Convoy L2 driver and LED options
35 posts / 0 new
ecotack
ecotack's picture
Last seen: 1 week 6 days ago
So whilst ordering a L2 late last night and with many pages open trying to find the cheapest, I accidentally bought just a host. Not a problem, but I’m not sure what I should do with it.
First thoughts was an XPL HI (because I have a couple on order), but then not sure what buck driver to use. I suppose a LD-29 would be a start, but would prefer 4-5Amp.
Second thought was an XHP35 HI, but finding a 20mm boost driver is proving difficult. Any suggestions?
Speed4goal
Mountain electronics 20mm buck driver. Keeping it in 2 cell you can choose up to 6 amps. The driver is $21 before adding other options if wanted
http://www.mtnelectronics.com/index.php?route=product/product&path=67_11...
Edit it use to go up to 6 amps. But only 5.5 now
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Satan@103TFS
Last seen: 15 min 48 sec ago
H2-C from KD with XHP 35 is another option but need some work cause the driver is 22 MM.
ecotack
ecotack's picture
I was looking at that. I spotted a measurement that showed the L2 driver hole is 21mm, so perhaps I can shave 0.5mm off all around the H2-C. I may wait until the host turns up and measure it myself (unless someone else can confirm).
ecotack
ecotack's picture
@Speed4goal, I’m in the UK so postage from Mountain electronics is usually a killer.
Yourrid
Yourrid's picture
Last seen: 7 hours 22 min ago
I put a XHP50.2 J4 in it, with a FET driver and two 26350 batteries, and I really like it! Tons of power and a pretty nice beam. It gets warm quick so you definitely want firmware with plenty of modes.
ecotack
ecotack's picture
I’ve already built a Solarforce M8 with XHP50.2 and zener mod driver with 10×7135. I also have a Convoy L6 (stock), several FET driven C8’s, some S2’s including triple builds and a random selection of odd balls. I fancied something with a little more throw.
TBone
Last seen: 2 hours 22 min ago
Living in the UK you have two good choices:
1. Wait a few more days until the new still nameless Schoki/Lexel boost drivers are ready (somewhere in this thread).
2. Try a Luxeon V with a single cell 17 mm LD-4 driver from led4power. 2500 lm @ 11 A.
ecotack
ecotack's picture
The L2 host arrived yesterday and last night I got to building.
A couple of days ago I started to de-dome a XP-G2 in petrol. Then forgot about it. 29hrs in petrol and the solder resist had started to lift at the edges. This was for a C8 build, using an old UltraFire host. I tried to finish this before starting the L2. Two switched burnt out before I spotted the screws where shorting on the copper PCB. Those solder pads on the KD PCBs are too big (or is it the screws are too big?). I thought it was the reflector to start with. Couple of fibre washers should solve that.
After that disappointment I looked at the L2. The driver bay measured about 21.4mm, so I started filing down a H2-C from its 22mm. Eventually I got it to fit. Popped in an XHP35 HI and it worked. The L2 switch is a forward clicky, so I may need to replace that. I did a quick measure at the tail and with 2 fresh 26650 it was drawing 2.6A. My Convoy L6 (stock) on the same batteries drew 5.4A. Possibly some loss in my meter. The H2-C driver also worked with 1 cell. I’m happy the build went well. Just need to try it outside tonight and see if I’m happy with the result.
Satan@103TFS
How about the the L2 with H2-C result ?
ecotack
ecotack's picture
Yes, very happy. I hadn’t had much time to check it out before. There is a bend in the road 300 meters from the gateway to our stables. The L2 hit this no problem, the L6 lights up all the way down. The C8 with de-domed XP-G2 not so much. The C8 measured 3.4A at the tail, so possibly some room for improvement (driver was lightly toasted also).
I’ll see how well my dash cam picks them out tomorrow. I have to be careful around here though. Its only semi-rural and the first time I used the LED lighting on my stables the police were called.
I’ve a couple of zoomies I’m looking to up-grade next. A Warsun X50 and X65. I’ll try another de-domed XP-G2, but from looking at my other C8 builds, I think the XP-L HI will be better.
d_t_a
Last seen: 10 min 26 sec ago
(probably off-topic, but) Why would the police be called by using LED lighting on your stables?
Pok
Pok's picture
Last seen: 3 days 30 min ago
Depending on Reflector.
I have 50+ pcs. of Convoy L2 stock (XML2 , XPL Hi ) and host.
There are 3 kinds of reflector.
1. bigger spot , less corona <<< this is the best for modding for all LEDs.
2. smaller spot , decent corona .
3. smallest spot , bigger corona <<< not suitable for small die LED dome or dedomed XPG2 , XPL Hi , XML2
I prefer XML2 U4 dedome + ATTiny25v + , 1500+-LM , 230,000+cd.
d_t_a
Pok wrote:
Depending on Reflector. I have 50+ pcs. of Convoy L2 stock (XML2 , XPL Hi ) and host. There are 3 kinds of reflector. 1. bigger spot , less corona <<< this is the best for modding for all LEDs. 2. smaller spot , decent corona . 3. smallest spot , bigger corona <<< not suitable for small die LED dome or dedomed XPG2 , XPL Hi , XML2 . I prefer XML2 U4 dedome + ATTiny25v + , 1500+-LM , 230,000+cd. . !https://i.imgur.com/aeczhAd.jpg!
Thanks for the measurements.
But I’m curious about the stock versions of the Convoy L2, I can’t seem to find specs (beam throw distance or candela CD). Would like to find out the approximate values (throw, CD) for stock Convoy L2 with XM-L2 and also Convoy L2 with XP-L Hi.
