DQG 26650 button broken_need advice
14 posts / 0 new
Narmattaru
Narmattaru's picture
Last seen: 3 days 3 hours ago
Hi guys. button of DQG 26650 got broken.
I`ve searched it at ali, no success. does anyone has any idea where i can find such button?
it is 4 pin. arrrow shows where shoud be moving plastic part that broken.
i wrote to manufacturer, but got no responce at all, so i ask for help here (
"Updated list of Aliexpress coupons and promocodes":http://budgetlightforum.com/node/64307 | "How to choose flashlight, Main things in simple words":http://budgetlightforum.com/node/68418
Edited by: Narmattaru on 04/07/2018 - 14:03
djozz
djozz's picture
Last seen: 4 hours 33 min ago
I’m sure it is out there but a better picture is needed if you want help with the search.
Barkuti
Barkuti's picture
Last seen: 24 min 43 sec ago
4-pin 6*6mm Pushbutton Switches (100-Pack) @ FastTech
Quite likely one of these standard pushbuttons.
Cheers
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
djozz
djozz's picture
No, it is a side-mounted switch.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 7 hours 3 min ago
Maybe you could keep the base and replace the internals from another switch? It would need some modding.
RobertB
RobertB's picture
Last seen: 1 day 11 hours ago
I had one broken from the factory. In fact it was completely gone. Banggood sent a whole new driver.
If you find a button that would work, I’d be interested in one too, to get this broken driver working.
edit…
I found these vertical switches at Mouser. Omron makes a few thousand different switches
https://www.mouser.com/new/Omron-Electronics/omronB3F/
https://www.mouser.com/ProductDetail/Omron-Electronics/B3F-3102?qs=sGAEp...
moderator007
moderator007's picture
Last seen: 3 hours 38 min ago
Try searching the major online electronic components stores like mouser, digikey, jameco, arrow, and newark looking for a tactile switch. The rating will not matter as the current is very low in our flashlight drivers. If you can find the particular one you have, do a search for the manufacture part number. Sometimes parts end up in unlikely places you never thought to look in your own country.
It will also help to narrow your search if you can measure with calipers the size of the old one.
Dutcheee
Last seen: 5 days 59 min ago
Wow, that’s nice. I wrote them a few times in the past, but never got a reply.
If you replace the switch, I suggest to glue it in to place with a (semi) permanent adhesive in the flashlight’s head. I used Sipik, the buttons tend to break after a while due to stresses on the board solder joint.
Narmattaru
you mean to glue button to driver or to glue driver to heead?
Dutcheee
After resoldering, glue button to driver. I don’t think you have enough access to glue the button to the head.
Narmattaru
yeah, that`s what i also thought to do. thermal glue would be simplest way, but it`ll get melted with 1st use (
Dutcheee
2K epoxy would be good, but you can never remove it again. Sipik is better than nothing I suppose..
Tyzmon
Last seen: 1 week 1 day ago
I would not recommend 2K epoxy, as it shrinks while curing and will put stress on covered components. I had done this to a flashlight once and when I dropped it all components sheered off.
My recommendation for this is either some pmma glue or silastic compound, while latter is even great for potting electronic components. (Just look for „703“ or „704“ glue on the web)
TexasToasted
TexasToasted's picture
Last seen: 2 hours 10 min ago
Every switch you could want for $16 at Aliexpress.
I need #10 to fix mt Rofis MR30.
