Thorfire TG06S Full Package / Full review
27 posts / 0 new
robo819
robo819's picture
Last seen: 3 weeks 3 days ago
This is the Thorfire TG06S package or kit , sent to me by Thorfire for review and NO other compensation other than keeping the kit.
At the time of this review , you can get this package for 40% off with the coupon code 8YGYJ38C* *(USA ONLY) from the Amazon site …… https://www.amazon.com/ThorFire-flashlight-battery-compatiable-Included/... (link is NON afilliated)
EDIT: I guess they decided to go another route….Light only for the 40% off looks like with the code ………. 8YGYJ38C (USA ONLY)
I know there have been a number of reviews on the TG06 S light , but as far as I know this is the first time the “package deal” has been made with this light.
The TG06SS kit / package , arrived in an Amazon Box with large bubble wrap inside and the Thorfire box inside that and the light inside a bubble wrap sleeve inside the Throrfire box. The kit includes the light itself , the single cell USB charger , 2 extra O-rings and the Thorfire (protected) 14500 BRC / 750 mAh – 2.8 wh cell.
The TG06S is not changed as far as the UI or the styling or any of that since the most recent model , just that they are now offering the Kit or Package with the above mentioned items.
As for the light itself it is the quality I have come to expect for the Thorfire lights and a very well made little light , for the more budget pricing they usually have on thier products.
The light is dual chemistry capable meaning it can use a variety of cells from AA Alkaline , NiMH and Li-ion 14500 and as already mentioned the Thorfire cell does come with the light.
The light although not as small as some 14500 / AA sized lights , is still plenty small for any pocket and very doable as an EDC light.
Comparison is with an 18650 cell and the Thorfire VG15S…..
The Knurling , anodizing and machining are all well done and I did not find any thin or bare spots on the light anywhere.
The clip on the light seems pretty sturdy and is also reverseable so you can use the light on a ballcap as a headlamp if needed.
The XP-G2 emitter sits in a smooth reflector and the lens is a glass lens , although I am unsure if it is AR coated . if so it is a very light coating.
The light will tailstand but needs to be on a fairly level surface due to the cut outs or finger grooves at the end of the cap itself. The knurling is also done well on the tailcap and the switch is pretty responsive. There are lanyard holes in the tailcap also if you happen to want to use a lanyard on the light.
All the threads were lightly lubed when I got the light and all the threads are well cut and pretty smooth.
The head is threaded all the way through pretty much , because the “pill” which the MCPCB and the driver both sit in / on , screws in all the way from the back end to the back of the reflector and the driver is a constant current.
The tail threads are anodized , so you can manually lock out the light. (no electronic lockout)
The beam is pretty smooth and fairly throwy for the small light also , with a useable spill , plenty bright for using to walk with. The tint is in the cool range although not to the point of being the blueish cool , I would guess in the 5500 to 6000K range.
All beamshots were taken using the included 14500 cell.
These shots at Gray wall from 3 feet on Medium and then 10 feet in all 4 modes….
These at 75 yards from Gate in Turbo , 50 yards High and Turbo and 25 yards Medium , High and Turbo………
And finally all 4 modes at 10 yards from gate…….
The UI is pretty straight forward with the light starting in High or Turbo every time and then goes down to the next level with each half press , from what I call Turbo it is……Turbo / High / Medium / Low or Moon. The reason I say it this way , is because with the 14500 cells the lowest lumens reading I get is 6 lumens and up to 8 lumens. In my opinion that is just too high to call Moon or Firefly. With the NiMh it does go down to 2 lumens.
The runtimes are also good with the 14500 cell and I was a bit surprised it ran as long as it did with the test I did on the included cell.
Here are the charts on the testing I have done with the included cell , an Efest 14500 High Drain and an Eneloop Pro……..
Video Followed by listed specs……………..
Product description
New Features on TG06S
1. More Modes: When use premium 14500 battery, the brightness can be High(500LM) -Middle(200LM) -Low(50LM)-Moonlight (1LM ), and Strobe(500LM); When powered by AA battery, the mini light gives out High(150LM) -Middle(80LM) -Low(20LM)-Moonlight (0.5LM ), and Strobe(150LM)
2. Easier Operation. Fully press the turn on/off, tap to change modes, double tap to activate Strobe mode for emergency.
We still keep the old features on TG06S as below:
1. The lightweight makes the newly designed ThorFire TG06S fits easily into your pocket, backpack, purse, or tool bag.
2. With one considerate metal clip, you can clip it to your shirt pocket.
3. It is great for multiple indoor and outdoor applications including searching, camping, hiking, or even use as an emergency light when suffering a power outage.
4. One cooler thing is that the O-ring behind the lens glows in the dark, which makes it easy to be found in the dark.
Warranty
ThorFire promise to offer 40 days money back and worry free customer services, if you encounter with any question, please contact us.
Technical Details
Part number: TG06S
Item Weight: 1.6 ounces
Product Dimension: 4.3*2*1.6 inches
Power Source: Battery
Type of Bulb: LED
Luminous Flux: 500 lm
Batteries Included? NO
Batteries Required? YES
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 05/22/2018 - 02:32
pennzy
pennzy's picture
Last seen: 6 hours 1 min ago
Did you check the charger for ending voltage and charge rate? Always starts on high , no memory?Always like the music.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 25 min ago
Hmm, just tried the code, doesn’t work.
Bummer.
eas
eas's picture
Last seen: 2 months 5 days ago
Same here. Just as well. I was thinking of suggesting this deal to a friend, but I’d probably have bought one for myself, too…
pennzy
pennzy's picture
eas
eas's picture
FWIW, the listing for the bare (no battery or charger) TG06S has a 40% offer on Amazon right now.
