AA/14500 flashlight
21 posts / 0 new
Sn95mustang
AA/14500 flashlight
Hey everybody, I’m looking for a AA/14500 flashlight that has a nice smooth transition from the hotspot to the spill. Any suggestions would be appreciated .
sesgum
sesgum's picture
Last seen: 2 weeks 4 days ago
I like everything of Sofirn SF14 so far. Great little light.
Persechini
Persechini's picture
Last seen: 1 month 2 days ago
I second the Sofirn SF14
Utorch UT01 has a quite smooth transition also, but doesn’t seem as smooth as the SF14
Avoid the Lumintop Tool AA by your criteria, the spill and hotspot have a much clearer transition
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
Sn95mustang
Awesome, thanks guys.yeah, I tried the tool and didnt like it. Also I have the Thrunite archer 1A and not fond of that one either.
Sn95mustang
Is there a BLF APP?
WalkIntoTheLight
Last seen: 1 hour 51 min ago
If you want a very smooth transition, you could get a small AA light with a frosted lens. Something like the Zebralight SC5F, SC5Fc, or SC5Fd (they are different tints). That will give you a soft hotspot, and a gradual fade out to a wide spill.
Or, get any AA light, and add a frosted filter yourself.
Otherwise, almost all AA lights using a small reflector and a domed XM-L2 or XP-L/XP-L2 LED will give you a very similar beam. About a 12 degree hotspot, and about 80 degree spill, with a fuzzy corona between the two. Anything more gradual than that, and you need a frosted filter. (Or a mule, but then there’s no hotspot.)
MascaratumB
MascaratumB's picture
Last seen: 14 min 22 sec ago
Hi Sn95mustang!
Welcome to BLF Wink
Well, I am one of those that can recommend the SF14 as well.
You can take a look here to how the beam looks like!
http://budgetlightforum.com/comment/1210143#comment-1210143
Also, WalkIntoTheLight gave a nice suggestion if you want a more floody light! Use a “filter” or DC-Fix! You can find it on sale on this thread by Boaz: http://budgetlightforum.com/node/42208 .
I can also give you another suggestion. I am using some TIR pebbled lenses in two lights, and they work very well if you want some flood and less hotspot.
Here are some experiences I’ve made with some AA/14500 lights (Amutorch S3) with those lenses: http://budgetlightforum.com/comment/1188895#comment-1188895
Those TIR fit well in other lights, so if you wanna try them I can post the link for AliExpress store!
Enjoy your stay here Wink
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
Sn95mustang
Cooll thank you, what products are out there that I could use to get that affect on my existing lights?
MascaratumB
The lenses I bought were these:
https://www.aliexpress.com/item/CREE-XP-E-XP-G-lens-Diameter-17mm-Bead-s...LED-lens-with-stand/2048689105.html?spm=a2g0s.9042311.0.0.xxabvP
Take a look at the store, and check the measures (diameter/height) you want for your flashlight!
About the filter, I pointed the link for Boaz thread on my previous post.
Maybe you can contact him through Personal Message Wink
GIVEAWAY: 1
kramer5150
kramer5150's picture
Last seen: 8 months 1 week ago
Any light with a couple layers of frosted scotch tape over the lens will achieve the desired result. Its easily reversible too.
jon_slider
jon_slider's picture
Last seen: 23 hours 6 min ago
Welcome to the search for the perfect light. Be warned, it may mean buying many, and making compromises.
regarding your beam shape interest, there are also diffusing films in the Lee Filter sample pack
I use double sided tape to apply Lee Filters to the outside of the lens, no disassembly required, and completely reversible
Lee Filters are also great for reducing the green tint of most of the typical lights being discussed
http://shop.leefiltersusa.com/Swatch-Book-Designers-Edition-SWB.htm
more details here
http://budgetlightforum.com/comment/1117960#comment-1117960
Examples of with and without Lee minus green
http://budgetlightforum.com/comment/1234356#comment-1234356
I also think MascaratumB has great suggestions in regards to using a TIR, if you are open to learning how to take a light apart.
And once you get started, you may want to add High CRI as a category to include in your choice of LEDs
afaict, all the lights mentioned so far have Low CRI
hang on to your wallet Smile
pavol77
pavol77's picture
utorch ut 01 nw
no problem + best  battery - / efest 700mah/
pavol77
pennzy
pennzy's picture
Last seen: 1 hour 1 min ago
The Sofirn SP 10b has a nice smooth beam and a neutral tint.
Lightbringer
Lightbringer's picture
Last seen: 7 hours 15 min ago
You can bug Boaz for some DCFix… Big Smile
Sn95mustang
Awesome thank you all for your suggestions, here is another one. Same size light with clicky switch and nichia led.
bigtrav261
bigtrav261's picture
Last seen: 7 hours 10 min ago
Manker has several AA and AAA models in Nichia flavor…mmm. They’re not 14500 compatible, though they do output 200-350 lumens on Turbo. Also, their reflectors have a light orange peel texture, that should give a pleasant transition.
Tactman
which one would you suggest after sf10…?
sp10b, sf12 or sf14? is there any significant step up in real life performances between them all? thanks…
Persechini
I don’t like the SF12 , the sp10 has a smooth reflector IIRC so it won’t be as smooth a transition, but a lot of people here like it. The SF14 is my favorite among those
In my Tree
Tactman
@Persechini
thanks…i guess brightness output between them is more or less the same?
Persechini
hmm, I can’t test that now since I changed the emitter on my sf12 and gave away my sp10a. I can sy the sf14 is brighter on high than the lumintop tool aa, and has a lower low
In my Tree
pennzy
pennzy's picture
The SP10B has a op reflector.
