Test/review of Vapcell INR18650 2500mAh (Purple) 2018
1 post / 0 new
HKJ
HKJ's picture
Last seen: 19 hours 19 min ago
DSC_5771
Official specifications:
  • Model: INR18650
  • Size: 18.3*65.2mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 2500mAh (0.2C discharge)
  • Min capacity: 2400mAh (0.2C discharge)
  • Weight: Max:46g
  • Internal resistance: Max:14mOhm
  • Standard Charge: 1500mA,CCCV 100mA cut-off
  • Charging Time: 2.5hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 20000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~75°C
  • Storage: Temperature -5°C~35°C, Humidity
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
Vapcell%20INR18650%202500mAh%20(Purple)%202018-info
A medium capacity high current cell.
DSC_5770DSC_5769
DSC_5772DSC_5773
DSC_5775
DSC_5776
DSC_5777
Vapcell%20INR18650%202500mAh%20(Purple)%202018-Capacity
The discharge curves looks perfect with the traces on top of each other and nearly constant capacity up to 20A.
Vapcell%20INR18650%202500mAh%20(Purple)%202018-Temp-20.0
The cells gets warm during a 20A discharge, but not too warm.
Vapcell%20INR18650%202500mAh%20(Purple)%202018-Temp-30.0
At 30A I stopped due to temperature.
Vapcell%20INR18650%202500mAh%20(Purple)%202018-CapacityTimeHours
Vapcell%20INR18650%202500mAh%20(Purple)%202018-Energy
Vapcell%20INR18650%202500mAh%20(Purple)%202018-PowerLoadTime
Vapcell%20INR18650%202500mAh%20(Purple)%202018-TripCurrent
Vapcell%20INR18650%202500mAh%20(Purple)%202018-Charge
Conclusion
This is a very good high current cell that can deliver 20A without problems.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
