ThruNite Catapult V6 XHP35 HI
222 posts / 0 new
Buttkicker
Last seen: 1 year 3 months ago
Newlumen wrote:
I like cw. I just preordered my v6 for $60. Thanks.
same here looks a nice light for my very small collection
Nightcore ST-7
Astrolux MF-02
Astrolux MF-01
Utorch UT-02
Thrunite V6 catapult
BLF GT Gigathrower
Astrolux MF-04
netprince
Last seen: 8 hours 41 min ago
Anyone who ordered one received any updates? No updates here…
atbglenn
atbglenn's picture
Last seen: 11 months 2 days ago
Ordered one and no updates yet here.
Boycott Nike
Newlumen
Newlumen's picture
Last seen: 2 months 1 day ago
Thrunite website say expected shipping date is may 1st.
KawiBoy1428
KawiBoy1428's picture
Last seen: 14 min 27 sec ago
Not yet….
KB1428 “Live Life WOT
mmalive
Why is there “ NO LOVE “ for cool white? Cool white really gives off full brightness. Neutral White has “ yellowish color “ correct? I bought the Utorch 02 because at the time they had only ‘ neutral white “ I really wanted “ cool white “ version.
beam0
beam0's picture
Last seen: 1 hour 43 min ago
There is some love:
It’s really a matter of personal preference, and different people see color differently, I’ve even read that age is a factor but I’m not sure how true that is.
The brightness difference is minimal, NW has better color rendering; go outside and beam a CW light into some green trees, shrubbery or other green vegetation, then shine a NW at the same objects, you’ll immediately see the difference and what I mean.
Additionally, here’s some reasons why NW is best for a thrower.
Speed4goal wrote:
………………. Cw is good for throw and also bad. If there’s moisture or dust in the air just going to see a wall of light. Not to mention it’s harder to make out details with cw at a distance. But manufacturers want to chase the high lumens that’s what the masses want
beam0 wrote:
For a thrower I think the extra output of the CW is lost in the lower visibility of the “white wash out” effect…………………
To me, a CW hot spot washes out the object in the distance in a blur of overly white hue, with NW now I can see the details of a distant object better, as it isn’t washed out.
Hugh Johnson
Hugh Johnson's picture
Last seen: 20 hours 53 min ago
Cool white light scatters more. Less light on target. It also reflects more in fog and mist which is a factor in my area.
Agro
Agro's picture
Last seen: 2 min 12 sec ago
Colour temperature and rendering are unrelated. Virence offers 6500k LED with CRI 9080.
Nicolaas
Last seen: 4 months 1 week ago
beam0 wrote:
beam0 wrote:
Nicolaas wrote:
Hmmmmm…………Thrunite getting on the “1*26650+XHP35 HI+USB charging port – Wuben/Astrolux/Manker/etc” bandwagon?
I wouldn’t call that light either a thrower or a Catapult. At best a baby catapult.
Just look at the size comparison with the Cata V5, different league altogether.
They should have given it another name.
It looks nice but, no thank you.
Grtz
Nico
Not a thrower?
This out throws the V5:
V5…..105400cd……..649 meters
V6…..140650cd……..750 meters
—> My cata V5 (changed led only for XP-LK HI V3 3C – great tint) does 184.000Cd.
Also which model of Astrolux is 1*26650+XHP35 HI?
—> Not sure, have to look it up. maybe I was wrong there…..in which case sorry,
Nicolaas wrote:
Want a short version of a real Catapult? Try the V2. Mine has BLF dd driver with dedomed XM L2 U2, tube bored out to accept 20700 and it does 243Kcd.
Catapult V2 SST-50, from 2010? Out of production now I believe, I don’t think you can buy those anymore. Yours sounds great though.
—> Nope, was the V2 XML series. BLF DD (FET) driver and dedomed XM L2 U……2 I think.
Nicolaas wrote:
And no, you’re right, neither of these lights have a XHP50 HI. So what?
My M2X does 1200Lumen and my Catapult V2 1550. Why need a XHP50?
I just don’t see the point of having an XHP50 HI in a small light with only one battery.
I guess you mean XHP35 HI?
—> Yes, that is what I meant
Nicolaas wrote:
If you want a small light, with one battery, that throws out a good amount of light and has good throw, use any
decent one-cell thrower, give it (near) direct drive and put a dedomed or shaved SST40 in it.
It will beat any one-cell light with an XHP50 HI (XHP35 HI)
I’ll have to look into SST40. Do they make it de-domed or would I need to shave it myself? Also do they make it in a good NW tint? (I prefer)
—> The SST40 exist only in 6500K and 7500K versions, so quite cool.
MTM sells them on Noctigon boards and you can order them shaved ($5 plus per led).
This will lower the Kelvins a bit, but it will not go NW. Very even tint tho, like with Cree’s HI series leds.
