Review: ROFIS R2 1xAA, 1x 14500
7 posts / 0 new
roma58
roma58's picture
Last seen: 1 week 3 days ago
ROFIS R2
The ROFIS R2 was sent to me by ROFIS for the review.
For the description, manual and technical data of the house here: http://www.rofislight.com/products/rofis-r2/
The Rofis R2 can be purchased on Amazon or Banggood.
Description and Technical Data:
The ROFIS R2 is part of the new series of multifunctional torches alongside the Rofis R1 presented a few months ago and the R3 output lately. Use a CREE XM-L2 U3 LED. Feature of this torch is the possibility of rotating the head of 90 ° and the integrated magnetic charging function. It has luminous indication of charge, temperature control circuit, magnetic tail, lock function and protection for reverse polarity. It has degree of protection to water IPX8 (2m). The Rofis R2 is suitable for many uses being able to transform from linear to angular (and vice versa). The Rofis R2 can be powered by a number of different batteries; 14500, AlkalineAA and Ni-MH AA.
These are the main features of the ROFIS R2:
Specifications:
  • LED: 1 * Cree XM-L2 U3 LED
  • Battery: One 14500 lithium ion battery (included)
  • Maximum output up to 700 lumens, beam distance up to 120 meters
  • Dimensions: 97.5 mm (Length) x 22.0 mm (Diameter head) x 20.0 mm (Tail diameter)
  • Material: aluminum alloy structure, Type III hard anodizing
  • Weight: 67 g (without battery)
  • IP protection rating: IPX8 2 m under water
  • Impact resistance: 1.5 m
Levels (Battery 14500):
  • Turbo: 700 - 300 lm / 3 + 67min.
  • High: 300 lm / 98min.
  • Med: 90 lm / 253min.
  • Low: 5 lm / 43h
  • Moon: 0.5 lm / 125hours
  • Strobe: 600 lm / 83min.
  • SOS: 600 lm / 90min.
Inside the package:
  • R2 torch + clip
  • 1 x rofis 14500 800 mAh lithium ion battery (installed inside the R2)
  • 1 x USB charging cable
  • 1 x band
  • 1 x lace
  • 2 x O-Ring
  • 1 x user manual
  • 1 x guarantee certificate
The packaging:
Good packaging of Rofis R2. The cardboard box opens to the book, we find printed the main features of the new Rofis R2 and the included accessories.
Package contents:
Once removed from the box, the battery of the R2 must be completely recharged before being used continuously. The supplied battery arrived with the Rofis R2 measured, in my case, 3.8v. Also remember to take out the protection tab under the negative pole of the battery.
Very deep the tailcap of Rofis R2 as seen from the picture. We see that the battery comes out of the torch body for 15 mm. No problem, however, to screw it into place.
The battery supplied with the Rofis R2 is a 800mAh 14500 Li-ion battery.
Charge indicator:
Once the battery is inserted into the torch and the tail cap is screwed on, the power button lights up briefly to indicate the charging status. If it lights up green we have more than 40% of remaining charge, if it lights red less than 40% and finally if red flashing indicates low battery power.
The Rofis R3 is equipped for charging a propretary cable approximately 54 cm long. This has on one side an effective magnet to be connected to the charging base above the Rofis head, and on the other a standard USB connector. Charging can also be done by connecting the USB cable to electronic equipment such as powerbank etc.
When the battery is being charged, the side button in translucent rubber lights up red. When the charge is 100% it lights up green. When the Rofis R2 is charging, the torch can be turned on, but only in Low mode. After charging (green led) I measured 4.19v for Rofis R2. To recharge the battery of the R2, when it is completely empty, you need about two hours.
If we try to load the Rofis R2 with the battery inserted with the inverted poles, absent or if there is a malfunction, the button will flash red and green alternating to alert us of the problem.
A comparison with other torches:
From left: Rofis TR15, Rofis R2, Zebralight H502 and Battery Rofis Li-ion 14500
The three Rofis R series together.
The head of the Rofis R2 has an SMO reflector (smooth) with the XM-L2 LED in the middle. The R2 is available in a cool white version.  The lens has an A.R. (anti-reflective) protection and  a polished stainless steel bezel that protects and enhances the aesthetics of the R2.
Magnetic Recharge.
On one side of the Rofis R2 head, there is the golden USB charging base. Being magnetic, allows charging on the fly.
As I was told by Rofis, the new R2 can also be loaded in fresh water without problems. I wanted to try with the Rofis R2 and in fact the recharge happened with the same times of the normal recharge and without problems. The magnetic board that I thought was blackened, remained the same.
The power button is made of rubber material, the dimensions are discreet and the click is decided. At the center of the button we have a translucent point with a notification led below it. The switch is not raised, it can be difficult to find it in the dark, especially with the use of gloves, fortunately the clip can help. This is simple but effective, firmly to the torch body and flexible at the right point.
The clip in the Rofis R2 can be inserted, without creating problems, only on one side of the four available (according to the tests done by me). Two sides are occupied by the power button and the charging base and one must be left free for the rotation of the head. As you can see in the picture, the clip is installed on the side with the word ROFIS.
Good quality and precision are the writing on the Rofis R2 as well as the glossy black finish and the knurling on the head and body.
As already mentioned, the head of the Rofis R2 can be rotated with a 90 ° excursion. The particular structure of the torch allows, once transformed into angular, to combine a non-acute angle as previously happened with the TR series.
The only part that can be unscrewed in Rofis R2 as in the other "R" series torches is the tailcap.
