my own XML2, XHP50.2 HI´s, not chemical dedomed, as good as XPL HI´s
48 posts / 0 new
Lexel
Lexel's picture
Last seen: 1 day 6 hours ago
Edited by: Lexel on 02/23/2018 - 18:25
AgentSteel
AgentSteel's picture
Last seen: 14 hours 58 min ago
How did you do it? Thumbs Up
Quidquid latine dictum sit, altum sonatur
doubleone44
doubleone44's picture
Last seen: 4 days 10 hours ago
Nice slice!
Lexel
Lexel's picture
Beer its just using good German bear to develop that technique
doubleone44 wrote:
Nice slice!
the final LED is not sliced
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 13 hours ago
doubleone44 wrote:
Nice slice!
the final LED is not slived
Beer Yes that is the key I agree!
Beer in combination with right flat washer and dremmel polish tool Wink
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
Lexel
Lexel's picture
luminarium iaculator wrote:
doubleone44 wrote:
Nice slice!
I have a Dremel, but its not used for it
AgentSteel
now I see the wilkinson razor blade in the picture! Facepalm
vinte77
Last seen: 7 hours 51 min ago
Wow, nice job lexel!
ARsee
ARsee's picture
Last seen: 1 week 5 days ago
A peel washer would be handy for slicing domes off too.
Nice and clean there, Lexel Thumbs Up
DavidEF
DavidEF's picture
Last seen: 14 hours 45 min ago
It looks nice. But, how can it be as good as XPL?
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
Lexel
Lexel's picture
I mean from the surface smoothness they are even better than XPL HIs
I can do this with all LEDs
one thing with bond wires is the fine tuning
Firts attempts look like this
Bond wired cut
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 47 min ago
Sliced and then sanded/polished down with 1500 or finer with a washer as a guide to maintain width/flatness.
The silicone surface needs to be cleaned thoroughly and little bit of debris, when the emitter heats up will burn the silicone.
KB1428 “Live Life WOT”
gravelmonkey
Last seen: 5 hours 48 min ago
Wow that looks pretty tidy.
As everyone else seems to be guessing the technique, I’m going guess microtome
Grad
Lexel
Lexel's picture
and the winner is
KawiBoy1428
but yes those microscope slice machines might work as well, but are out of my budget
KawiBoy1428
Lexel wrote:
and the winner is
KawiBoy1428
WinkThumbs Up
MRsDNF
MRsDNF's picture
Last seen: 1 hour 10 min ago
Sweet. Nice Lexel. Thumbs Up
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
CRX
CRX's picture
Last seen: 25 min 52 sec ago
Looks great Thumbs Up
DavidEF
DavidEF's picture
So, when does sale start? Innocent
-Ayn Rand
vinte77
I second this, “when does the sale start?”
Yokiamy
Yokiamy's picture
Last seen: 7 hours 27 min ago
Good tip Lexel, might try it myself sometime.
Do you think it will work on XPL2 HD? It should outperform XPL-hi in my opinion
Have to buy some razorblades first, always use my Philishave Wink
Thijsco19 wrote:
a regular symptom of flasholism Big Smile
“Flasholism is the most severe form of flashlight use and involves the inability to manage your flashlight use habits. It is also commonly referred to as flashlight use disorder. Flashlight use disorder is organized into three categories: mild, moderate and severe. Each category has various symptoms and can cause harmful side effects. If left untreated, any type of flashlight use can spiral out of control.”
Lexel
Lexel's picture
Yokiamy wrote:
Good tip Lexel, might try it myself sometime. Do you think it will work on XPL2 HD? It should outperform XPL-hi in my opinion Have to buy some razorblades first, always use my Philishave Wink
Razor blade is the first step
I used a thicker washer for it as first step
Then a 2. 0.1mm thinner washer for the 1500grit paper
3. Washer 0.1mm thinner
start with 2500 grit
used 5000 then
last a very old used 5000 one
Agro
Last seen: 8 hours 16 sec ago
Looks great.
May I suggest XHP35 E4?
What’s the source of washers?
southland
southland's picture
Last seen: 1 hour 43 min ago
Nice work.
NikolaS
NikolaS's picture
Last seen: 2 days 4 hours ago
I have done this long time ago with XHP70, and used only 1000 grit sandpaper to leave the surface little bit muddy and claen everything with isopropyl alcohol. Results are amazing in terms of throw and beam looks phenomenal.
Only downside is lumens lost up to 20%…
Great work Lexel !
Yokiamy
Yokiamy's picture
Ok, i just tried it with XPL2 HD, i can confirm, it is harder then it looks.
You really have to have the good size shim and it would be nice if you have it from alu or another hard material, since the plastic convoy butterfly spacer which i used is too soft.
I (accidently) cut off the rim of the spacer and ended up quite low, but i managed to get a nice and clean cut. (Don’t know if there is any material left to sand it down to get it even flatter)
Do i see a bondwire over there ?
The result is good, but not what i hoped for, throw improved but it still shows the ugly yellow/greenish corona
Have to compare it with fresh charged cells against a XPL-HI to get real world results and see if it outthrows XPL-Hi
The_Driver
The_Driver's picture
Last seen: 3 hours 37 min ago
You need to remove all phosphor around the die to get rid of the yellow corona.
EasyB
Last seen: 4 hours 12 min ago
That would turn it into a blue corona and reduce the lumen output.
Newlumen
Newlumen's picture
Last seen: 9 min 21 sec ago
I think this is how skylumen do it too.. he shave dome on sst40 lately and it doesnt turn out green. Output is great too. Here is his sst40 shave dome led.
408486_DD-_EC32-4013-8134-628_A1_D0_CD07_A
The_Driver
You can keep a tiny layer, but practically speaking removing most of it will imrpove the beam quality.
djozz
djozz's picture
Last seen: 8 hours 43 min ago
Maybe cutting it away at an edge, say 45 degrees, makes for the best beam? Nice work Yokiami!
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
vinte77
So Lexel when are you going to start offering the dedomed LEDs for sale?