Lightbringer
Yeah, but I wanted to try the kit.
Actually, was just looking and I see that the order is high-to-low, not low-to-high. Hmmm. Not really a fan of being blinded at night when I want low or even moonlight/firefly. That’s a bit disappointing.
robo819
robo819's picture
The ending voltage listed in the chart in OP (2.73) …….didn’t check charge rate.
robo819
robo819's picture
I emailed Thorfire about the code not working on the package last night……No reply yet
GreenLights
Last seen: 2 hours 33 min ago
H-M-L and according to the Amazon page you MUST use a button top if using 14500. Bummer.
Just discovered this wonderful addiction.
Persechini
Persechini's picture
Anyone has both this and the sofirn SF12 to compare? I know it has the same mode, forward clicky, emitter, but I fell like my SF12 is terribly machined, and the retaining rings get loose every once in a while, making it by far my most failed light. I’d like to know if the thorfire version fares better
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
robo819
robo819's picture
I just tried the Flat top Windyfire’s I have , they work fine and it takes a heck of a jolt straight back to get a blink out of the light. The Efest and AWT High drain button tops wont loose contact at all and of course the protected cell that came with it is even a little longer.
EDIT: I can see where it could be a problem if you use a cell that is not raised at all on top (the windyfire is very slightly raised) but the driver end is really flat where the cell makes contact so yea a button top may be best for safety really.
robo819
robo819's picture
I updated the OP but it looks like they are doing the light ONLY and not the package for the 40% off with the coupon code ………. 8YGYJ38C
I will update again when I hear anything else from them on this.
Blackbeard
Blackbeard's picture
Last seen: 5 hours 40 min ago
this is the one with bad pwm?
robo819
robo819's picture
I am not sensitive to the PWM but I just checked using a fan with 4 different speeds and also my video camera monitor and I cannot see any with either in any of the modes.
Blackbeard
thx, maybe it was a different model, thought I saw some reviews about that
robo819
robo819's picture
Don’t shoot me I am just the messenger but……….
Just an update on the 40% off code …… Light only for the 40% off using code (USA ONLY)………. 8YGYJ38C
hiker89
Hey robo,
Thanks for the great review!
One thing makes me hesitate.
Do you think the discrepancy between listed lumens on Nimh and actual lumens with an Eneloop Pro was a mistake with your light or would other lights also exhibit the same behavior? Its really weird that a manufacturer would under list the performance on turbo by 50%. 150 lumens on a good Nimh is kinda sad but ~300 lumens is pretty close to Utorch UT01/klarus mi7 territory. Maybe the 150 lumens refers to alkaline only?
If it produces 300 lumens on a nimh I’d instantly buy a few. 150? Not so much.
robo819
robo819's picture
Always glad to do the reviews Hiker…….
I just rechecked on the meter with the NiMH and the 14500’s , readings are almost identical to the first test.
With a new Duracell copper top I got 233 Lumens.
I don’t have a clue if it is all the lights or if I just got a fluke , but mine is staying consistent.
I checked a couple of other lights on the meter that I know the lumens are correct on also to be sure my meter battery wasn’t running down or anything , all seems to be spot on with the meter.
hiker89
Thanks Robo!
For 10 bucks what the heck its worth a shot. The great thing about inexpensive AA lights is that if the output isn’t quite up to par you can always re gift it to someone!
eas
eas's picture
I wouldn’t worry too much about the discrepency you’ve observed, hker89.
While lazyness, mistakes or outright dishonesty can come into play, there are plenty of much more benign reasons for differences between a manufacturer claim and an independent test.
In this case, I think you’ve probably already hit on the likely source of most of the discrepancy. If you check ThorFire’s description, they don’t specify the chemistry of the AA cell tested. I’d guess, and robo819s retest suggests that they were probably testing with Alkalines. Not surprising, since a NiMH cell can deliver a lot more power (watts) than an Alkaline.
Another factor is that the numbers may not actually mean the same thing. I don’t know about robo819, but a lot of people test with a topped off cell. It’s the easiest way to make sure different tests are being done at similar state of charge. A downside is that it doesn’t give a very clear sense of whats typical. I can’t say for sure, but from comparing manufacturer claims to peoples tests of lumens at a given current and forward voltage, its clear to me that the number some report is more like the output when the cell is at its nominal voltage (3.6-3.8v). This is in many ways a much more useful number, but it can be harder to test for.
robo819
robo819's picture
Yes I do test with the cells topped off always so I get the most consistent numbers and all cells are at their peak.
The run time testing is where I show what the cell is doing as it progresses, (as noted in charts in OP) as far as output.
I do not stop the testing once I turn the light on however to do any checking on the voltage or anything , as I always just turn the light on in the highest mode and then take measurements at the step down (sometimes at 30 seconds depending on light) and then usually at 15 minutes and 30 minutes and every 30 minutes after that until the Low Voltage warning , or cut off, and then check the voltage at that time.
wle
wle's picture
Last seen: 6 hours 40 min ago
IMHO – way too long for an AA light – 109mm!?
Geez, the Utorch ut-01 is 83mm.
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
robo819
robo819's picture
Guess they listed that wrong too………
I just measured mine to see and it is only 95mm (3.74 inches) not the listed 109mm (4.3 inches)
wle
wle's picture
maybe that was the box.
wle
-Greg Lemond.
sixfink
Last seen: 11 months 2 weeks ago
I’m using one of these, for half a year now. Nice little backup torch.
Put an eneloop in it, and be happy.
Henk4U2
Henk4U2's picture
Last seen: 6 hours 38 min ago
Swap the tailswitch for a lighted one, ditto with a nylon washer and an opaque tailcap, and presto …..
Works fine out of the box, you don’t need to add a bleeder resistor.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
