ThruNite Catapult V6 XHP35 HI
212 posts / 0 new
RT--
Last seen: 12 hours 26 min ago
Just released.
http://www.thrunite.com/thrunite-catapult-v6-mini-thrower-rechargeable-f...
Coupon code 20%
Product Description
The Catapult V6 is the newest light of Catapult series with latest CREE XHP35 HI LED emitter and the max beam distance up to 750 meters. As the appearance communicates, the Catapult V6 features its compact size, durability and reliability in the field. And it can also provide everything an advanced EDC or tactical LED flashlight can offer: low-voltage protection, overheat protection, simple user interface and cost effective performance. Therefore, for those who are looking for a compact and powerful thrower, our ThruNite Catapult V6 will be a best choice…
Features
Adopts an advanced CREE XHP35 HI LED to give great light efficiency. With the max output of 1700 lumens and max beam distance up to 750 meters. The most compact size comparing other 26650 thrower flashlights on the market currently. Smooth reflector for a high quality beam and throw. Ultra clear tempered glass lens with anti-reflective coating. Aircraft grade aluminum body structure with tactical knurling for firm grip. Premium type III hard anodized anti-abrasive finish. Reverse polarity protection designed to protect from improper battery installation.
Specifications
LED: CREE XHP35 HI LED with a lifespan of 20+ years of run time. Output mode/Runtime(Tested by ThruNite 26650/5000mAh battery): -Turbo (1700 lumen; 150 minutes) -High (950 lumen; 165 minutes) -Medium (180 lumen; 9 hrs) -Low (22 lumen; 62 hrs) -Firefly (0.5 lumen; 41 days) -Strobe (1200 lumen; 180 minutes) Working voltage: 2.75V-4.2V Battery: 1 × 26650 batteries ( included in the light) Max beam distance: 750 meters Peak beam intensity: 140650 cd. Waterproof: IPX-8 Standard (2M) Impact resistance: 1.5M Working temperature: -20℃ to 40℃. Weight: 192g without battery. Dimensions: 132mm (Length) x 58mm (Bezel Diameter) x 33.5mm (Tube Diameter) Accessories: Holster x1, Lanyard x1, ThruNite 26650 battery x1, O ring x2, User’s manual x1, USB charging cable x1, Spare USB plug x1, Spare side switch cap x1
Operation
Turn ON/OFF Single press the side switch to turn the flashlight on/off . Long press the side switch to get firefly mode. Change Modes With the light turned on, long press the side switch to circle through Low, Medium and High. Double click from any mode to get to Turbo. Another double click to get to Strobe. Memory Function The light will turn on in the last mode accessed, except for Firefly, Turbo and Strobe. Charing and indicator 2A USB charging. When the indicator on the switch flashes red, it means the battery need to be changed or charged. During charging, the indicator is RED, and only firefly, low and medium modes are available. After the light is fully charged, the indicator light will turn to BLUE. The indicator will be off when it is firefly mode. Purple light means abnormal charging. Battery Replacement Take off the tail cap, insert the battery with the anode (+) toward the LED assembly (head of the light), screw the tail on and tighten it all the way to operate the light.
Edited by: RT-- on 04/28/2018 - 11:57
KawiBoy1428
KawiBoy1428's picture
Last seen: 33 min 28 sec ago
Got the e-mail this morning… very nice, I’m getting on of these, love ThruNite! Thumbs Up
Bye bye modded MF02! Big Smile
KB1428 “Live Life WOT”
-X3-
-X3-'s picture
Last seen: 9 hours 17 min ago
Now that’s how you make a compact powerful thrower !
USB rechargeable, great capacity with the 26650, wonderful UI (seems to be quite the same as Olight) and a faire price of 60$ !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
komeko
komeko's picture
Last seen: 7 hours 8 min ago
Only CW Sad
I was supposed to buy TC42 and what now? Hmm. If there was an NW version, I would not think about it Smile
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Q8, D4, D4S, PL47, GTmini, SDmini, Mini AAA, TIP CRI, M43, H1, H03, TC20, TN40S, TN42, V6, UT01, UV
RT--
For that price it would be an easy decision – if it was neutral white.
I already asked them but they have no plans to make neutral white. Perhaps they would change their mind if lots of people emailed them about it?
hIKARInoob
hIKARInoob's picture
Last seen: 5 hours 38 min ago
RT— wrote:
For that price it would be an easy decision – if it was neutral white. I already asked them but they have no plans to make neutral white. Perhaps they would change their mind if lots of people emailed them about it?
That’s so unreal. Thrunite’s been offering neutral white for a very long time for pretty much every model they have. Love the diamond pattern tube. Cool
atbglenn
atbglenn's picture
Last seen: 3 hours 48 min ago
I’ll be ordering one Smile
komeko
komeko's picture
I am curious about a direct comparison to Utorch UT02
sp5it
sp5it's picture
Last seen: 6 hours 21 min ago
Price is fine, but CW I pass.
 Anyone offended by my signature please fill: Complaint Form. Thank you.
chooma
Last seen: 1 hour 31 min ago
Is this light a candidate for Narsil?
