6. Batch "TA" 1S or 2S Bistro HD OTSM/NarsilM drivers 15-47.5mm size fit, S2+, C8, H03, MF01, MT03, Q8 Clicky or E-switch
307 posts / 0 new
Lexel
Lexel's picture
Last seen: 3 hours 47 min ago
on latest Gen I used 8 or 10 mil safety distance
F.i.l.a.s
F.i.l.a.s's picture
Last seen: 6 hours 9 min ago
Okay Lexel, I will check once more the spots you showed as potencial issue, thanks Wink
chadvone
chadvone's picture
Last seen: 1 week 2 days ago
Lost a switch pad on my skilhunt driver. Anyone know another option?
vinte77
Last seen: 2 hours 10 min ago
You can use one of lexels switch boards from oshpark as a replacement.
chadvone
chadvone's picture
Is there another option to connect the switch?
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 17 min ago
ATiny 13/85 try the #2 Leg of the MCU the other to Grnd.
KB1428 “Live Life WOT
chadvone
chadvone's picture
Awesome. Thank you very much. I know there should be a pin from MCU.
Now I need to figure out were number 2 is.
Thank you and Merry Xmas
ZozzV6
ZozzV6's picture
Last seen: 3 hours 59 sec ago
Number one marked with a dot on the atmel. Pin 2 is in the same leg line next to it.
chadvone
chadvone's picture
Thanks for the save Smile I been in a rush to get this together before family shows up. Doesn’t pay to hurry, I know.
JasonWW
JasonWW's picture
Last seen: 10 hours 8 min ago
I guess pin 2 is what Lexel uses on that driver? It can certainly vary. It might be best to trace the circuit back to verify it’s pin 2. (I’ve seen drivers where pin 7 is used)
Alternatively, you can scrape the solder mask off the trace by the pad and attach the wire there. The current is super low for the switch.
Click this to go to signature links.
KawiBoy1428
What BLF based/designed drivers use pin #7? Every BLF based driver using the Atiny13/85 I have used, uses #2 Lexels/RMM’s.
KawiBoy1428
Your welcome, Merry Christmas to you and yours! Beer
JasonWW
JasonWW's picture
The Haikelite MT09R and MT03 drivers that Texas_Ace built uses pin 7. He said he had to flip the MCU around so it fit the design better.
My point was that the pins are assignable, so it’s always good to verify.
Lexel
Lexel's picture
Dont understand TA MT03 is different from his basic 46mm SRK he used to use 2 1206 0Ohm, On my designs I traced it without 0Ohm or changing any parts location or orientation
I flipped many drivers MCU from TA designs and never ran into pin assignment problems
I would always stick to the standard firmware pinouts which is compatible between them thanks to some forum members
Some drivers need to run a trace below a resistor
Switch will be aleays pin2
2S pin7 for voltage divider
2 channel pin 5,6
Indicator LED 3
3 channel 5,6,3
Indicator 7
KawiBoy1428
Most everybody knows they are assignable, not BLF based drivers Lexel/RMM (#2 is kind of a standard) that I know of ever used #7, and this IS Lexel’s driver thread, any way good to know it was done on the Hacklites MT09R MT03 for what ever reason?
KawiBoy1428
2 channel pin 5,6
Indicator LED 3
3 channel 5,6,3
Indicator 7
Right on! Thumbs Up
JasonWW
JasonWW's picture
You know what, there might have been some confusion about the chip orientation. I think it was Pin 2 after all and not 7.
chadvone
chadvone's picture
I have got this driver working. I also lost the indicator light pad. Both mishaps where my fault and had nothing to do with the with the driver. I had the driver in a small vise when I was soldering the switch wires on, when I took the driver out of the vise the head of the light caught the vise, my solder joints held and the pad didn’t.
Thanks everyone that contributed to my success.
johnkey68
Last seen: 2 hours 36 min ago
It would be interesting to install a driver waiting for Eagle Eyes X6R with the Narsil v.1.2 firmware and an E-switch
Is it possible ?
eas
eas's picture
Last seen: 1 day 4 hours ago
According to the hwdefs, TK’s 4-channel lightsaber driver has the switch on pin 7 Smile
Lexel
Lexel's picture
johnkey68 wrote:
It would be interesting to install a driver waiting for Eagle Eyes X6R with the Narsil v.1.2 firmware and an E-switch Is it possible ?
as far as I have seen the X6R uses switch on the main board and another piggy back board for charging and AMCs
It may be possible to add one of my drivery, you may sacrifise the charging board, like here and here
if the driver cavity is deep enough yopu may use charging board as well
JasonWW
JasonWW's picture
Is it possible ?
Some lights make good hosts, some don’t. Due to the switch, the X6R does not look like a good host light.
Lexel
Lexel's picture
Shipping conditions in Germany changed
usually you could ship whatever you wants just needed to look to size and weight specs
for sending items you could simply make another stamp and declaration and envelope had not to be glued and it was even cheaper on size and weight compared to normal envelope
now they simply changed normal envelopes to papers only, so they can charge more on non business customers for a parcel instead raising the price from 3.2€ to 18€
and for sending items you need to make a business account with 200 national shipment per year minimum quantity
this would not apply to me
If they check with x-ray or so the stuff I sent last days may be returned
contactcr
Last seen: 1 hour 57 min ago
Look in to DHL eCommerce
Lexel
Lexel's picture
I doubt I will ever get back to 4€ tracked and 25€ insured envelope
if they really filter non paper envelopes with drivers in them with x-ray I got literally no other option than to send by DHL (17€ untracked uninsured or 46€ tracked and insured)
contactcr
The DHL ecommerce isnt the fast DHL. Its a different product which i assume would be cheaper but i couldnt find pricing without getting a business quote
Lexel
Lexel's picture
yes you need 200 per year minimum national and 5 per quarter international
no way i get that many national as most is international
scr79423
is it possible to make a FET+N+1 driver for a 2s2p configuration on a MF02S?
Lexel
Lexel's picture
does not make sense, as the LED is 12V, it woulsd smoky any AMCs plus its not regulated
Buck driver with 4S carrier mod is the way to go, we got full output and regulation
Tom E
Tom E's picture
Last seen: 6 days 2 hours ago
Lexel wrote:
as far as I have seen the X6R uses switch on the main board and another piggy back board for charging and AMCs It may be possible to add one of my drivery, you may sacrifise the charging board, like ...
Ahhh, the custom X6R driver exists - I've used them recently.
This is a triple stack from PD68, old but latest driver design. All my pics on this triple LED X6R mod here: photobucket.com EagleEyeX6R Triple
 It's a great light now - triple 90 CRI XP-L2's, though I didn't get in an AUX LED - need to add that still.
