similarities Utorch S1 Mini, Klarus Mi1c, Olight Minis, and Sunwayman
33 posts / 0 new
jon_slider
jon_slider's picture
Last seen: 19 min 30 sec ago
imo, all these lights are using parts from the same sources
Re: Utorch S1 Mini,
same model name “S1 Mini”, same timer and UI as 0light S1 Mini and 0Light S Mini,
same USB battery as 0Light S1 Mini and Klarus Mi1c (Fenix also puts their label on a USB 16340),
same fisheye/convex/aspheric lens as Klarus Mi1c and Sunwayman T16R
Same no High CRI as S Mini and Mi1c
Klarus Mi1c and 0Light S1 Mini have low battery indicator
does the uTorch S1 Mini have low battery indicator?
Of the lights mentioned, only the 0Light S1 Mini offers High CRI
I wish one of these was available with a Nichia!
joechina
Last seen: 2 days 4 hours ago
They use Cree LEDs and they get the lenses from some company. And they don’t produce batteries.
They copy from each other
UTorch S1
Head and tube one pice
Klarus
Head and tube two pieces.
The UTorch has no red switch LED IMHO, I didn’t see one in the video.
You can rebuild normaly any UI
And the Olights S1 series was long time without a good clone.
I think if you disassemble the lights they are quite different.
jon_slider
thanks for your thoughts, and for making me aware of the Utorch light by posting in the 0light S Mini thread
I appreciate you pointing out that the UTorch S1 Mini lacks low battery indicator, that is a feature my 0light S Mini does not have either. The Klarus Mi1c does have low battery indicator. As does the 0light S1 Mini.
decisions.. features, choices.. oh my!
joechina
Youre welcome!
I guess the rechargeable USB batteries have a under voltage protection as most of the good protected ones.
I hope it is similar to this
http://budgetlightforum.com/node/49984
The lamp can stop working, but you shouldn’t ruin the battery.
jon_slider
yes, I really like the USB rechargeable LiIon, and yes, they have built in protection so are a good choice for unprotected lights like the ones in this thread.
“A protective circuit is built in”
jon_slider
16340 light features
SKV89
Last seen: 1 hour 7 min ago
Wow thanks for the very detailed table. How do you determine Nichia compatible?
jon_slider
edited the feature list to correct the Ti S Mini is NW, and to show the LED types
Nichia compatibility is lacking for the Olight S Minis because the TIR is designed for the wider die XML2, though I made an exception for the Sunwayman that is also XML2, because it does not have a TIR. I did not mark the Olight S1 Mini as Nichia compatible not because of the TIR, which IS compatible, since the light uses an XP-G3, but because the Olight S1 Mini cannot be opened without damage. The ones marked Nichia compatible have bezels that unscrew easily, and use XP leds, that match the footprint of Nichias.. At least, that was my thinking. Open to corrections.
jon_slider
fwiw, the N219b 9080 LEDs from Clemence are available again, for one last time. Anyone interested, this is your chance to stock up.
see
http://budgetlightforum.com/node/60638
Agro
Agro's picture
Last seen: 3 hours 7 min ago
!{width:99%}https://farm1.staticflickr.com/965/42324372221_e1006b60a0_h.jpg!
Great comparison, thanks. It would be even better if you included light dimensions and weights.
jimmy yang
jimmy yang's picture
However, the high CRI provided by 0Light S1 Mini is a tragedy.
Cree High_green-CRI Sad
jon_slider
Good idea Smile
I dont want to take the time atm, but I can tell you that the Utorch S1 Mini weighs about 5 grams more (the weight of one USA 5cent coin), and is about 1/4” longer, than the Olight S1 Mini High CRI
I have a thread here with more info about both lights
http://budgetlightforum.com/node/60324
jimmy yang wrote:
However, the high CRI provided by 0Light S1 Mini is a tragedy. Cree High_green-CRI Sad
I agree. I could tolerate the light with a Lee 1/2 minus green filter. But I sold it and bought some Utorch S1 Mini instead, because they can be modified to Nichia.
The Olight S1 Mini has high CRI Ra, but rather low CRI R9, the Saturated Red component.
there are more photos and info about the R9 of several high cri lights here
http://budgetlightforum.com/node/59863?page=1
jon_slider
added Fenix E16, preliminary.. I invite more accurate info, for example, should I also list a Cool White option (Fenix E16R), and does anyone know if the tailmagnet is removable, and if the beam is similar to the Olight S1 Mini?
Agro
Agro's picture
Size / weight data straight from manufacturers:
Olight S1 mini 21*54 mm, 43g
Olight S mini CU 21*54.5 mm, 54g
Olight S mini Ti 21*54.5 mm, 31.5g
Utorch S1 Mini 59.4*20.6 mm, 28g
Klarus Mi1C Alu 54.5*20.5mm, 27g
Klarus Mi1C Ti 54.5*20.5mm, 33.2g
Klarus Mi1C Cu 54.5*20.5mm, 56g
Klarus Mi1C HCI 54.5*20.5mm, 26g
Sunwayman T16R 59*26mm, 30.8g
MecArmy PT16 69*30mm, 45g
Fenix E16 51*21.1mm, 21g
Olight S1 Mini Al seems too heavy, maybe they include battery?
Also Klarus Mi1C weighs less in HICRI. Big Smile
jon_slider
Thanks for your contribution!