At the negative pole there is a removable plated spring with the magnet underneath. Also to the positive, contrary to that seen on the R1, we find a plated spring.
The tail being flat allows the use of the torch in a candle position (tail standing). It is also equipped with a hole to insert the lanyard.
The magnet in the tail of the Rofis R2 is powerful and allows you to anchor the torch stably on iron objects.
The fillets on the body of the Rofis arrive, in my sample, not so much lubricated; being anodized they allow the physical lock-out of the torch.
        THE HEADBAND:
The elastic headband is well made, worn and adjusted easily.
In the Rofis R2 the torch in angular version fits easily into the orange silicone support, provided that the tailcap is momentarily unscrewed. If inserted with the switch on the left side, you can keep the inserted clip without problems. In this case it is easy to rotate the torch up to cover an angle of more than 90°
The switch is well visible.
We see the band with torch and clip worn on a helmet.
Without clips Rofis recommends using the switch on the right side.
Good distance covered by the Rofis R2 beam.
Rofis as a headlight can also be placed above the ear.
All these possibilities make the Rofis R2 ideal for use as headlamp.
User interface (UI) and levels:
Rofis R2 (battery 14500):
Medium: 90 lm / 253min.
Low: 5 lm / 43h
Rofis R2 (AA Alkaline battery):
High: 300 - 90 lm / 1 + 125min.
Medium: 90 lm / 132min.
Low: 5 lm / 39.5hours
Moon: 0.25 lm / 312h
Strobe: 300 lm / 127min.
SOS: 300 lm / 238min.
Rofis R2 (Ni-MH AA battery):
High: 300 - 90 lm / 1 + 201min.
Medium: 90 lm / 204min.
Low: 5 lm / 35h
Moon: 0.25 lm / 219h
Strobe: 300 lm / 107min.
SOS: 300 lm / 120min.
Turning on and off:
Press the toggle button to turn on or off. The lamp has memory and starts from the last level of light used. (Strobe, SOS, Turbo and Moonlight are not saved in memory).
Change brightness:
In power-up mode, long press the toggle button for longer than a second and hold down, the Rofis R2 will circulate between "low light, medium light and high light". When released, it will be in the current position selected.
N.B. In the Rofis R2 if we use batteries other than 14500 (Alkaline or Ni-Mh), we lose the 700 lumens Turbo level. Pressing the button twice will call up the High level.
Turbo:
In the on or off status, double-click the toggle button to enter Turbo mode.
Moonlight:
In the off state, long press the switch button for 2 seconds, the flashlight turns on in the moon mode.
Special modes:
1) Strobe: in each state, in a fast and continuous way, click on the button 3 times and the torch will enter a stroboscopic state.
2) Strobo-SOS: in stroboscopic mode, long press the switch, for more than 1 second, the torch goes into SOS mode. Pressing the switch again for longer than 1 second to return to Strobe mode. Then press to turn off.
Electronic Lock:
Lock: in the off state, long press the switch for more than 3 seconds (it will enter the moon mode before the lock is active).
With the lock active, if we try to press the switch, the red indicator will light up for one second.
Unlocking: in the locked state, long press the switch for more than 3 seconds, it will enter the moon mode and the lock will be removed.
Let's see the beam of the Rofis R2. Discreet the spot tending to the yellow and an effective spill without particular artifacts. The distance between the beam and the feet is about 50 cm.
Runtime.
The test was performed with the battery fully charged in TURBO and HIGH without forced ventilation. The battery used is the one supplied with the R2 and that is a 14500 of 800 mAh.
We see that in TURBO after exactly 3 minutes there is a step down that brings the light output to halve the initial value of 3420 cd. When the battery is almost empty the torch warns us with a flashing red flashing on the power button.
Below the graph of the first 10 min. in TURBO:
Two shots in TURBO with the Rofis R2.
Unboxing of the Rofis R2 and R3
CONCLUSIONS:
ROFIS with the "R" series and with this Rofis R2 has greatly improved the already good quality of the previous TR15. Many positive aspects of Rofis R2 make it a "must" in the field of torches AA / 14500. I wait for the next evolution to see it with a different LED.
Thank you for reading this review.
Edited by: roma58 on 04/04/2018 - 09:28
agent80
Last seen: 2 hours 57 min ago
Nice review. Thanks.
What with the proprietary charging cable? A micro usb would have been perfect.
roma58
roma58's picture
I meant propretary in the sense that it has the magnetic contact to connect to the base above the head. The connection to the USB port is standard.
theadlee
Last seen: 4 weeks 9 hours ago
I tried charging a Ni-MH (Eneloop Pro) battery in the torch. Would not charge. 14500 charges fine. Is this by design? Doesn’t say in the manual.
roma58
roma58's picture
The Eneloop Pro Ni-MH are recharged. After inserting the battery and closing the tailcap, connect the USB charging cable. Now unscrew slightly and screw the tailcap back on. You will see that the red charging light comes on.
theadlee
roma58,
I tried this and indeed the light comes on, but it doesn’t actually charge. Tried multiple Ni-MH batteries and let them charge for 6+ hours. Same result. Can you confirm on yours that it actually charges Ni-MH. It appears that only the charging red light comes on with Ni-MH.
Todd
roma58
roma58's picture
I tried with Eneloop pro and with other Ni-MH. It is strange but with the Eneloop Pro something loaded, with other Ni-MH not. In the manual it is however written that the Ni-MH are not recharge.
