Group Buy: Wuben TO10R and TO46R (real 90+CRI triple XP-G3) - CLOSED!!
503 posts / 0 new
maukka
maukka's picture
Last seen: 8 hours 59 min ago
It’s very easy to swap the emitters, unless they decided to glue the bezel in the new batch. You won’t get much more visible brightness though.
_the_
_the_'s picture
Last seen: 2 days 8 hours ago
Pezo wrote:
This is only for making the beam more floody, or is it for color correction as well? About how much will this reduce the output?
For normal outdoor usage, the light is good as is.
For photography, indoor usage, or just hunting white walls, it might be a good idea to apply DC-Fix. This will not only make the beam smoother and floodier, but also reduce the tint shift (towards green on the edge of spill).
vresto wrote:
do you think,its possible to change the leds for brighter? xpl…or so..i mean home custom
Would be interesting to try XP-L2, but unfortunately, that would probably require also driver changes for any major gain. Has anyone tried this on his TO46R?
=the=
RobertB
RobertB's picture
Last seen: 1 week 1 day ago
Batch1 wrote:
Where do you buy DC-fix, and what type Thanks Robert
You don’t need DC fix. These are standard Carclo optics. the slightly frosted 10508, and more frosted 10509 are what this light uses. The light comes with the clear Carclo 10507. I tried a 10508 in mine, and it smooths out the beam beautifully.
Batch1
Last seen: 11 months 2 weeks ago
Thanks everybody for your input
Robert
Klotski
Klotski's picture
Last seen: 3 days 5 hours ago
Thanks The
Payment has been sent:
You sent $72.00 USD to 姚 巧敏
1-TO46R: $35 1-TO10R: $32 1- Extra emitter boards: $5 BLF
MascaratumB
MascaratumB's picture
Last seen: 43 min 57 sec ago
Thank for the updates on the process =the=! It is now closer to get the lights on our hands Wink The light and emitters are paid!
Do we have to send you any kind of information or the info we sent to Wuben is enough?
Hum, about this, I am not sure if – in terms of beam – the XP-L2 would be better! Brighter, for sure, but maye not better! I have 2 Sofirn lights that arrived with XP-L2 leds. One seemed more tending to 5000K and the other was a bit higher (5500 or 5700???).
However, both produce and yellowish and greenish tint shift similar to the one on the stock XP-G3 these Wuben lights have.
So…I am not sure if XP-L2 would be a good choice. However, a Luxeon V 4000 K, I guess that would be an interesting bet for these lights! No major shifts (or none), and a quite pleasant beam!!
But now let’s see how the leds we’re going to receive behave and that is the most important thing right now Silly
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
beam0
beam0's picture
Last seen: 1 year 8 months ago
I’m hoping there will soon be a Luxeon V 5000K
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
maukka
maukka's picture
Lights are in and they are CRI90+
TO10R on high
TO46R on high
Pezo
Last seen: 1 month 4 days ago
That’s good to hear, thanks for doing the tests maukka Thumbs Up
KevinZA1988
KevinZA1988's picture
Last seen: 3 days 15 hours ago
Fantastic news. Thanks maukka!
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
MascaratumB
Thanks for the tests maukka Smile
Party-time now Party
OL Contest 2019
GIVEAWAY: 1 / 2
Xikex
Last seen: 2 days 3 hours ago
awesome news maukka, thank you
blinks
Thank you the and maukka. Good news all around.
Chatika vas Paus
Last seen: 15 min 8 sec ago
They are even better than first samples.
TO10R on high (old-new)
TO46R on turbo/high (old (turbo)-new (high))
_the_
_the_'s picture
Thanks for testing maukka! I'll give Wuben a green light.
