"Mechanic" SnBi solder wire - fake
11 posts / 0 new
Agro
Last seen: 1 min 45 sec ago
I got a roll of low-temperature solder wire today.
It clearly has a higher melting temp than my Sn60Pb40.
Avoid.
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 23 min ago
I always avoid Lead Free no worries.. Big SmileThumbs Up
KB1428 “Live Life WOT”
Lightbringer
Lightbringer's picture
Last seen: 1 hour 8 min ago
Umm, from where?
Plan to p&m to the vendor? I definitely would.
Lightbringer
Yeah, when I got a coupon from MicroStore for 10bux/20bux/whatever off (use like cash), I went’n‘got two 1lb spools of regular good ol’ fashioned SnPb solder.
I’m set for a long time. Big Smile
kiriba-ru
kiriba-ru's picture
Last seen: 45 min 37 sec ago
I use one that have sticker same design as on mehanics solder paste. Works great. Many years ago I got one from dx.com, nowadays you can find it on ebay.
Need a vlogger for machine accessories reviews
Agro
Lightbringer wrote:
Umm, from where?
From here:
https://www.aliexpress.com/item/2pcs-set-0-3mm-HK-Mechanic-green-low-tem...
I intend to start a dispute as soon as I have a video of this being solid at 200 degrees-hot iron tip (even if tip temp is lower than I set it to, at the same time I got a blob of Sn60Pb40 being fluid at the other side of the tip).
I also have Mechanic paste. I haven’t compared it with anything, but it works.
KawiBoy1428
Yep the Mechanics Sn63/Pb37 solder paste works, I prefer Kester EP256 paste, and use Kester SN63PB37 (.031) wire, but my favorite wire is Stannol LoveThumbs Up
Agro
BTW, no surprise, there are others noting that it’s fake:
https://www.eevblog.com/forum/beginners/low-temperature-solder-wire/msg8...
And now I’ll add a couple of keywords to make this thread easier to find:
Sn42Bi58 Bi58Sn42 China Chinese Aliexpress review test quality good bismuth bi leadfree lead free 138
atbglenn
atbglenn's picture
Last seen: 17 min 52 sec ago
Same here.
Agro
The seller has sent me a test report of a compliance check with EU regulations. This tests show that the solder is lead free and not very contaminated. For this reason my suspicion that the solder is just recycled is much weakened.
Anyway it doesn’t show anything about actual contents.
If anyone is interested in seeing the report, PM me.
BTW, I won the dispute even though the video that I created was of very poor quality and I wouldn’t grant myself a refund after seeing it. Big Smile
led4power
led4power's picture
Last seen: 35 min 27 sec ago
If 100% fake, it melts at ~230C, even higher than regular SnCuAg solders.