Pok
Pok's picture
In the picture , first row is stock XPL Hi with 2 × 26650.
but 1 × 26650 is lower.
KevinZA1988
KevinZA1988's picture
Last seen: 17 hours 56 min ago
Hi =D
I am also looking at this particular driver for my L2. Just a few things I need to know. I’m planning on running it with a the following output levels:
Moonlight
Low = 80 mA
Medium = 900 mA
High = 3000 mA
Turbo = 5500 mA with a 180 seconds timer which falls back to 3000 mA.
2 cells will be used at all times.
Do you think this is a wise decision?
I am happy with the stock output of 3000 mA but I find myself looking for a bit more power now and then. Please advise.
Acebeam L16, Acebeam EC50 GEN III, BLF Q8 (modded), BLF A6 (modded), Convoy L2 (modded), Convoy S3 (custom), Emisar D4, Skilhunt S3 Pro, Jaxman E2L (custom), Olight S1R Baton II Etarnal - Spring - Autumn - Summer - Winter, Olight S2R Baton II, Nitecore HC65.
fedcas
fedcas's picture
sorry, what do you mean there are 3 reflectors? how do I know which one will I receive if I buy a L2?
nkresho
nkresho's picture
Last seen: 5 hours 46 min ago
I’ve seen two different reflectors for the smooth variant. The lip at the business end (that spaces the reflector from the host) are different lengths. The smaller one allows the reflector to be pushed closer to the shelf and allows easier focusing. The longer one is more limited and might require spacers to fit, thus moving the led further back towards the batteries.
I am able to get a smaller hotspot with the short lipped version, using a thinner LED gasket. Can’t do the same on the taller one without a copper spacer under the LED, or a thicker MCPCB (neither of which I have).
I have seen that there’s an OP available too, but haven’t had my hands on one to check it out.
marsalla
marsalla's picture
Last seen: 1 day 16 hours ago
Can I use a 17mm driver in the L2?
Chatika vas Paus
Last seen: 21 min 14 sec ago
marsalla
marsalla's picture
Thank you for the link
BrySig228
BrySig228's picture
Last seen: 6 days 18 hours ago
Convoy L2 driver size 20 or 22 mm? How bout the emitter side what size is it? I just got my L2 and I was thinking of moddIng it. New driver and emitter. I might replace the tail switch too. All the results I’ve seen are from the older version of the L2.
Thank you
marsalla
marsalla's picture
does any make a 17mm retaining ring for c8. I would like a brass replacement for the one that came from the factory for my driver.
nkresho
nkresho's picture
I asked Simon and he sent a couple in my subsequent order. The aluminum one I had stripped.
KawiBoy1428
KawiBoy1428's picture
Last seen: 9 hours 36 min ago
Thank you
My 2 Newer Convoy L2 driver pockets measure 21.5-21.6mm you can run a 20mm FETDD driver which is sloppy or 22mm FETDD driver, if you just file/sand down the board a little for a tight fit, With 22mm Buck or Boost drivers the components (smd’s) might be too close to the ground seat edge. The depth of the pocket is approximately 3.5mm.
KB1428 “Live Life WOT”
marsalla
marsalla's picture
New question. What would be the best driver/emitter combo to get the best throw using two cells in series please.
Thank you
 Also: I need a good soldering iron. any suggestions.
KevinZA1988
I went for a 20mm buck driver and XP-L HI combo from mountain electronics. Pushing 5.1 A on Turbo and the throw is good. However, my centering ring is rubbish so I’m definitely going to change that because when I fasten the bezel completely it moves slightly off centre. Super annoying!
Satan@103TFS
Unfortunately “20mm buck driver” that push hi Amp is very hard to find (non US) I looking for it but can’t find one.
KevinZA1988
I’m from South Africa and had no issues with shipment. Can’t they ship to your country?
Satan@103TFS
The price +shipping is too much for me.
finnegans
Last seen: 3 months 11 hours ago
Howdy, folks. This is not intended as a thread hijack, it seemed right on-point but if it strays too far I’ll start a new thread (and come back to this post and link there for the curious); just LMK.
I’m looking to build a throwy light for boating at night — going between mainland and island on a rocky, low-trafficked (especially at night) lake. I need to be able to spot landmarks/scan the coast at distances of around 1000 feet or so. I’d be running 2 22650s all the time (for balance, to marry the cells, and because it’ll be left in the boat for extended periods), and wanted to use either an XP-L HI V3 3C (from mountain electronics) or an XP-L HI U6 4B (aliexpress — was going with the V3 3C originally but am starting to wonder if maybe the U6 4B would be better for cutting fog?), and looking at buck drivers. I’ve seen some folks have filed down larger drivers to fit the L2 — any suggestions between mountain’s 20mm and 22mm buck drivers? The 20mm has 2.5A and 3.5A output options, whereas the 22 has a 3.0A (the max current of the LEDs under consideration) if that matters.
Also wondering if I need to be talked off the ledge on this one: there’s a HK seller on the auction site offering the L2 with U6 4B for $43 — I’m open to the suggestion that for what I want, I should grab the off-the-shelf option (possibly potting it & bypassing springs) and be done with it. That one comes with an LD29 driver. If the advantages of building it myself are outweighed by the ease and savings of clicking Buy-it-Now, I want to be smart about it. I recognize that that’s a personal calculus, but are there any major disadvantages to simply buying the light whole like this?
Thanks in advance for any guidance.