Thanks
atbglenn
atbglenn's picture
I clicked on one of your links in your signature and this what I get:
komeko
komeko's picture
You received an incorrect message. This is a link to my photo located on the server of my internet provider. It has no threats.
komeko
komeko's picture
See if something changes, as I change the png file to jpg. How it works will replace all links (Link Nitecore).
keithd
keithd's picture
Last seen: 2 weeks 4 days ago
komeko, I get the same thing:
"www.strony.toya.net.pl has been reported as containing malicious software. You can report a detection problem or ignore the risk and go to this unsafe site." So it's not your picture that's the problem, but the main URL.
atbglenn
atbglenn's picture
komeko, it still gives me the same warning in Chrome on my Mac
Nicolaas
Last seen: 11 hours 23 min ago
Hmmmmm…………Thrunite getting on the “1*26650+XHP35 HI+USB charging port – Wuben/Astrolux/Manker/etc” bandwagon?
I wouldn’t call that light either a thrower or a Catapult. At best a baby catapult.
Just look at the size comparison with the Cata V5, different league altogether.
They should have given it another name.
It looks nice but, no thank you.
Grtz
Nico
hIKARInoob
Grtz
Nico
I personally would have liked a Catapult V6 with 2×18650 and single XHP35; same form factor as V5 and V3.
komeko
komeko's picture
www.strony.toya.net.pl has been reported as containing malicious software. You can report a detection problem or ignore the risk and go to this unsafe site.” So it’s not your picture that’s the problem, but the main URL.
I changed the server, so if you can check if it works. Sory for offtop
keithd
keithd's picture
komeko,
That link works. Clicked on the Thrunite TC20 and the color analysis picture came up.
Nicolaas
Me to.
Then they could have driven the emitter harder and get the throw well above 200K and the form factor wold still be “Catapult”.
Better yet: two 20700/21700.
To me it looks like Thrunite is just “going with the flow/hype”.
To bad, they set the standard with the original Catapults, with the TN31/32 line and lately the TN42.
Don’t follow others, design your own.
Grtz
Nico
LichtAn
I was crossing my fingers for an Oslon in there. Crying
Speed4goal
Last seen: 1 month 1 week ago
Would be nice to have a nw version. Cw is good for throw and also bad. If there’s moisture or dust in the air just going to see a wall of light. Not to mention it’s harder to make out details with cw at a distance. But manufacturers want to chase the high lumens that’s what the masses want
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
atbglenn
atbglenn's picture
komeko, it’s now working. Whatever you did fixed it.
komeko
komeko's picture
I changed the server. Thanks
beam0
beam0's picture
For a thrower I think the extra output of the CW is lost in the lower visibility of the “white wash out” effect. But it might just be my old eyes.
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
beam0
beam0's picture
This does appear to compete well with the Utorch UT02, except the price, and that Utorch offers NW.
At 750m it’s an upgrade from the V5 in distance, but the XP-L HI equipped Emisar DS1 and Maeerxu M8 are rated 720m and 800m.
I thought with the XHP35 HI it might be more, but the UT02 is rated 700m, so I guess the gains of XHP35 HI are efficiency, a larger hotspot and more spill?
beam0
beam0's picture
Grtz
Nico
Not a thrower?
This out throws the V5:
V5…..105400cd……..649 meters
V6…..140650cd……..750 meters
Also which model of Astrolux is 1*26650+XHP35 HI?
Nicolaas
Grtz
Nico
Not a thrower?
Note: my V5 has an XP-L HI. Originally CW V1, I changed it to V3 3C (=NW). \
It does – without any driver or spring mods – 184Kcd = 860m.
Want a short version of a real Catapult?
Try the V2. Mine has BLF dd driver with dedomed XM L2 U2, tube bored out to accept 20700 and it does 243Kcd.
And no, you’re right, neither of these lights have a XHP50 HI. So what?
My M2X does 1200Lumen and my Catapult V2 1550. Why need a XHP50?
I just don’t see the point of having an XHP50 HI in a small light with only one battery.
Regulation will always be an issue and the led cannot be driven hard so the throw will always be limited.
If you want a small light, with one battery, that throws out a good amount of light and has good throw, use any
decent one-cell thrower, give it (near) direct drive and put a dedomed or shaved SST40 in it.
It will beat any one-cell light with an XHP50 HI.
I view lights as the one in this topic as hype lights. Yeah, looks nice and of course Olight means quality but why should you?
I see no other redeeming points for this form factor other then extended runtime.
Big deal.
If runtime is what you want simply us a multiple cells light.
Just my 2 cents of course WinkWink
I can see the appeal.
Cheers
Nico
beam0
beam0's picture
Grtz
Nico
Not a thrower?
Nicolaas wrote:
Want a short version of a real Catapult? Try the V2. Mine has BLF dd driver with dedomed XM L2 U2, tube bored out to accept 20700 and it does 243Kcd.
Catapult V2 SST-50, from 2010? Out of production now I believe, I don’t think you can buy those anymore. Yours sounds great though.
I guess you mean XHP35 HI?
It will beat any one-cell light with an XHP50 HI (XHP35 HI)
I’ll have to look into SST40. Do they make it de-domed or would I need to shave it myself? Also do they make it in a good NW tint? (I prefer)
Is SST40 a very tight beam? I’m not looking for a pencil beam thrower, I’d like some spill with decent long range (700m plus)
Here’s what I’d like:
  • Single cell
  • Side switch
  • NW tint
  • Has some spill – not pencil beam
  • Decent long range (700m plus)
What do you recommend? (off the shelf, without modding)
Here’s the one’s I’m considering:
  • Catapault V6
  • Utorch UT02
  • Emisar D1S
  • Maeerxu M8
SKV89
Last seen: 2 hours 33 min ago
Too bad only CW. I would buy if it had NW But still curious how it compares with the UT02
Newlumen
Newlumen's picture
Last seen: 1 hour 15 min ago
I like cw. I just preordered my v6 for $60. Thanks.
