Luxeon V with abnormal high voltage
Recently I ordered a Luxeon V mounted on DTP from led4power.
I measured the current draw with a power supply, the wire to the DTP board are AWG20.
@3.4V I only get 2.8A, at 4.2V its 6A.
According to https://budgetlightforum.com/t/-/47339/73 I should get the 6A @ 3.4V.
What could be wrong/faulty?
There can be large voltage drops between the power supply meter and the leads. Have you verified the voltage by measuring closer to the LED?
@EasyB: Thanks for the advice! The voltage meter from the power supply is totaly out of scope...
I soldered directly thick wires to the 20AWG wires and took short (25cm) 4mm 2.5mm2 (AWG14) cables, stronger clamps and measured the voltage with a DMM:
Now I get @3.4v 4A, @3.7v 6A.
Does this new luxeon V need a "burn in time" like the old Luminus SST50/SST90 to drop the needed voltage?
I can’t quite picture exactly your measurement set-up, but I might suspect you still have voltage drops you are not accounting for, like at the clamps. It doesn’t take a lot of resistance to drop 0.3V at 6A.
New setup: Now I get @3.6V 6.18A:
Thats a little closer to de goal of 3.4V@6A.
