Vappower INR20700 3000mAh (Green)
Official specifications:
Nominal Voltage: 3.6v
Charging Voltage: 4.2v
Standard Charging: CC-CV, 1.25A, 4.2V±0.05, 50mA cut-off
Rapid Charging: CC-CV, 4A, 4.2V±0.05, 100mA cut-off
Capacity:3000mAh
Energy Density: Nom.240Wh/kg
Max. discharge current: 30A
Max. pulse discharge: 50A
Discharge cut-off voltage: 2.5V
Internal resistance:Max.20mOhm
Cell weight: 47G
A high current 20700 battery.
The discharge curves tracks fine and the cell has nearly constant capacity.
The cell gets fairly warm at 20A
And I had to stop the discharge at 30A
Conclusion
This battery can deliver a lot of current with a good capacity, performance is about the same as the best 18650.
Notes and links
The battery was supplied by Vappower for review.
Compare to 18650 and other batteries
