Thinking about modding SF14
6 posts / 0 new
stevens02
Last seen: 7 months 1 week ago
Hi there, I wanted to mod a recently acquired SF14 with a MTN-DDM running Crescendo, just wanted to get your expert opinions on whether the 15 or 17mm diameter size would be a better choice. Thanks!
““Reference material”“:http://budgetlightforum.com/comment/1210143#comment-1210143
-Steve
MascaratumB
MascaratumB's picture
Last seen: 7 hours 23 min ago
I would go for a 17mm driver! The 15mm will be too “slim” to fit the pill! Thumbs Up
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S ///
 Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7   TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
stevens02
Thank you, I knew I’d get a good answer. Wink
MascaratumB
Show us what you’ve done, when you’ve done it Wink
Good work Thumbs Up
 MY GIVEAWAY (FW3A)
stevens02
K so I managed to get the driver on the pill, but found out the ø of my driver is a little too wide for the threads inside the head. I guess more sanding is req’d. Then I realized that the springs are too long as well! I was considering shortening the spring on the tailcap side; will the different lengths of spring affect anything? Thanks!
I’ll try to add some pictures later.
Sofirn
Sofirn's picture
Last seen: 13 hours 47 min ago
Please make sure the space for battery is good for contact after you shorten the spring. Also be careful with the spring in case it damages the battery.
Sofirn is owned by a factory, contact us for any lights you wanna make or contact to be a dealer.
Sofirn Flashlight Deals Group
AMAZON US Store
Authorized AMAZON DE Store
Aliexpress Worldwide Store
Thailand Shopee Store
Malaysia Shopee Store
