Hey guys i’ve just ordered a 3000K clear l6 :partying_face: and now i need two 26650 … I searched for information here but the posts are like 1-2 years old… so im about to buy these ones but im asking maybe im missing something better? Thx
well dont think so, i was hoping the new keeppower 6000mah would work for l6 but someone said they are too big and dont even fit
Get the new shockli 5500 unprotected button tops. Will give you the best of capacity and output
thx for the suggestion guys! yeah its a shame the 6000mah doesn’t fit the l6… and the shockli seem nice but i thought you only have to put protected batteries for this light
I think only the protected 6000mAh does not fit, the unprotected ones seem OK - but i haven’t checked. AFAIK the L6 has LVP so you should be good with unprotected. However, the 6000mAh are not much better then the 5500mAh - possibly the same cell inside?
That’s the best capacity/price deal i think - Liitokala 5000mAh:
https://fr.gearbest.com/batteries/pp_663615.html?wid=55
Thx for the link but gearbest can’t ship lithium batteries to my country!
I thought batteries in series should be protected?
well yes but if using good quality matched it shouldnt be a problem, im using Efest 4200mah they work fine no issues so far.
puglife2, look no further than the popular PLB 5000mAh cell if you want to spend your money right: https://www.aliexpress.com/w/wholesale-liitokala-26650.html?g=y&CatId=52805
Less than $4 per cell easy with slow boat shipping.
Cheers :-)
thx guys i’ll check them out :+1:
Did those 22650’s from AliExpress work out?
I want to buy a first generation L6.
Can you recommend batteries for this flashlight, what perfect fit to this Convoy?
Being thrifty I do not usually like a lot what I see in Vapcell store, but you are sure to get “real deal” cells from them (or you should). Check their 26650 store section here.
Before anything else I'd first take a careful measurement of your L6 tube inner diameter, because unless it is at least fairly close to ∅27mm certain cells (like this ∅26.6mm “INR26650-55A” Power Long Battery made one) are probably not going to fit inside. Have some petroleum jelly at hand if you are going to take the risk of trying to fit a too wide cell inside, just in case… O:)
What do you think about this? Soshine protected 5500mAh
I can buy for good price, protected, and there is a lil bottom on top.
Size is: D26*H68.5mm.
should be good as long as its button top.