I added the weights to the feature charts posted above also
I agree Olight S1 Mini weight is way overstated above
the Utorch S1 mini weight is understated above
I removed the lights I dont have from the list below, these are their actual weights on my scale:
these are empty weights, no battery, AND no clip. Posted clip weight separately, so people can add those in if desired. (I remove clips for personal preference, so clip weight is separate)
Olight S1 mini 21*54 mm, 21.2g clip +5.2g
Olight S mini CU 21*54.5 mm, 52.3g clip +3.2g
Olight S mini Ti 21*54.5 mm, 28.5g clip +3.2g
Utorch S1 Mini 59.4*20.6 mm, 30.5g clip +3.1g
MecArmy PT16 69*30mm, 54g
Agro
Agro's picture
I think dimensions deserve a mention too. F.e. Sunwayman is quite large for its weight.
jon_slider
thanks for the reminder, updated the chart w weights, thanks for collecting the data
Slayer1
Slayer1's picture
Last seen: 1 day 16 hours ago
Great info.
Agro
Agro's picture
Maybe-correction: E16 probably doesn’t come with a TIR but with a lens-reflector hybrid. I doubt it’s narrow, but maybe…
jon_slider
I believe the E16 does use a short TIR, but may be mistaken. Fenix calls it an “optical lens” and shows it compared to what I would call a TIR, hence I consider the E16 lens a short TIR.
As far as narrow or wide, my definition of a narrow beam includes the Olight S Mini and Olight S1 Mini. They are basically a wide hotspot, but not as wide as the spill on a conventional reflector beam. I call it narrow, because when I use an Olight as a headlamp, I have to move my head a lot, to keep the bright beam on whatever Im doing with my hands.
My only reference for the beam on the E16 is the German Video. It shows a very round beam, no hotspot, hence, I think TIR, similar to Olight beam.
By contrast the Aspheric lens of the Utorch S1 Mini, is a huge flood of even light. When used as a headlamp, I do not need to move my head, just my eyes, to be able to see everything in my hands, out to shoulder width, easily.
For my arms length headlamp use, a conventional reflector, such as on my Lumintop Tool, forces me to move my head constantly, to keep the hotspot aimed at whatever is in my hands. I do not like reflector beams for arms length. I dont like the Olight TIR any better. I consider both give me a narrow field of bright light at arms length.
these are just my thoughts, Im open to others perspective. Some people for example, might consider the beam from an Olight TIR to be “wide”, and it is certainly “wide-er” than the hotspot from my Tool, when shining across a room..
Here is an example of an Aspheric, then an Olight TIR, and a conventional reflector on a Tool.
the lights are, left to right, Utorch S1 Mini w Aspheric and 2000k E21A, stock Olight Ti S Mini w TIR and NW XM-L, Lumintop Tool w reflector and N219b 4500k 9080
Personally, Im very disappointed with the Tint of the Ti S Mini. I would sell that light for $40 shipped Conus, if anyone wants it, PM me.
Agro
Agro's picture
Here is my best guess on how does the E16 lens work.
I think the central part refracts some light, focusing it forwards. It somehow redirects outward light towards reflector, possibly using total internal reflection for that. Then reflector makes a forwards-facing beam out of it.
Regardless if I’m right or wrong about that, I really don’t think this is just a TIR.
jon_slider
thanks for the link and info
you may be right that it is a Hybrid that relies on a reflector, not just fully TIR
whatever it is or does, I look forward to someone posting side by side beamshots of the E16 and an S Mini, so we can see how the beams compare.
Agro
Agro's picture
Me too.
jon_slider
I am curious about the Fenix E16, I hope someone does a review.
Im even more curious about the Klarus Mi1C High CRI.
Glenn7
Last seen: 1 hour 10 min ago
jon_slider
Glenn7 wrote:
Olight S1R II
The S1R use a unique IMR battery with the positive and negative on the same end, to work with the magnetic charger. Its a convenient package, but, Im not very comfortable with the exposed charge ring on the tailcap..
otoh, if you want to use the light to start fires, here is how to do it:
http://budgetlightforum.com/node/55261
Also that IMR battery is UNProtected, so, BAD idea to use it in any of the S1 Mini or S Mini, that lack the protection circuit built into the S1R. I gave my S1R to one of my adult children as a house light. I did not want to keep it around, due to the non standard battery.
Agro
Agro's picture
Some more info: throwiness. Based on manufacturer data.
Mi1c Al: 0.7 cd/lm
Mi1c HCRI: 4.1 cd/lm
Mi1c Ti/Cu: 4.8 cd/lm
Olight S1 Mini Ti: 5.5 cd/lm
Olight S1 Mini Baton: 7.0 cd/lm
Fenix E16: 7.2 cd/lm
Don’t have the numbers for the others.
ADDED: I see that E16 uses XP-L HI while S1 Mini Baton uses XM-L2.
This means that with XP-L HI S1 Mini would be able to collimate the beam to very roughly 14 cd/lm. Olight optics is way throwier than Fenix one…
jon_slider
Agro wrote:
Some more info: throwiness. Mi1c Al: 0.7 cd/lm Mi1c HCRI: 4.1 cd/lm Mi1c Ti/Cu: 4.8 cd/lm Olight S1 Mini Ti: 5.5 cd/lm Olight S1 Mini Baton: 7.0 cd/lm Fenix E16: 7.2 cd/lm Don’t have the numbers for the others.
thank you! this tells me the M1c High CRI has a hotspot, like the Ti/CU
do you own these lights?:
can you share your thoughts on the Mi1C High CRI tint, maybe post a photo of it next to the Ti S Mini and Ti Mi1c
Also
for those times when Sundrop style floody High CRI beam, w No Hotspot, is desired..
Does the Aspheric lens from the Mi1c Al, work on the Mi1C High CRI? (without the shiny reflector)
Agro
Agro's picture
Also
These numbers are from the manufacturers. I am unable to answer your questions.
g_damian
g_damian's picture
Last seen: 1 hour 52 min ago
Has anyone opened E16? I have Ti version, but cannot unscrew the bezel.
jon_slider
it works like this
