Discussion of compact size production throwers 700m+ under $60
101 posts / 0 new
beam0
beam0's picture
Last seen: 11 hours 37 min ago
For quite a while I’ve been looking at different compact size thrower lights (under $60) to find the best combination of distance and pocket-ability.
I’m only looking at side switch lights.
Here’s the ones I’m considering:
………………………………………………………………Length mm…..Head mm…….Distance (mfg. spec.)
  • Emisar D1S………..18650………..XPL-HI………….127……………50………………..720m
  • Maeerxu M8………..26650……….XPL-HI…………..142……………54………………..800m
  • Utorch UT02……….26650……….XHP-35 HI………148……………59………………..700m
  • Catapault V6……….26650……….XHP-35 HI………132……………58………………..750m
The D1S appears to be the most compact sized production thrower currently available for under $60 in it’s range class (700-800 meters)
It has about the same range as the others but it’s the smallest size. And even more compact having the thinner 18650 tube.
I’m leaning more and more towards the D1S.
All/any input and discussion is welcomed. Beer
Links added:
Emisar D1S
Maeerxu M8
Utorch UT02
Catapault V6
Edited by: beam0 on 03/26/2018 - 19:15
komeko
komeko's picture
Last seen: 1 month 1 week ago
Pay attention to the time the turbo flashlight goes into a lower state and how much power it has then. UT02 runs 180 seconds and falls down, but you can turn it back on in the turbo. In addition, in turbo modes, you can turn on the turbo without descending.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
FlashIight
FlashIight's picture
Last seen: 7 months 1 day ago
I’m not certain, but I think I recall a review which measured the M8’s throw closer to 600m…
IMO, you can’t go wrong with the D1S. I love everything about mine.
gravelmonkey
Last seen: 1 day 19 hours ago
+1 on the emisar, I wouldn’t describe it as particularly pocketable though.
Side switch is awesome.
Ramping user interface is excellent.
DENGOH
DENGOH's picture
Last seen: 7 months 2 weeks ago
UT02 is the one I would pick and quite cheap with coupon applied.
cool i'll see you when you get there
beam0
beam0's picture
Good point about the step down, yes need to consider.
I’m not completely sure but I think the D1S can keep up with that 3 minutes of the UT02, plus it’s user-adjustable in the firmware.
(Quote from TK’s review):
Thermal Regulation:
“it might not activate on the D1S at all, because the host is almost perfectly tuned to handle the heat on turbo without getting too hot.
However, the temperature limit is user-configurable, so you can tune it to fit your preferences”
beam0
beam0's picture
Thanks for pointing out. I didn’t look into it in the review, just comparing Mfg. specs. first, but I had a good feeling it was over rated.
toddcshoe
toddcshoe's picture
Last seen: 8 hours 44 min ago
Another vote for the D1S. Hard to beat that UI and the quality.
"Everywhere I go, there I am"
beam0
beam0's picture
I’m pretty sure at one time there were deals on it for around $30, now I’m seeing around $40, if you know the lower deal can you post a link to the deals thread?
Also why the UT02 over D1S?
beam0
beam0's picture
It’s probably going to end up being between the D1S and UT02.
Catapault V6… hasn’t a NW option and almost double the price.
Maeerxu M8… the UI may not be good, ramping only (slow) and no pre-set group.
DENGOH
DENGOH's picture
It has better feature like 26650, USB charging, batt low indication on switch and XHP35 HI.
Ya, nowadays its price stay around $40, very close to D1S. But its feature is much superior in my opinion. But I don’t configure FW much, I just use the flashlight.
Design wise I think UT02 is more handsome too.
komeko
komeko's picture
In this thread you have shown the turbo time for D1s:
LINK
UT02 is better for me because it has a better battery, longer working time, quality of finish, USB charging, the ability to work in turbo without going down, voltage stabilization so practically constant output level. You do the R100 mod and you have a small sweeper.
beam0
beam0's picture
Hmmm, UT01 and D1S are the same price.
I have to consider then,
  • UT02 bigger – longer and fatter head.
  • 26650 makes it feel less compact in size, but provide a lot more runtime.
  • USB charging I don’t need, but could come in handy on camping trip for instance, to charge from vehicle.
  • Batt level indicator switch is nice too, at least D1S blinks, but only shortly before shutdown:
    “The light blinks and drops brightness at 3V to warn users of impending darkness. There is low voltage protection at 2.8V when the light turns off”
  • I need to know why XHP35 HI is better than XP-L HI? Lumen output is the same on UT02 and D1S both 1300lm, does it have more spill beam?
  • It’s okay to have extra settings in the firmware, once you get it set up how you like, then you just use the flashlight Smile
Kicking myself though now for not getting UT02 when it was (I think) $29.99 Facepalm
beam0
beam0's picture
LINK
Yes good points, thanks.
Speed4goal
Well you could build one, convoy c8 host 11 dollars, fet driver 7 dollars. Xpg2 dedomed 6 dollars all from rmm. Add a couple dollars shipping for around 30 dollarsish you have a 700+m pocket thrower that won’t step down unless you want it to.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
DENGOH
DENGOH's picture
Do you have BLF GT? All flashlights are featherweight nowadays if you ever hold a BLF GT, just kidding Cool
At least UT02 is not overdriving XHP35 HI to get that output, I think I measure about 12.6V of Vled for its Turbo mode. I don’t have D1S, I am not sure its output is sustainable to drive XP-L HI for that output.
Pulsar
Pulsar's picture
Smaller die. Smaller die with equal lumens will result in higher lux, which is what matters with throw
beam0
beam0's picture
Yes I’m going to have some fun doing that eventually, I already have most of those parts. Smile
But right now I want to try a compact side switch thrower – stock off the shelf.