=the=
maukka
maukka's picture
Tint graph in different modes. My sample of the TO10R is pretty good in the hotspot, but needs d-c-fix to even out the beam. I also added a tint measurement with d-c-fix and a Lee Zircon minus green filter on high for the TO46R. That’s an easy solution for the XP-G3 and makes the beam look quite pleasing.
beam0
beam0's picture
TO10R on high
Did you happen to measure the lumen output? I’m wondering the output of TO46R in Turbo.
maukka
maukka's picture
Approximate numbers, not exactly at 30 sec nor did the usual sphere calibration routine, but should be within 5%.
1100 lumens for the TO46R
630 lumens for the TO10R
KevinZA1988
That’s great output. I’m really excited to get my hands on this light!
MaksVasilev
Last seen: 11 months 5 days ago
I swapped original Cree XP-G3 (low CRI and acid-rainbow, but buyed as hi-cri) to HI-CRI Samsung LED LH351D 4000K 90 CRI. Now light very smooth and more wide.
Original:
Now:
Can any one take a beamshot from new XP-G3 with real hi-cri?
my blog: http://torchobzor.blogspot.ru
And sorry for my english.
maukka
maukka's picture
The high CRI XP-G3 beam looks identical to the low CRI one on a white wall.
And I agree, the LH351D makes the light much better.
_the_
_the_'s picture
Samples have been approved by maukka and all GB lights are ready to ship! Have you paid yours already? If not, please do so at latest on this week’s Saturday (2018-06-02)!
Ps. We have some 10r’s and emitter boards still left. PM me if interested. (all 46r’s are reserved, but I can get you on the waiting list if someone would be crazy enough to bail out.. Silly )
=the=
Umcookies
Literally failed to read, sending pm as requested.
beam0
beam0's picture
Better if you are ok with a considerably warmer tint?
Besides the Cree’s fried egg beam (that you only see on a white walls) there really that much of a difference?
Will swapping to LH351D give higher lumen output?
I bought this light because it’s 5000K and HI CRI, I do like 4000K but mostly for indoors, for outdoors I prefer 5000K because 4000K Cree (XPL 5A) is slightly too warm/yellow for me. But in MaksVasilev’s photos the 4000K Samsung appears even more white than the 5000K Cree, however I’m not sure the photos show a accurate representation of the color (and he has the WB set different between the 2 photos).
In real life how does the LH351D 4000K compare to a Cree 4000K or this XP-G3 5000K as far as color is concerned? (overall color disregarding the tint shift)
beam0
beam0's picture
Doing a bit of research here on my questions in my last post (above) I found maukka’s post in the LH351D group buy thread.
Compared to the (Actually low CRI) Cree the Samsung appears to have a bit of a pink-ish hue and does seem considerably warmer. But again I’m not sure the photos show a accurate representation of the color. In comparison to MaksVasilev’s photos here you see a very noticeable difference in tint color. Also the lumen outputs were equal.
maukka wrote:
Received my 3x LH351D today. Installed them inside a Wuben TO46R. They’re really nice. No tint shift to speak of in the clear triple optics. A simple filter will perfect the tint on most modes if you need to be on the BBL. On higher currents it’s already superb.
And what’s amazing. It offers Nichia like beam quality but reaches output comparable to the XP-G3. I measured equal lumens before and after the swap. Although one of the original XP-G3s was dedomed so didn’t probably live to its true potential.
MaksVasilev
White Balans are different and marked on photo.
This photo on same WB = 5000K (left: XP-G3 6000+K, right: With 4000K Samsung LED):
SKV89
Last seen: 1 hour 56 min ago
Since this can be easily modded (not glued), can these be sold without the emitter boards? I’m thinking of buying some presoldered noctigon emitter boards with the 219B 9080 from Clemence and put it in there. The 0.0049 DUV Maukka measured is on the TO46R is too high/green for my liking. But I like the two button UI and usb recharge on this nice looking host.
_the_
_the_'s picture
Not possible. Wuben simply won’t agree on selling hosts or parts. Sorry!
=the=
SKV89
Oh. Besides the 90CRI emitters, is anything else different/improved on this version?
_the_
_the_'s picture
90+CRI instead of 70CRI
and
5000K instead of 6500K
Other specs are the same than original.
=the=
