ThruNite Catapult V6 XHP35 HI
222 posts / 0 new
fluke
Last seen: 11 hours 37 min ago
Amazon Us ships to UK, maybe Sweden?
polarweis
polarweis's picture
Last seen: 5 days 19 hours ago
Could the driver be installed in a other light with e switch? what size is the driver?
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
Pavlo
Last seen: 8 hours 13 min ago
Has anybody tried an xhp70 led in the Catapult v6? Looks like it could make a nice single cell host with some throw.
pc_light
pc_light's picture
Last seen: 12 hours 48 min ago
I’ve gone as large as XHP-50.2 FWIW.
Took it from long distance pencil beam to wider beam medium range, better suited for my preference.
I am thinking of going XHP70 to my old U21 Wink for the same reasons.
Seeking the light.
mortuus
mortuus's picture
Last seen: 45 min ago
not sure why u want such a big emitter ? it wont be a really good thrower with tight hotspot.
...where Frugal meets with Flashlight!
Pavlo
What mcpcb did you use and how did you center it?
Pavlo
Not looking to make it into a thrower.
I would have two, one with XHP35 for tight hotspot throw, and one with XHP70 for added lumens, efficiency, and better illumination up close.
I find most XHP70 lights too floody, so this could be a nice compact host that still has some throw.
mortuus
mortuus's picture
okay, otherwise have a look on astrolux ft02, it has the xhp70.2 and similar size, maybe someone posted beam pics there to give u an idea.
pc_light
pc_light's picture
I used the “Sinkpad XHP50 12V 20mm Copper MCPCB” one of the few 12V boards available and the largest I could find at the time. Really needs a larger one (28-30 mm) to clear the reflector bottom.
Couldn’t find anything off the shelf, so I centered by eye and used thermal adhesive to keep in place.
Seeking the light.
Pavlo
Thanks for the added info pc_light and mortuus
FT02 is a good idea, forgot about that host.
Also thinking the V6 might work well using Clemence’s new quad e21a boards for a high CRI beast.
finges
Last seen: 2 days 2 hours ago
You could use the 32mm MCPCB from kaidomain and cut the trace and bridge it with a cable to adapt the MCPCB to 12V.
Like so
Also there was a 32mm MCPCB from Maxtoch at banggood for a while, only could find it at mtn now http://www.mtnelectronics.com/index.php?route=product/product&product_id...
(also for XHP70 http://www.mtnelectronics.com/index.php?route=product/product&product_id...)