Here’s the tail switch throwers I have on the shelf to mod/build:
(Some from long ago and some newer)
  • Convoy C8
  • UltraFire HD2010
  • SupWildFire
  • LuckySun D80 BLF
Planning on XP-L HI w/FET driver and XHP35 HI w/boost driver for these.
I already have a few FET/DD drivers w/Dr. Jones guppydrv.
I think Xpg2 dedomed beam is thin? (don’t want a pencil beam, I’d like some decent useable spill)
I also might try to do something with my long 2-cell side-switch thrower: Small Sun ZY-T13
beam0
beam0's picture
D1S does seem compact though, this photo makes it hard to resist:
beam0
beam0's picture
I’d love to see a photo of the D1S along side a UT02, looked around a while but haven’t found one yet.
Agro
Agro's picture
Last seen: 5 hours 3 min ago
I bought UT-02 last December and the quality was way lower than my first, half year earlier.
  • Very dusty inside reflector
  • battery tube would have too long thread, leading to large gap between it and the head. There’s a lot of mess gathering there, I need to file it down eventually
  • USB cover is very flimsy. Once I dropped it on gravel when twisting the light to mechanically lock it.
The first and the second are easily repairable. The last one is actually the most severe and I don’t have a fix for it.
And after complaining to GB it turned out I paid $14 for it. Try to beat it for that price…
Overall I still love this light. My first was stolen and decided to buy another rather than Emisar. But considering the quality drop and the price hike (it’s roughly as much as Emisar now), I would probably trade USB charging, constant-current driver and better battery capacity for better host quality, better UI (I actually like that of UT-02 but Emisar is better) and lighter / more compact body.
komeko
komeko's picture
There is a photo where you can see both flashlights. In the Ma02 test for MF02:
LINK
arficus
Last seen: 4 days 13 hours ago
The head sizes are fairly similar for UT02 and D1S. What benefit is there in having thinner 18650 tube behind such a wide head? Neither are particularly pocketable. I would much rather have extra run time of 26650 in a light with that form factor.
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 1 min ago
The UT02 form is my favorite modded, I have put just about every emitter you could put in the UT02 from MT-G2 XHP70.2 XHP50.2 XP-L HI XP-L W2 (domed/de-domed) and an old school de-domed XP-G2 pulling 6.3amps. With Lexels T/A 30mm drivers and Narsil UI and lighted switch. I run 2×26350’s for the XHP’s and run 26650 26700’s 21700’s and 20700’s in the other 3v emitter lights. I was never happy with the stock UT02/XHP35HI but with Lexels 1S boost driver at 3amps, I have one stock UT02 sitting here waiting on this driver.
To me the D1s is not attractive at all… Sick
KB1428 “Live Life WOT
beam0
beam0's picture
LINK
!https://i.imgur.com/TpLJtqn.jpg!
Good find, thanks!
The D1S might look shorter though since it’s position is in front of UT02, but that does give an idea of the size difference.
Billy X
Billy X's picture
Maybe have a look at the Haikelite SC01 .I don’t have one but 2000lm turbo from XHP35 Hi,,with thermal regulation,26650 with usb charging,135mm long,40mm head,under. $35.Anyone know more about it?
beam0
beam0's picture
Similar but quite some difference, (measurements in the OP) out of the four lights UT02 has the widest head (59mm) and D1S has the smallest (50mm)
Also the same with the length (UT02 longest, D1S shortest)
I do realize these are not quite pants pocket sized lights, was thinking more of jacket/vest side pocket. So basically which of the lights fits smaller in the hand for that. The D1S seems to be a good bit smaller overall.
True about the battery capacity for extended run-time, and the D1S does kind of look odd or unbalanced, the short thin tube with the large 50mm head.
I’m going to have to look to some reviews to find actual kcd measurements, what benefit for a nearly a 10mm wider head if the throw distance is slightly less, not more?
beam0
beam0's picture
I agree the UT02 is looks nice and the DS1 is kind of ugly Smile
And real good point about the upcoming Lexel 1S boost driver.
beam0
beam0's picture
That is interesting, throw distance less but not to shabby:
“Throws measured @92160cd / 607m (600m Claimed)”
Quote from this review: http://budgetlightforum.com/node/55629
So now I need to find some actual measurements of the others too.
Not that it matters a lot but I find it to be unappealing in looks, uglier than D1S I think. Sick
Dirty_Pierre
Dirty_Pierre's picture
Last seen: 1 year 11 months ago
FlashIight wrote:
I’m not certain, but I think I recall a review which measured the M8’s throw closer to 600m… IMO, you can’t go wrong with the D1S. I love everything about mine.
I’ve got them both with same emitter option. 4000k I like them both. I haven’t had the time of late to run the numbers and do my comparison shots but when I had them both out to the lake a very cold night not long ago, it looked like the D1S out threw the M8 slightly. However the M8 did not get nearly as hot like the D1S did which was nice. If that’s due to a weaker thermal path, or simply the larger mass of the M8 we’ll see. I like the 26650 size and cell options for run times vs the D1S. The UI of the D1S seems more polished than the UI of the M8 also, but I have plans on doing some stuff to the M8 to make it more to my liking.
Just throwing my 2cents in the mix regarding my feelings towards both of those options.
RobertB
RobertB's picture
Last seen: 5 days 11 hours ago
The Maeerxu M8 is nice. Neutral tint, lighted side switch, on board usb, high quality machining. Some think the Maeerxu might be made in the same factory as the Emisar lights. I don’t doubt it for a minute. Materials are virtually the same, build, and anodizing is very similar. Even the thread shape and pitch is identical.
