1x18650 you would hand to an idjit...
51 posts / 0 new
ValuseekeR
Last seen: 2 days 4 hours ago
Okay, been reading a lot of threads, but still getting a bit confused and dizzy from all the options. Facepalm
Hoping for some input to help narrow the search.
Where I’ve been: Have a fair number of 1xAA and 1xAAA edc type lights run on rechargables. Also an old Fenix E21.
Where I’m at: Decided to step up to having at least a couple of 18650 lights for greater output and/or longer run times. Ordered a BLF Q8, 4 unprotected 30Q cells, and a Liitokala 500 charger. I realize this is sort of a specialty/flashaholic light that I need to use with care and keep away from idjits, children, etc… So with that in mind I also want to get a good 1×18650 that will be somewhere in the middle between the Q8 and my “normal” AA/AAA lights. One that I won’t mind handing off to a buddy when his cheapo light dies or whatever.
What I’m looking for, (I think):
-1×18650 with a neutral white emitter. Doesn’t have to be Nichia, but I’ve been pretty spoiled by them in my other lights so that’s the benchmark.
-Looking for a general use light, so I guess a happy medium between flood and throw. A zoomie might be a good option, but I know little about them.
-Pocketable is a plus, maybe up to the size of the BLF X6 or Convoy C8 as the max.
-I find moonlight/firefly modes useful, and generally prefer lights that start on low or at least have mode memory.
-***Safety features.*** After some of the recent discussion, I’d like to make sure this light has low voltage and reverse polarity protection, temp stepdown, ability to accept protected cells, have a mechanical lockout/not easy to turn on accidentally, and anything else that’s recommended that I didn’t think of…
-Max budget ~$50 for the right light, but preferably ~25-$30.
-Durability and reliability is a concern. I’ve been burned by a couple lights I expected more from (dead Balder SE1 and Xeno E03 after negligible use).
Thanks in advance for any input. Also, if anything I wrote sounds ignorant or unrealistic, or if these constraints are too narrow or too broad, please feel free to tell me I’m an idjit too. We all have to start somewhere… Smile
Garth
Last seen: 1 week 3 days ago
You have answered our own query . Grab a BLF A6. Don`t over think it.
GRAY LITNIN
Last seen: 2 months 4 weeks ago
All written sounds perfectly realistic to me. May want to check out this thread if you haven’t already.
“Budget rechargeable 18650 lights”
:http://budgetlightforum.com/node/57743
Should my information be incorrect in the slightest please inform me as i am always learning as well and may not recollect everything properly. ALSO, ANYTHING I WRITE PLEASE TAKE WITH A THOUSAND GRAINS OF SALT AND YOUR OWN LIABILITY, AS YOU SHOULD WITH ALL INFORMATION.
mrheosuper
Last seen: 12 hours 20 min ago
well, BLF a6( astrolux s1) fits all what you asked
another option is astrolux s41 and 18650 tube, which is available in Nichia option, great if you want better collor
if you want a light that wont become too hot at turbo, convoy S2+ is a great option
Forgot my pen
GRAY LITNIN
S2+ is a great option. But i recommend only the 3 or 4 chip models if temperature is a concern. My 8 chip models can become hot enough that I wouldn’t recommend them if accidental activation is a concern. You can get biscotti firmware on some models (all models if you ask Simon) and will give you a somewhat moon mode.
mrheosuper
yeah, i forgot to mention that
Forgot my pen
GRAY LITNIN
Its easy to forget, too much to remember nowadays. Especially with all the options on everything. I had to edit mine because i forgot to mention Biscotti for lower modes LOL!
ValuseekeR
GRAY LITNIN wrote:
… too much to remember nowadays. Especially with all the options on everything.
Tell me about it, lol.
I’ve looked at the S2+ before, but not sure what you mean about the different chip models? What I’m I looking for in the product description if I go that route?
________________
On the A6, I didn’t mention it here (I mentioned the X6,) but I did look at it and remember reading this in the “Not just a flashlight anymore…” thread:
everydaysurvivalgear wrote:
…using high drain cells with no knowledge. Very different outcomes if you put a battery in reverse in a brand name light vs a BLF A6. The E40R i just reviewed has reverse polarity protection while the later does not.