Is SST40 a very tight beam? I’m not looking for a pencil beam thrower, I’d like some spill with decent long range (700m plus)
—> The SST40 has roughly the same die size as XM-L2 and/or XP-L HI so spot will be roughly same size. Not as pencil as with dedomed XP G2 or smaller.
Here’s what I’d like:
  • Single cell
  • Side switch
  • NW tint
  • Has some spill – not pencil beam
  • Decent long range (700m plus)
What do you recommend? (off the shelf, without modding)
Here’s the one’s I’m considering:
  • Catapault V6
  • Utorch UT02
  • Emisar D1S
  • Maeerxu M8
—> considering your wishes I would recommend the Cata V6, although I’m not sure if Thrunite makes them NW of the shelf…… byut apart from that it has everything
you want and Olight quality in my opinion is still one of the best around.
Cheers
Nico
maukka
maukka's picture
Last seen: 42 min 13 sec ago
In theory yes, but it is immediately apparent which one brings out the greens better when you compare CRI70 6500K and 4000K emitters in a similar thrower. Add a bit of moisture and the gap widens.
netprince
I can go either way for throwers. I understand warmer tints are better for seeing what your pointing the light at… but sometimes its fun to have a light saber with a bright white beam.
beam0
beam0's picture
Subject continued in a new thread to prevent hijacking: http://budgetlightforum.com/node/60000
RT--
Last seen: 3 weeks 6 days ago
I can now see a neutral white option in the dropdown menu!
But nothing for Europe.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 days 7 hours ago
RT— wrote:
I can now see a neutral white option in the dropdown menu! But nothing for Europe.
See here: http://budgetlightforum.com/node/60232
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
beam0
beam0's picture
Thanks RT— That’s awesome!
beam0
beam0's picture
I know the pineapple knurling keeps in style with the previous Catapults, but I really wish this had the same grippy knurling of the TC20.
amaretto
Some measurements and beamshots, if you are interested. It’s the cool white version.
http://www.taschenlampen-forum.de/threads/thrunite-catapult-v6-review-pa...
hIKARInoob
hIKARInoob's picture
amaretto wrote:
Some measurements and beamshots, if you are interested. http://www.taschenlampen-forum.de/threads/thrunite-catapult-v6-review-pa...
Thanks! Thumbs Up
Nice review and very nice beam shots! I love the comparison with the V2 where the battery tubes are about the same in diameter. Big Smile
sp5it
sp5it's picture
Last seen: 14 hours 25 min ago
Terrible tint shift Sad
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
beam0
beam0's picture
Were you referring to the white wall beamshot? I don’t notice any terrible shift I couldn’t live with in the outdoor shots.
I didn’t try to translate but I assume that’s the CW version.
beam0
beam0's picture
Yes thanks for posting!
The outdoor beamshot comparison (GIF) photos in that review are awesome! (and most helpful!) The Thrunite blows away all the other lights.
Its larger reflector provides a much wider beam than UT01 and all the others, but with comparable throw… and even better throw than most of them.
And the CW tint is not bad at all, looks MUCH warmer/nicer than the Manker, Haikelite, Nitecore and Olight!
sp5it
sp5it's picture
Newlumen
Newlumen's picture
Maybe we might get shipping notice for the thrunite v6 today.
Geuzzz
Geuzzz's picture
Last seen: 55 sec ago
amaretto wrote:
Some measurements and beamshots, if you are interested. It’s the cool white version. http://www.taschenlampen-forum.de/threads/thrunite-catapult-v6-review-pa...
Thnx for sharing! Off topic: gotta love that D1s beam.
desmondkun
desmondkun's picture
Last seen: 7 hours 58 min ago
Great light for size and price.
Take care of your flashlight and your flashlight will take care of you.
Nicolaas
Agree.
Tested with around 185.000Cd. Not bad on one (big) cell and with a 50mm reflector.
But…..too small for my hands and my liking.
I go for the Amutorch.
Grtz
Nico
Speed4goal
So basically this light is a convoy l2 with a e switch?
If the price came down a lot maybe in a year or two I might get one.
180k throw is nice, my old xpg2 c8 hits around 170k.
Need to send off my sliced sst40 and see what numbers it’s hitting in my convoy l2
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
nullunit
nullunit's picture
“Expected Shipping Date is 06/15/2018”
Hmm. That is disappointing.
Buttkicker
I am having trouble logging into Thrunites website saying my email not recognised yet i have 3 emails from them from when i ordered the flashlightlight
i ordered my light 27 march and the replied my delivery date would be around May 1 and have heard nothing since and can now no longer log in
Nightcore ST-7
Astrolux MF-02
Astrolux MF-01
Utorch UT-02
BLF GT Gigathrower
Astrolux MF-04
