
Japcell%20BC-800S%20(eneloop)%20%232
Japcell%20BC-800S%20(eneloop)%20%233
Japcell%20BC-800S%20(eneloop)%20%234
Japcell%20BC-800S%20(eneloop)%20%235
Japcell%20BC-800S%20(eneloop)%20%236
Japcell%20BC-800S%20(eneloop)%20%237
Japcell%20BC-800S%20(eneloop)%20%238
All channels works the same way, termination is not working!
Japcell%20BC-800S%20(eneloopPro)%20%231
Japcell%20BC-800S%20(eneloopXX)%20%231
Japcell%20BC-800S%20(powerex)%20%231
The high capacity cells has exactly the same problem.
Japcell%20BC-800S%20(eneloopAAA)%20%231
With AAA cells the current is lower, but the termination is again late.
Japcell%20BC-800S%20(2xeneloop)%20%2312
With two cell in the charger I got a acceptable termination (only about 30 minutes late).
Japcell%20BC-800S%20(4xeneloop)%20%231234
Again missing termination.
Japcell%20BC-800S%20(8xeneloop)
With 8 cells on the charger this one misses termination, but the one with the thermo sensor did not.
Japcell%20BC-800S%2012V%20(8xeneloop)
The charger uses just below 1A from the power supply, that is marked 1A.
Temp2999
M1: 38,7°C, M2: 41,8°C, M3: 34,0°C, M4: 35,5°C, M5: 36,3°C, M6: 37,5°C, M7: 37,6°C, M8: 38,1°C, M9: 37,5°C, M10: 35,8°C, HS1: 44,5°C
Temp3001
M1: 51,3°C, M2: 48,9°C, M3: 49,3°C, M4: 55,9°C, M5: 55,1°C, M6: 47,0°C, M7: 54,7°C, M8: 53,3°C, HS1: 58,8°C
Batteries are full and waiting for termination.
Poweron
The charger needs about 2 seconds to start up.
Charging1NiMH
The charger is pulsing the current, looks to be about 25% for a cell, lets check some more cells.
Charge123
Here I am measuring voltage on the 3 first cells and as can be seen it will step between them. It only looks like there are four phases, how do it handle cell 5 to 8?
Charge125
Moving the scope from #3 to #5 shows that it run a separate four phase cycle on the four last cells.
TrickleCharge
There is a trickle charge pulse each 80s and it is 1.8 second long (Same size as above), with 2A pulses this gives 45mA in trickle current.
Discharge
Japcell%20BC-800S%20discharge%20(eneloop)%20%231
A single 2000mAh cell can be discharged in about 3 hours and then it is automatic charged again.
Japcell%20BC-800S%20discharge%20(8xeneloop)
The discharge is not fast with 8 2000mAh cells it takes nearly 12 hours. After the discharge the cells are charged again.
The much lower discharge current with many cells is probably to keep the charger fairly cool.
Temp3004
M1: 34,9°C, M2: 33,6°C, M3: 30,7°C, M4: 29,8°C, M5: 29,8°C, M6: 30,1°C, M7: 30,3°C, M8: 30,5°C, HS1: 40,0°C
It looks like the discharge resistors are placed in one side of the charger (Note: charger orientation is changed compared to the other IR picture).
Discharge
The discharge is with a constant current, no pulsing here.
Conclusion
It looks like the charger is missing many more termination with my test equipment connected*, than without, but it did also miss termination without test equipment connected.
The charger is useable, but I will recommend keeping track of time and remove batteries, even if the charger say it is still charging.
Notes
*My test equipment add some resistance between the cell and the charger, i.e. the cell may look older than it is.
