Newbie here. Ok so this weird thing happened. I have this Nitecore 18650 battery (model NL1835R, one with a USB port) that I got as a gift. I was using it fine for like a couple of days then when I decided to charge it today it felt quite a bit hot as I got it out of my MH20, which btw was off and not in use for hours. I also noticed the indicator lights on the battery were going out of whack as I took it out, then disappeared after a few minutes.
I then plugged it in to charge using the built-in port and no indicator lights were showing. I thought it wasn’t charging so I charged it using an external charger and it was charging and I had the chance to use it a few times after that.
I then set it aside to let it “rest”. After a few hours on the table, the button top of the battery felt hot (yes, hot and it was out on the table) but the body was mildly warm only. I pulled out my voltmeter and get this, it read 9.96 volts (like wtf?). I tried measuring my other batteries and those read 4.18-4.19 so I knew the voltmeter was okay.
Can anyone give me an idea what might have happened? I’m not sure if the circuitry is broke or if my battery is dead or about to explode or what. I’m kinda apprehensive about plugging it in the charger since something might happen lol. Please help.
Get rid of it, safely. Obviously, that battery is waiting to vent or flame or even explode. 9.96v sounds impossible (circuitry gone wrong?), unless it’s a battery pack with multiple cells, but whatever the case, any battery that stays warm when not in use is an extreme safety hazard.
Most of the vent and flame thing with li-ion is exaggerated gossip, I think. If you read Intertek's guide to the UN requirements for lithium battery testing prior to transportation, in page 9 you can see the overcharge test for single li-ion cells implies “2xvoltage and current” for 24 hours, with a “no disassembly or fire within 7 days of test” pass criteria. Serious benchmark!
And you know… well, everything's possible I believe. ;-)
Oh, I agree that many people are far too paranoid about lithium-ion cells. But, I wouldn’t keep a cell that stays hot when it’s not being used. That is trouble.
Stick it in a metal can and let it cool down. Line the can with some plastic so it doesn’t short. When it reads close to 0 volts, throw it out or recycle it. I assume it’s an internal short, so it should discharge by itself over a few hours or days.
I wouldn’t trust Nitecore to have used only cells from quality brands. I wouldn’t trust shady chinese cell makers (there are tons of them) to produce anything that passes regulated tests.
The temperature OP describes shows either the cell or the circuit is damaged (or both). Not necessarily will this lead to a thermal rundown, but it very much increases the risk. As this produces at least poisonous fumes and fire, who wants to use this cell anymore except somebody who doesn’t care about himself or others?
And the voltage clearly is way off, so using the cell might damage anything you put it into. Why bother.
only way i can see that cell reading 9.xx v is on a harbor freight meter with a low battery.
they can be wildly inaccurate when the battery is low.
the heat is damage to the charger/protection board.
i would take it off and convert it to unprotected.
cell is likely fine.
If those measured voltages are right (9.96V, then 9.68V after a few hours means damaged cell), such cell should be disposed. I've seen cheap 4.2V cells die just by overcharging them up to ≈4.35V. It's not worth taking a risk in this case.
If the instruments you’re measuring these batteries with consistently measure other known voltages accurately; please do not sleep in a residence with this battery in it.
Easy enough to read less voltage from a battery, requires a specific circuit to put out a reading at 2X what you’re expecting.
There may be special circumstances but if the battery was “quite a bit hot as I got it out of my MH20, which btw was off and not in use for hours” there’s a problem.
I’m not sure that test indicates the cell is charged up to 20v. It may just be that they use a 20v load on it in order to force current through it to overcharge it. Can a lithium-ion cell even have a resting voltage more than about 5v?