The product description says it does have protection, but the above made me worry.
GRAY LITNIN
The chips are stacked on the board to create more light output should see something like 3×7135, 4×7135, 6×7135, 8×7135. The first number denotes amount of chips, 7135 is chip type. Lower number of chips equals less output but it wont get scorching hot if left in turbo for long periods
GRAY LITNIN
________________
Protected 18650 cells have a circuit built in that protects against shorts and other no no’s, you need to be more careful with the batteries if they are not protected should the light you choose not have protections built in.
Lightbringer
Lightbringer's picture
Last seen: 9 hours 9 min ago
Zanflare F1. Great styling (love the “spline” knurling), built in recharging, tail-clicky for on/off and side-clicky for modes, strobe is well-hidden but there if for whatever depraved reason you’d want it, available in NW or CW, has TCLO to prevent accidental activation, most bells’n‘whistles of nice lights, hella bright if you need it, 20bux with coupon-code.
ValuseekeR
Thanks on both counts Gray. Thumbs Up
Zanflare will get a look LB. Wasn’t really looking for built in re-charging, but I guess it wouldn’t hurt.
The Convoy S2+ is looking hard to beat as a budget/loaner option, but I’m not in a big hurry to make a decision. I could always end up with more than one light as well. Innocent
Lightbringer
Wellp, you said for idjits, and an idjit might stick the cell into the charger backwards, so… Big Smile
The S2+ is infinitely modifiable. Swap a 20mm TIR for the reflector. Use a shorty tube for an 18350. Stick in a triple. Etc.
That’s the spirit!
GRAY LITNIN
Of course. Just glad i can help someone during the few and far between log in’s i get nowadays. Both great light options and +1 on LB’s advice of usb charging, can’t mess up too much if removing battery is avoided.
toddcshoe
toddcshoe's picture
Last seen: 6 hours 25 min ago
ValuseekeR
toddcshoe wrote:
Emisar D4.
http://www.mtnelectronics.com/index.php?route=product/product&path=80&pr...
Thanks, that looks like a nice light, but also in the “not just a flashlight thread:
Robertb wrote:
Heck, nobody seems to care that the D4 is a potential pipe bomb if the battery is accidentally put in backwards..
I don’t know what to make of that statement, if it’s true or false, if it’s a non-issue with protected cells, etc…, but that’s the worst case scenario I’m keen to avoid. Clarification would be awesome (from anyone).
donnybrook
Last seen: 1 day 1 hour ago
I’d second (or third, whatever) the recommendation for the S2+. I have both the 4×7135 and 8×7135 versions and the difference is definitely noticeable but not huge. Up to you which one you want to go for.
If this is a loaner it would be a good idea to buy a protected cell for it. The S2+ goes into low mode and flashes when the voltage is low but that’s not really idjit-proof, which is one of your criteria. The idjit would just say “huh, it’s flashing.” There are various threads on BLF and CPF that report which protected cells fit or don’t fit in the S2+.
You will. Believe me, you will.
ValuseekeR
Excellent point Throw, I will make sure I know that one.
Thanks Donny, I meant to put in the OP that I intend to only buy protected cells. The unprotected cells for the Q8 will only be used in the Q8 as a set.
Phlogiston
Last seen: 14 hours 8 min ago
The newest version of the Convoy S2+:
https://www.aliexpress.com/store/product/desert-tan-S2-flashlight-with-X...
has low voltage protection built in, because it has the Biscotti firmware which was developed by our very own Toykeeper, here on BLF Smile
I’d still put a protected cell in it, though, just in case your idjit opens it and takes the cell out. That’s what I do with my loaner unit.
You can select any “Emitting Color” you like – I recommend the U6 3A for a nice, neutral white light output – but only go for a 7135×3 or 7135×4 “Body Color”. The other versions will run too hot for safety with the uninitiated. My loaner unit is 7135×3 and works nicely; the 7135×4 would be a bit brighter, a bit warmer, and run out of charge a bit faster.
ValuseekeR
Thanks very much Phlogiston! I think that seals it for at least one S2+.
toddcshoe
toddcshoe's picture
I always seem to forget about that protection part. I normally don’t buy or use protected cells but being as you may be handing this over to someone not so inclined to leave it well enough alone the D4 may not be the perfect light. If you don’t mind the C8 platform the Sofirn C8F is a mighty fine light. Moonlight mode, well spaced (for me anyway) normal modes, quick access to a yard filling 2500 lumens of turbo. I love that light too. $34 for the light or $38.50 with charger and battery.
https://www.aliexpress.com/item/Sofirn-C8F-Triple-Reflector-Tactical-LED...
Or the Sofirn C8A if you are looking for more of a thrower with a tail clicky. Around $19, $23 with battery and charger.
https://www.aliexpress.com/item/Sofirn-C8A-Tactical-LED-Flashlight-18650...
patmurris
patmurris's picture
Last seen: 6 hours 35 min ago
Forget the BLF A6 and Emisar D4. These are really good lights but not for everybody. Both can become very hot on high/turbo, especially a D4 on 18650.
The Convoy S2 with 6×7135 is an easy choice.
The new Convoy S9 with moderate output (and heat) has built-in USB charging.
Another budget option is the Eagle Eye X2R – very similar to the S2 with built-in charging.
Use something like protected Panasonic NCR18650B 3400mAh.
ValuseekeR
Thanks guys,
I sort of lost track of things during the site outage but a C8 in some flavor is probably in my future. I did order a Convoy S2+ from AliExpress. Just a 4× for my “idjit” light. Will probably by a 6x or maybe a couple more next time there’s a good sale.
Firelight2
Firelight2's picture
Last seen: 18 hours 45 min ago
Not sure I’d want to hand the Zanflare F1 to an Idjit. The tailcap switch is very easy to miss. Result is the Idjit just presses the side switch and wonders why nothing is happening.
I think the ideal 18650 light for Idjits should have the following features:
  • Idiot-proof UI – UI should be extremely simple.
  • Low output – if the light only goes to 500 lumens or so there’s a lot less risk the light will overheat and blow up, or burn a hole in something.
  • Single-cell – much less risk of battery issues.
Funner
Last seen: 3 months 1 day ago
I have that light in hand. The S2+ in V2 1A, 7135×8, in the sand color. It is sweet. It took about 3 weeks to arrive.
I just went with a C8 too. But I ordered the C8.2 with a XHP50.2 from Kaidomain.
http://www.kaidomain.com/p/S026927.KDLITKER-C8_2-Cree-XHP50_2-White-6500...
Should be a blaster. It should put out some heat though
It’s still in transit.
Another lite that is one of my top lights is the Kaidomain KF8. It warms up a bit too.
Lightbringer
Lightbringer wrote:
Zanflare F1.
Wellp, there’s “idjit” and there’s “lobotomised”…
Then what about that all-white Xioumi light? Think it’s all of 500lm, simple UI.
Lightbringer
Speaking of idjits and F1s, I made the mistake of getting 2 more F1s. Flash price was 20bux… for whatever reason I thought it was 10bux each or 20bux total. Talk about idjit…
Anyway, ordered 2 of the same, whatever they were supposta be, whether both CW or both NW.
One’s CW and one’s NW. Facepalm
DENGOH
DENGOH's picture
Last seen: 2 hours 16 min ago
Zanflare F1 is very good light. It is very simple UI actually. One tail switch to turn it on, another side switch to set mode. Those single switch lights are more complex if you think of it this way.
cool i'll see you when you get there
Lightbringer
Ah, here ya go…
https://www.gearbest.com/led-flashlights/pp_1192375.html
All of 240lm. Big Smile
It’s basically a battery-bank with a flashlight head stuck on.
You could give it to someone who’s been pithed and he’ll still be able to work it.
Boaz
Boaz's picture
Last seen: 3 hours 53 min ago
I like the fenix E21 one of my favorite lights
patmurris
patmurris's picture
Lightbringer wrote:
Lightbringer wrote:
Zanflare F1.
That happened to me a couple times with the F1! Click the side switch, nothing… screw and unscrew everything… nothing… until i remember there are two switches!
I’ve no recollection of having lost part of my brain though… i guess that’s the idea behind the procedure? lol Big Smile
